Toymods » Tech & Conversions » Bang 4 Buck mods for '90 Seca SX
cjeff
Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 07:32 Go to next message
Hi guys, I have a budget of around $1000 to do some mods to my 100KW 4AGE. I currently have 1990 Toyota Corolla Seca SX. I am basically wanting the best bang for my buck. I have just found this website yesterday and found it extremely helpful, but I haven't found anything cement for what I'm looking for.
I am looking at any of the following options, and some combinations:
* Cold Air induction/Filter/rampod
* plug in chip - powerchip/chiptorque...
* aftermarket ECU - autronic/Wolf/Microtech/motec, etc...
* 4AGE 20V motor conversion
* 20v throttle body?
I haven't put an exhaust in there yet, as I don't necessarily think it will be a cost effective mod stand alone, but am open to input.
Thanks guys
tanman
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 08:42 Go to previous messageGo to next message
I used to own a Seca Sx I put a set of genie extractors and and a 2inch exhaust on it. The exhaust made a noticeable difference. I also fiited a K&N filter to the standard airbox and fabricated a pipe form the stock air pick up to the slot on the front bar. I wouldn't bother with a 20Valve conversion, I have driven 20v cars and they dont go much better. For the same money you could do a 4AGZE conversion.
[Updated on: Wed, 25 September 2002 08:47]
tercelboy
Townsville, Queensland
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 09:36 Go to previous messageGo to next message
is a AE92 to 4AGZE conversion possbile is it, I have a post about it but know one has said a word about it.
tanman
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 09:43 Go to previous messageGo to next message
most 4AGZE engines and front cuts are from AE92 derivatives. Just buy a front cut and swap everthing over. It is a bolt in fit.
[Updated on: Wed, 25 September 2002 09:46]
bayka
perth
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 16:40 Go to previous messageGo to next message
no shit, finally someone with the same fucking car as me
is the 1990 corolla seca SX an ae-93 ???
All i know is i have one too, how much were u quoted for a chip??
Grega
melbourne.victoria.austra...
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 20:14 Go to previous messageGo to next message
um, you'll need a little more than $1k for a ZE, quad t/b or ECU conversions.
try the usual route, exhaust, intake. get it breathing right.
if thats not good enough try some longer duration cams with a little bit more lift?
kingmick
Banned by his request
moved to tamworth
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 22:22 Go to previous messageGo to next message
i have a ae93 shopping cart aswell. best thing to do as you wont really get much power from $1000 is to drop the car by 2inch with good springs and shocks and get a set of offset caster bushes from whiteline. then have it aligned{ask me when you are having this done and ill tell you the settings}and throw a set of bendix metal king pads in the front. then no one will beat you through the bendys. then next stage change rear swaybar to a whiteline ajustable one and add 15 or 16 in rims with 205/50{15} or 45{16} series tyres, its bumpy on bad roads but great on moderately smooth roads.
mick
[Updated on: Wed, 25 September 2002 22:26]
cjeff
Re: Bang 4 Buck mods for '90 Seca SX Wed, 25 September 2002 23:32 Go to previous messageGo to next message
Powerchip quote $890 for their plug in chip. It gives 8KW with use of PULP and 11KW with use of 98ron only (they are 2 separate chips though). They say they modify the standard program to suit if you have cold air induction and/or exhaust.
BTW when I said budget of around $1000, I was being fairly conservative. I could quite easily spend up to $1500, the problem is, the moment you say $1500, you end up spending $2000 and so on, I'm sure a lot of you can relate to this... Wink
The other thing is, I don't really want any more power than 120KW (at the flywheel). So maybe I should be asking, how much would I have to spend to get this much power, and what would be the best way to do it?
Julz
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 03:16 Go to previous messageGo to next message
Yep, they are AE93. I can confirm that coz it says so on my SX Seca Wink
Tanman, what configuration were your extractors? 4-2-1 (??) and in what range did they make the most improvements?
seeks
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 03:22 Go to previous messageGo to next message
Gday,
I dumped a 20 valve 4age into my ae92 sx seca. Very impressed and very happy.
ECU/GEARBOX/ENGINE for $1600.
WIRING help - $300.
Catcha,
Seeks.
cjeff
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 03:46 Go to previous messageGo to next message
Seeks, do you need a different gearbox for the 20V? did you sell off your 16V? if so how much?
