Toymods » Tech & Conversions » Wolf3D on 1GGTE...realistic power???
BLK1GGTE
South Eastern Subs
icon5.gif  Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 04:46 Go to next message
I just want to know if anyone has used a WOlf 3D on a 1GGTE. Its been recommended to me as originally I wanted to fit the APexi SAFC for fuel mixture.
How does it compare to the Jap computers?
I heard it has more features and will be able to reduce lag on the standard set up with ignition control. Anyways I brought a HKS cooler and want to wind the boost to 15 pounds.
I am hoping for 160 to 170 rwkw with the Wolf 3D. Is this possible?
Also I can remove the air flow meter with the WOlf 3D. Any benefits in this?
Well looking for any informative opinions.
faulksy
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 05:25 Go to previous messageGo to next message
i have heard wolf and toyota dont go down well. i know of a 4age 20v motor which had a wolf and the cpu didnt know how to communicate to the crank angle sensor (pretty sure it was this sensor). a special box needed to be made up for it to work. i dont know if your going to have similar problems with a 1GGTE
sideshow
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 06:20 Go to previous messageGo to next message
u might need a reluctor interface
most new aftermarkets ecus these days are compatible with most engines
its only the older ones that used to cause many probs
these days theyre so cheap i dont know y people buy 2nd hand older ecus
if u cant afford a new one then keep it std
BLK1GGTE
South Eastern Subs
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 07:31 Go to previous messageGo to next message
But bang for you buck is the WOLF 3D a good buy or does anyone know something better for that price to work with the 1ggte?
sideshow
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 09:01 Go to previous messageGo to next message
what are they worth
microtech is only 1100 bucks retail
and i have wired up many of them with no problems
YelloRolla
On your mum!
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 09:02 Go to previous messageGo to next message
Bang for buck the Wolf is O.K. The top end power will be pretty much the same if it's a Wolf or any other computer - it's the tuning effort and the base engine that are going to determine how it goes.
Aiming for 170rwkW is something - but you will give the tuner the car, he will give it the fuel and ignition that it needs to make best power and the dyno will give the number - and it all happens in that order - and you just can't get away from it.
Go with the management that your tuner likes to use.
BTW - I run Wolf version 3.1 and I will run Wolf version 4 when I can afford it.
[Updated on: Fri, 24 September 2004 09:03]
Siktoy ra23
Plumpton/sydney
Re: Wolf3D on 1GGTE...realistic power??? Fri, 24 September 2004 10:19 Go to previous messageGo to next message
I use EMS stinger and they retail for $995 And mine makes 167kw and is very smooth to drive down low as well
BLK1GGTE
South Eastern Subs
Re: Wolf3D on 1GGTE...realistic power??? Sat, 25 September 2004 16:57 Go to previous message
Thanks guys for the responses..very helpfull..the guy is a wolf 3d tuner so i will go with it...and i get my AFM removed so i get that gay turbo induction noise..don't know if i get more power but.. with the removal of the AFM??
Previous Topic:HELP!!! 1G-GTE TPS adjustment specs.
Next Topic:1jz - removing injectors?
Current Time: Thu Oct 22 06:55:36 UTC 2026
Total time taken to generate the page: 0.004655122756958 seconds
