Toymods » Tech & Conversions » which low pressure pump?
Sam_Q
S.E suberbs, Vic
which low pressure pump? Fri, 24 September 2004 23:29 Go to next message
I am setting up a surge tank for my Sprinter and I have a VL pump to go from my surge tank to the engine, I am looking for a low pressure scavaging pump. I have seen ones for sale that have either an obscene amount of flow like 500hp pumps or ones that doent have enough. Does anyone know of a good pump thats available cheaply or though a wrecker? I prefer it to be rated above the VL one which apparently is 2.3L/ minute under pressure. Also I really dont want to run dual pumps, I want to avoid too much complexity under my car, as anyone who has worked on an 86 will know there isnt much room under there. But if I have to I will.
Any advice would be appreciated
takai
Re: which low pressure pump? Fri, 24 September 2004 23:44 Go to previous messageGo to next message
Im using the Pierburg lift pump, does 3psi and 2.5L/min.
Pretty good pump.
Sam_Q
S.E suberbs, Vic
Re: which low pressure pump? Sat, 25 September 2004 00:00 Go to previous messageGo to next message
where did you get it from Chris?
takai
Re: which low pressure pump? Sat, 25 September 2004 03:46 Go to previous messageGo to next message
Toby Hunt @ Meridian
Re: which low pressure pump? Sat, 25 September 2004 05:08 Go to previous messageGo to next message
if the VL one can suck enough, use another one for the lift pump Wink
with no presssure restriction, it will DEFINITELY flow more than the one filling your fuel rail, and then you won't have any concerns about relative flow.
Sam_Q
S.E suberbs, Vic
Re: which low pressure pump? Sat, 25 September 2004 07:36 Go to previous message
thats a good point I guess theres no reason why I would need to use a high pressure pump.
Atleast they wouldnt be mismatched!
Previous Topic:KE20 front brake/strut upgrade?
Next Topic:realistic 1g power
Current Time: Sun Oct 18 02:53:02 UTC 2026
Total time taken to generate the page: 0.0054619312286377 seconds
