Toymods » Tech & Conversions » Supercharger clutch (do I need it)
ToNkA
icon4.gif  Supercharger clutch (do I need it) Fri, 24 September 2004 08:30 Go to next message
I have a 1ggze engine that I dropped into the hilux today. Now I want to know about my supercharger? How does the clutch work on it? What makes it come on, when does it come on?
Do I need a clutch on it? Or can it be run simply off the pully?
If you could take some time out to explain it that would be great.
1. I am wondering if I can remove the clutch set up so that I have some more room for the radiator.
2. I am also wondering how the clutch works anyway for when I wire this engine up.
Tonka
Re: Supercharger clutch (do I need it) Fri, 24 September 2004 09:14 Go to previous messageGo to next message
Clutch works like an AC clutch - you apply power, it locks, you remove power, it freewheels. The ABV allows the engine to breath when the blower isn't running.
Re: Supercharger clutch (do I need it) Fri, 24 September 2004 10:21 Go to previous messageGo to next message
me thinks it is a choce between a SC clutch or a SC that rapidly wears itself out from over use.
GZE ECU is supposed to decide whether to use the ECU or not
ae95
Re: Supercharger clutch (do I need it) Fri, 24 September 2004 10:30 Go to previous messageGo to next message
thechuckster wrote on Fri, 24 September 2004 18:21
it decides whether to use itself or not?
i think you mean it decides to use the supercharger or not
Re: Supercharger clutch (do I need it) Fri, 24 September 2004 10:42 Go to previous messageGo to next message
i think one is a tactical choice (whether to let the ECU decide when to use the SC) and a longevity test - how long a toyota SC lasts when used 100%
i'm assuming Tonka want's to see how long a SC lasts when not wired up as per factory?
drift86levin
brisvegas
Re: Supercharger clutch (do I need it) Fri, 24 September 2004 10:53 Go to previous messageGo to next message
another bad idea is what my amte done to his MR2..he simpy put a 12 vlot switch in place and ran it when ever he wanted..and it was way better with the stock ECU!!!
pure WANK factor!!
rozz
Re: Supercharger clutch (do I need it) Sat, 25 September 2004 06:53 Go to previous messageGo to next message
this topic also applies to me as i plan on putting one of these chargers on my 5sfe but also with wolf 3D, how could i wire it up
what is the point of having a blower if its not on all the time
thats just useless
ToNkA
Re: Supercharger clutch (do I need it) Sat, 25 September 2004 08:59 Go to previous messageGo to next message
My main reason for not running the clutch was to make it easier to fit a radiator in my hilux. The SC clutch makes things real tight.
Looks like Im keeping it from the responses.
Smile
Re: Supercharger clutch (do I need it) Sat, 25 September 2004 09:09 Go to previous messageGo to next message
toyota SC is not designed to air sucked thru it (e.g. when there is high manifold vacuum). is why there is a bypass arrangement on 4agze (and 1ggze i think).
the ECU detemines when to switch the blower on - which is usally when you are generating a large amount of power. I think ECU also controls the bypass valve.
being on 100% will shorten life of blower considerably and you will get no benefit from it at low rpm or power output (e.g. cruising or idling).
you might be able to get a Wolf ECU (or any other ECU) to drive it if it can be programmed to enable the SC under certain conditions (e.g. low vacuum, near WOT, high airflow, etc).
sideshow
Re: Supercharger clutch (do I need it) Sat, 25 September 2004 22:40 Go to previous message
it usually comes on at about 1500 to 2000 rpm
u have to remember if it comes in when revs are to hi it will slip abit
this will drastically wear the clutch surfaces
toyota spent many work hours figuring out the best time for it to come on
y go changing it
if u want a supercharger that is on all the time buy a
sprintex supercharger
Previous Topic:Are 3sgte ECU (GT4, SW20, diff series) interchangable?
Next Topic:HELP!!! 1G-GTE TPS adjustment specs.
Current Time: Tue Oct 20 00:06:48 UTC 2026
Total time taken to generate the page: 0.0057849884033203 seconds
