Toymods » Tech & Conversions » 1UZ CAS
SupraPete
1UZ CAS Wed, 25 September 2002 05:16 Go to next message
Very specific question:
How many lobes on the Crank does the Crank Angle Sensor read? Is it 32?
KDog
Re: 1UZ CAS Wed, 25 September 2002 05:37 Go to previous messageGo to next message
The 1UZFE has 12 teeth on the crank angle sense or engine speed sensor as Toyo call it.
SupraPete
Re: 1UZ CAS Thu, 03 October 2002 04:30 Go to previous messageGo to next message
Is there another sensor that tells the computer that its at TDC.
How does the computer know where TDC no 1 firing position?
There are 12 teeth (I checked as well), how does it know which one is TDC?
Is this a Cam Angel Sensor or a Crank Angle Sensor? Its at the bottom of the engine, which I'd assume its off the Crank.
Pete
gold coast
Re: 1UZ CAS Thu, 03 October 2002 11:54 Go to previous messageGo to next message
It will have a Sync (Motec) or Cam position sensor (toyota).
Maybe even 2.
JZ series have 2 Cam Pos sensors, why i do not know. The rear most sensor is at TDC cyl 1. The front sensor is 180 deg opposite.
1UZ FTE
Re: 1UZ CAS Thu, 03 October 2002 21:56 Go to previous messageGo to next message
HI Guys
The Home trigger is on each cam pulley wheel it is a little tooth that sits proud approx 3 to 4mm high and the sensors are just underneath the cam wheels
It runs each dizzy seperate for each bank apparently?
jamie
SupraPete
Re: 1UZ CAS Fri, 04 October 2002 02:08 Go to previous message
Jamie,
What computer are you running? The standard toyota fires the injectors in pairs, the computer I'm putting on - Delco - fires them all at once, which won't hurt power output over 2,000. But might make it idle a bit differently (not a problem, just different).
Need to find a way for the computer to know TDC. Might grind a few teeth off the crank, down to 4 teeth (from 12). Then get it from that. Can't do it from the cams as they run at half crank speed.
Peter
Previous Topic:Gearbox conversion
Next Topic:ra40 + 1g-ge install tech article
Current Time: Sat Oct 17 10:02:32 UTC 2026
Total time taken to generate the page: 0.0051710605621338 seconds
