Toymods » Tech & Conversions » Best (4 stud) brake upgrade(s) for xA6x celica/Supra?
Stefan
Hobart, Tas
Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 11:57 Go to next message
If I want to stay 4-stud, what's the recommended brake upgrades for an xA6x celica? Planning on getting a Supra rear end for the discs, but it's the fronts I'm more concerned about. Besides Greenstuff pads, any suggestions?
BlackSupra
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 12:11 Go to previous messageGo to next message
my plan is nissan Z31 26mm calipers and pug 406 discs and some machining.
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 12:31 Go to previous messageGo to next message
R33 etc. 297mm rotors + calipers. Get the rotors redrilled, or buy them new and undrilled. Mod the hubs as follows:
Longer studs: Magna
Extend the centre so the wheel has something to centre on
Machine the OD of the hub down
MX83 master cylinder
If you know someone with a lathe, this is a damned cheap upgrade, and works well too. If not, PM me Evil or Very Mad
Stefan
Hobart, Tas
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 12:54 Go to previous messageGo to next message
I may have to PM you sometime.... Wink
What about the caliper bracket? Or no need in this case? Any idea on estimated cost for your list?
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 12:58 Go to previous messageGo to next message
Depends really what you can get the calipers+rotors for, which really depends on the mood of your local importer-dude
ed_ma61
Lost in the K hole
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:08 Go to previous messageGo to next message
80 series landcruiser studs are just a little bit longer again than the magnas. a good alternative if you need them
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:17 Go to previous messageGo to next message
I just use Magna ones because they're easy to get and dead cheap Evil or Very Mad
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:30 Go to previous messageGo to next message
what year magna?
I'm prolly gonna need some longer studs, whatever route to rims and brakes I end up taking (whichever it is, I'm sure it'll involve lots of dicking around, and much swearing)
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:32 Go to previous messageGo to next message
TM-TS, basically go to your nearest self serve wrecker and knock the studs out of any box Magna you see
Stefan
Hobart, Tas
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:39 Go to previous messageGo to next message
Or buy them from Repco or somwhere like that. Can't remembr how much they are each, but it isn't that much for new ones.
Stefan
Hobart, Tas
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:41 Go to previous messageGo to next message
BTW what size rims do you need for lathed-sown R33 rotors?
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 13:42 Go to previous messageGo to next message
But hey, when you take a bucket of them for $0, you don't argue Very Happy
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 14:19 Go to previous messageGo to next message
Stefan wrote on Fri, 24 September 2004 21:41
Probably 16", but you might get away with 15's depending on their construction.
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Fri, 24 September 2004 22:20 Go to previous messageGo to next message
You don't lathe down the R33 rotors at all.. Just take a little bit off the HUB so the rotor will fit over it. I've got them on the front of my KE70 with 15s, and they only just fit, and I mean JUST!
BlackSupra
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sat, 25 September 2004 08:05 Go to previous messageGo to next message
R33's have 16's from factory and its tightish
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sat, 25 September 2004 09:02 Go to previous messageGo to next message
BlackSupra wrote on Sat, 25 September 2004 16:05
All depends on the rims Smile
brett_celicacoupe
townsville NQLD
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sat, 25 September 2004 09:12 Go to previous messageGo to next message
why peugot? whats so good bout these?
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sat, 25 September 2004 09:33 Go to previous messageGo to next message
Just the size of them, they are around 280mm, yet have a total height similar to the MA61/RA65 discs.
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sat, 25 September 2004 11:22 Go to previous messageGo to next message
I mean, even BA Falcon rotors are an option, personally I used the R33 ones because they suited what I wanted to do better. However, the BA ones will come closer to letting the calipers bolt straight up, as well as giving more wheel clearance. Also, they're thinner (26mm), plus Falcon's have an enviable(?) reputation for warping front rotors. Suit yourself, really.
bbaacchhyy
Re: Best (4 stud) brake upgrade(s) for xA6x celica/Supra? Sun, 26 September 2004 01:54 Go to previous message
mrshin wrote on Sat, 25 September 2004 21:22
On a MX83 strut, the R33 Calipers bolt straight up with BA rotors, and they are 30mm thick.
See what Black Supra comes up with as well.
The landcruiser studs are 8mm longer, and $5 from Toyota, but as others have said, Magna ones for nix (if long enough) are good too.
Previous Topic:Wheel spacers...
Next Topic:Are 3sgte ECU (GT4, SW20, diff series) interchangable?
Current Time: Sun Oct 18 01:07:21 UTC 2026
Total time taken to generate the page: 0.0049660205841064 seconds