How long did the conversion take?
Have you had your car dynoed? I'm wanting to hit somewhere between 110KW and 120KW at the flywheel.
Thanks - Craig
troyboy
Colyton, NSW
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 04:11 Go to previous messageGo to next message
OK OK OK
its edited....
appologies to those who were offended...
read below reply to see what i wrote if u wanna...
IMO
if ur driving on normal roads.. runs off lights etc go GZE
if ur on a track.. 20V
but lets face it.. how often are u on the track.
put the money on lowering and exhaust...
when ur ready then get engine...
yes i have a ae93 seca gze and its white Razz
[Updated on: Thu, 26 September 2002 09:06]
troyboy
Colyton, NSW
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 04:12 Go to previous messageGo to next message
ps
why the hell wouldnt u want more that 120k at the fly????
cjeff
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 07:34 Go to previous messageGo to next message
I would like more than 120KW, I just don't want more than 120 going through a FWD corolla. I'd rather just buy another Liberty RS (which I don't want to do just now) - now that baby could move Evil or Very Mad
BTW, nice pics troyboy - mine is white too...
seeks, could email me, would like to talk about your 20V conversion - still haven't written this off, but is looking a less likely option by the day...
troyboy
Colyton, NSW
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 07:57 Go to previous messageGo to next message
yeah i guess if its only spining 1 wheel..
i guess that would suck big time..
i dont have that problem as i have a LSD gearbox .. hahaha
id love to know what i have at the fly...
i got 90 at front wheels... 1 day after front mount was installed.. i wonder now that the car is adjust itself (if it does) what id get at the wheels...
seeks
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 08:39 Go to previous messageGo to next message
Gday all,
"please dont waste ur money on a 20V
they will always be in my exhaust fumes.. (riiiiiiiiiiiight)
save ur money... if ur driving in traffic.. gze...
if ur on a track.. apparently the 20V
lets face it.. how often are u on the track."
Troyboy you crack me up, i knew as soon as i wrote '20v' some nay sayer would kick in. Gotta love this type of comment. Man I love revving the piss out of my smooth engine, it's great, i've been in a 4agze and wouldn't dream of getting one instead of the 20v.. I'm 'on the track' as soon as I hit the road, and in the 20v, I feel like i'm on the track too. Why the hell would you want a gze in traffic, to use more fuel ? pay more insurance ? accelerate faster to 15km/hr before having to slow down behind the person in front ? choice!
If you're in traffic, go replace your engine with a 4ac Smile.
Troyboy, drive your 4agze and enjoy it for what it is, I reckon it would be fun too! Personally i like 4agze's too, but don't try to convince people a 20 valve is a waste of money, because you're wrong.
Cjeff, if you like the idea of having a 20v in your engine bay and being able to happily flog it to 8000rpm while listening to the quad throttle bodies sucking it back, go get a 20v and be happy that you have one of the smoothest fastest 1.6litre normally aspirated engines ever released in stock trim.. I did months ago, and i'm still happy. Smile If you want forced induction, go get a gze. (or do it properly and get a 20v turbo)
Catchas!
Seeks.
seeks
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 08:50 Go to previous messageGo to next message
Gday cjeff in reply to your questions,
Thanks - Craig
I used the 20v gearbox. I'm not sure if the 16v gearbox and the 20v gearbox are interchangable without any modification.
Putting the actual engine in only took a couple of days, wiring slowed me up, it took a month, but i was doing it on a student budget and had to do a chunk of the wiring myself while juggling exams etc. I had a big thread going on here the whole time i did it, everyone was very helpful, i'll try to find a link to the thread if you're interested.
I havn't had it dynoed, i'd say it is probably about 105 at the flywheel. Thats with factory airbox, standard small exhaust etc. If u got exhaust and better induction it would make a fair difference, the standard 20v extractors are meant to be quite good already. Use good fuel, it makes a noticeable difference too.
Thanks,
Seeks.
inertia
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 09:30 Go to previous messageGo to next message
Well Seeks,
I may go the 20v into my AZ92. It currently has a 4A-FC with a shitter 3spd Auto. After this Auto was installed I cannot rev high in first gear without one hell of a gear change Rolling Eyes
I am hanging out for revs, and the ability to SHIFT the gears myself.
