Toymods » Tech & Conversions » Stripping a Sprinter
d-shiznit
W.A
Stripping a Sprinter Fri, 24 September 2004 12:59 Go to next message
Hey ppl,
Today i stripped my sprinter, taken everything out except not sure how to remove the dash... unscrewed almost everything in sight. Any ideas? (Planning to transplant an AE92 dash in!)
Also, in preperation for some stitch welding, I was wondering if I should try to remove the tar stuff on the floor pan... Has anyone done this?? Only way I can think of is chisel it off then get the whole thing acid dipped...
Any comments appreciated!
MYT-16V
Re: Stripping a Sprinter Fri, 24 September 2004 13:05 Go to previous messageGo to next message
there's a bolt behind the top vent on the passenger side
and a couple up high behind the glove box, but remove glove box first and it should pop off with a litttle pull, good luck
AE86slut
Baulko Hillo
Re: Stripping a Sprinter Fri, 24 September 2004 13:10 Go to previous messageGo to next message
Yep, that bolt behind the passenger vent and one way up behind the glovebox caused me headaches too......
Best way I know of to strip the tar stuff is to use a heat gun and you should be able to peel it off in huge pieces.
PM Youngy about that. He will tell you exactly what to do.
Jeremy.
Anthony Kellam
Re: Stripping a Sprinter Fri, 24 September 2004 15:44 Go to previous messageGo to next message
yes. hammer and a half inch chisel is not fun Sad
dash has one bolt behind passenger side demist vent. one screw in the middle of the glove box latch. One bolt behind clock shroud (good luck getting that off in one piece) 2 nuts toward the top of the instrument cluster cavity.
Thats about it apart from the ones that should have become obvious removing the lower finishes.
good luck Smile
[Updated on: Fri, 24 September 2004 15:45]
no_tofu_speed
Jab what?!!?!
Re: Stripping a Sprinter Fri, 24 September 2004 16:35 Go to previous messageGo to next message
Tar stuff? Is it just for sound-insulation?
Is there that much (I am dreading to look).
For sound insulation on the floor under the carpet, do they still use tar? If not what? (prolly pastic, that make everything else out of plastic sheesh)
ae95
Re: Stripping a Sprinter Fri, 24 September 2004 16:47 Go to previous messageGo to next message
if your talking about the dash as in the instrument cluster you need to pull off the dial on either side (the wiper and headlight dials) then pull off the black twisty things, then theres a white coloured nut under there which u just screw off
takai
Re: Stripping a Sprinter Fri, 24 September 2004 22:46 Go to previous messageGo to next message
Yep its tar with a backing all over the floorpan. I simply used a 1" chisel and a whole lot of time. Then used a rotary wire brush on a drill to remove the rest of it, and then liberally applied POR15 and then VHT enamel.
d-shiznit
W.A
Re: Stripping a Sprinter Sat, 25 September 2004 01:02 Go to previous messageGo to next message
HEy thanks all of you!
I'll give it a try.
AE86slut
Baulko Hillo
Re: Stripping a Sprinter Sat, 25 September 2004 01:34 Go to previous messageGo to next message
no_tofu_speed wrote on Sat, 25 September 2004 02:35
All up there is quite a lot. Someone I know stripped theirs and weighed it - 35kg's!!!
Anthony Kellam
Re: Stripping a Sprinter Sat, 25 September 2004 02:08 Go to previous messageGo to next message
Fark! were they counting the seats ?!?
takai
Re: Stripping a Sprinter Sat, 25 September 2004 03:45 Go to previous messageGo to next message
I got to 20kg of deadening alone before i gave up weighing.
Arch
Re: Stripping a Sprinter Sat, 25 September 2004 03:46 Go to previous messageGo to next message
To remove the tar you can also use dry ice, it will freeze the tar which u can then take off in large chunks.
otherwise use a heat gun and a chisel, then use a solvent to remove the residue left behind.
Satoshi
Re: Stripping a Sprinter Sat, 25 September 2004 04:12 Go to previous messageGo to next message
what tar stuff you guys talking below of the carpet? anyone got a pic?
ae95
Re: Stripping a Sprinter Sat, 25 September 2004 06:23 Go to previous messageGo to next message
you can see it if you open the boot and look under the carpet
Instigator_PsY
Melbourne Victoria
Re: Stripping a Sprinter Sat, 25 September 2004 06:53 Go to previous messageGo to next message
Took the tar out of my AE86 not long ago, used a heat gun and a chisel. The thicker tar at the front can be heated up and pealed of in large pieces, the rear tar is thinner and heats up real quick and becomes very soft and difficult to scrap up in large pieces. Small pieces of tar that was left was sanded off with a drill sanding disk. In all the tar wieghed about 20 kgs.
no_tofu_speed
Jab what?!!?!