What modifications did you need to do to get the 20v engine into your engine bay? Which mounts did you use, radiator? (I've heard the 4AFC radiator is perfect for 20v.
The wiring is what worries me, as the car is currently carby... I am picking up the complete wiring system book for my car next week from Holden so that should help.
Is there any torque steer with the 20v?
Finally, did you solve your starter motor probs?
Johnny
Sydney, OZ
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 09:36 Go to previous messageGo to next message
All 'A' series gearboxes are interchangeable, that's why they're call 'A' series. For High Torque, force induction, use the ZE, but are absoultely crap for N/A use. For nice close ratio's the 20V boxes are are the best. The standard boxes found here will cope behind a ZE, and handle a 20V no worries, but no LSD...
inertia
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 10:03 Go to previous messageGo to next message
Further to my previous questions.
Do you guys with 20v's have the aircon attached and working?
Johnny
Sydney, OZ
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 10:09 Go to previous messageGo to next message
I gave the Air con the flick, the engine was intended for racing. If you get a whole front cut, everything is there, it's just a matter of transferring and hooking it up, otherwise a bit of thought, you could use the factory fitted stuff the car came with.
seeks
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 10:22 Go to previous messageGo to next message
Gday inertia,
"I am hanging out for revs, and the ability to SHIFT the gears myself." - hehehe, if it's revving you want 20v is the go! Smile
"What modifications did you need to do to get the 20v engine into your engine bay? Which mounts did you use, radiator? (I've heard the 4AFC radiator is perfect for 20v. " -
I believe that the 4ac radiator is the way to go as my 4age radiator actually needed some very awkward piping. The engine just fits, I didn't need any mods. I don't know what your fuel system in your car is like, but i do remember people having to change the fuel pump workings when moving from carby to injected. The SX ae92 fuel pump is actually built into the tank, it doesn't sit in the engine bay, you might wanna check out your fuel pump and stuff before going further.
"The wiring is what worries me, as the car is currently carby... I am picking up the complete wiring system book for my car next week from Holden so that should help." -
The wiring also worried me, Grant from sixworks helped me by doing some of it, unfortunately i had gone ahead already and chopped/butchered some of the harness so i was on my own for a little while too. All in all, if you have the books, the right ecu/plugs and the wires, it's all just a matter of sitting down and planning things out. Oh, also a soldering iron and a multimeter can help at times too Smile, and a spare car to drive around and... hehehe
"Is there any torque steer with the 20v?" -
yup, it's not that bad though, just hold the steering wheel tight. I've had people drive my car and been really turned off by the torque steer, but i hardly even notice it.
"Finally, did you solve your starter motor probs? " -
Yup, in my engine conversion i lost the battery brace so what happened was the make shift brace i used came undone. The battery slipped, pulled out an earth wire. Then a much smaller earth burnt through and snapped due to having too bigger job for such a small wire. All i had to do was re-wire up some better earths and get a stronger/better fitting battery brace so the damn thing didn't move again Smile.
Have fun!
Seeks.
inertia
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 10:29 Go to previous messageGo to next message
Got any video's or sounds of these things screaming to 100+??? Km/h Very Happy
Cheers for the replies gentlemen.
CrAiGzEE
south of the big smoke
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 10:52 Go to previous messageGo to next message
ok hears my opinion
Ive driven a fairly modifed 20v,my mate works for haltec so he has access to all there gizmos etc.. i gave it a little of a hammering. It was amazing how smooth and rev friendly it is, but at the end of the day it didnt feel that fast!
On the city cruise troy took me for a ride in his car. it hammers! the pulling power of it is great, at the time his car wasnt running that well also! you could feel the power much more than the 20v
the title of this thread is "bang for ya buck" if ya want bang for ya buck definetly go with the 4AGZE,
Lets say you get a 20v, what about 6 months down the track when ya want more power. The 20v can be expensive to get a noticable power increase out of.
With the 4agze u can get a second hand pulley set from an importer for around $250 which will rise ya boast from 6-8 pound to around 12-14. If you feel you need even more power there also the otion of turboing it! (90% sure the 4agze has much stronger internals than the 20v)
also the extra torque comes in handy when ya got a car load of mates,
lastly the 20v was in a ae82 and troys is a ae92
the 82 is a couple hundred kilos lighter which gives it a head start but still slower than gze
Conclusion
my money would go on the ze! sfter all you dont spend $2000- $3000 on getting a smooth engine
I would want a noticable power increase!!