Re: Stripping a Sprinter Sat, 25 September 2004 09:33 Go to previous messageGo to next message
dry ice??
Satoshi
Re: Stripping a Sprinter Sat, 25 September 2004 11:00 Go to previous messageGo to next message
yeh i did find some tar at the rear...but i'm curious where the F did all the tar came froM??
20kg...u wanna sell them? Laughing
d-shiznit
W.A
Re: Stripping a Sprinter Sat, 02 October 2004 04:25 Go to previous messageGo to next message
HEy!!
Okay I finished removing all the tar (got pics if anyone is interested), was wondering how to get rid of the residue, or even if it is necessary?
I'm intending to stitch weld the chassis before spraying the interior black..
takai, did you just leave the residue and prime/spray over the top?
I was thinking, the easiest way seems to be:
Find something to remove the residue,
Stitch weld without stripping paint (welding should burn paint off)
Prime
Spray
Sound good?
[Updated on: Sat, 02 October 2004 04:35]
sideeways
Re: Stripping a Sprinter Sat, 02 October 2004 07:51 Go to previous messageGo to next message
yo i would like some pics to bruiselee08@hotmail.com thanks! just pics of the tar or the interior??
i was told by a workhop that the proper way to do it. is strip everything, sandblast, then spot weld, and then spray over..mannn how much work is that?? i think that sucks man but hopefully it will work! anyone got any ideaS?
how does this dry ice thing work? ive been told to use dry ice too but no idea how its gona work..
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Stripping a Sprinter Sat, 02 October 2004 09:00 Go to previous messageGo to next message
use a wirewheel on the areas you intend to weld, make sure it is free of residue or crap!
satoshi: the tar is all throughout the car for sounddeadning, it is quiet effective at it too.
im dreading the day i do mine haha
ae95
Re: Stripping a Sprinter Sat, 02 October 2004 09:21 Go to previous messageGo to next message
im too lazy to do mine Cool
d-shiznit
W.A
Re: Stripping a Sprinter Sat, 02 October 2004 11:25 Go to previous messageGo to next message
I tried using some acetone on the residue... does an ok job on the residue, but there are a lot of small bits of tar that wont come off... wire brush doesnt do jack.
Any ideas? Besides going at every tiny bit with a chisel....
Anybody?
no_tofu_speed
Jab what?!!?!
Re: Stripping a Sprinter Sat, 02 October 2004 12:01 Go to previous messageGo to next message
oxy-torch?
hahahaha
Dodgy_Haro
Re: Stripping a Sprinter Sat, 02 October 2004 14:35 Go to previous messageGo to next message
AE86slut wrote on Fri, 24 September 2004 23:10
That's about the most common way ppl remove it.
However, the other alternative I've seen is to use dry ice ...
http://www.driftday.com/R4_2.jpg
http://www.driftday.com/R4_1.jpg
http://www.driftday.com/R4_3.jpg
The Club4AG link on the build up of Taka's car is a good reference point (picture wise anyway) about stripping a car and building it up ... pretty much what I'll be doing to my 2nd AE86 soon ...
http://www.driftday.com/taka_rebuild.htm
mr2drift
Re: Stripping a Sprinter Sun, 03 October 2004 02:03 Go to previous messageGo to next message
i did mine not to long after getting the car, used a heatgun and paint scrapper, then got all the residue off using kerosene on a rag and in the more difficult spots kero and a brush, came up like new....
However, the tar on the fire wall takes absoloutley ages and you MUST have EVERYTHING removed from under the dash, so not sure how many of you will go to that extreme.
ae86drift
sydney.au
Re: Stripping a Sprinter Sun, 03 October 2004 07:59 Go to previous messageGo to next message
mine was done in japan for me
Very Happy
heh
Re: Stripping a Sprinter Sun, 03 October 2004 12:45 Go to previous messageGo to next message
A suggestion: using those little wire wheels you get at Bunnings on a drill is useless - angle grinder with a bigger (and more expensive!) wire wheel is far more effective..
chubbylover53
Re: Stripping a Sprinter Mon, 18 October 2004 07:36 Go to previous messageGo to next message
this may sound stupid but is the floor held together by any of this tar stuff. i don't want my car to fall apart. \Alos wat is the advantage of seem welding
jacek
Perth, WA
Re: Stripping a Sprinter Mon, 18 October 2004 13:30 Go to previous message
Nope none of the tar holds anything together, but you will reveal some holes in your body.
And as far as i know, seam welding is a way of strengthening the body and making it more rigid.
Previous Topic:Little Help Please...Differences...JZA-70 or MA70
Next Topic:rust removal
Current Time: Fri Nov 20 09:43:26 UTC 2026
Total time taken to generate the page: 0.0094389915466309 seconds