[Updated on: Thu, 26 September 2002 10:53]
inertia
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 11:03 Go to previous messageGo to next message
Well if a 20v isn't a big power increase over my poor example of a 4AFC 3sp Auto I'll run around the block clucking like a chook Laughing
Considering I am 20 years old, insurance is not favourable.
Anyhoo, the real question will come when this current Auto packs it in Mad
[Updated on: Thu, 26 September 2002 11:05]
CrAiGzEE
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 11:14 Go to previous messageGo to next message
hey man ive got a fc 2 atm, 5 speed but!
they aint no power train by any means!
im gunna get hassled for this but i dont wreckon its heaps more powerful
you cant tell its twice the kw at all!
but yeh if the 20v is what ya want by all means do it man dont let me stop ya
troyboy
Colyton, NSW
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 11:36 Go to previous messageGo to next message
craig...
i like ur avatar!
u know what.. ask Daniel (djb23_20v)...
he had a 20V in a seca ae82
now he has a GZE in a seca ae93
ask him.. i guess hed be the best person to ask as he has had both and done both conversions...
CrAiGzEE
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 11:43 Go to previous messageGo to next message
thanks man
like your to troy
what happened to it?
djb23_20v
Wollongong
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 12:58 Go to previous messageGo to next message
Guys,
I put a 20v in my (lighter) ae82, and shes really got along nicely. 20 is really smooth and revs out cleanly to redline, lots of fun to drive. But, to really get anywhere you had to rev it to bits all the time, which really isn't good for it (even though its Toyota-Tonka-Tough).
I just finished a 4AGZE into AE92, and it walks all over 20v, even with the extra 100kg of car for the newer model. GZE has so much torque from idle, unlike 20v which really needs to wind up to 4500rpm before things start to happen. GZE doesn't need to be wrung to redline either, you can just massage the throttle to shoot along in traffic. And GZE is heaps easy to boost up with a pulley kit, better intercooler and free flow exhaust.
Conversion wise the wiring and the labour is roughly the same amount of work. I ran the standard g/box with my 20v (but that died a horrible death after a driveshaft shop didn't tighten up the driveshaft flange and the driveshaft work loose and ate the g/box casing just after handing in my final year mech engineering thesis). With the gze I've fitted the GZE g/box, driveshafts, struts etc.
So thats it, I vote GZE.
kingmick
moved to tamworth
Re: Bang 4 Buck mods for '90 Seca SX Thu, 26 September 2002 13:34 Go to previous messageGo to next message
thought you had 1000-1500 to spend. 20v or gze? if there is someone out there that has done either for 1500 raise your hand. you might get the engine,gearbox,computer and loom for 1500
but it cost alot more than that to change as you have things like new clutch{always change it if the engines out of the car and its half worn, i just change it to save the time later}. next is timing belt{you can try you luck with the other belts but i change all of these}, then a waterpump change is also a good idea . there other parts i change but you get the idea.
but for the money you want to spend, go exhast system{from tip to tail}. as to chipping is a waste of time on a toyota ecu and ive yet to see or hear of one. a full aftermarket ecu will cost you atleast 1500 plus as it has to be tuned and if not a plug-in
unit, wired. and an aftermarket wont give you much if you dont change exhaust and cams. cold air intake is cheap and easy to do so its a given , so exhaust is my two cents worth.
mick
[Updated on: Thu, 26 September 2002 13:57]
inertia
Re: Bang 4 Buck mods for '90 Seca SX Fri, 27 September 2002 07:07 Go to previous messageGo to next message
Oz_Craig,
I believe you are right when you say it doesn't feel like twice the Kw. Prolly because it doesn't have twice the Nm as the 4AFC.
The ole 4AFC has 90HP@5500 and 135Nm@3600 from memory. The AE92 GZE has in excess of 200Nm and this is what we feel pushing us back into the seat.
I have yet to be in a 20valve, but Fassil was nice enough to take me for a spin 'round the block in his GZE and it was awesome!
Anyone in Melb got a 20v AE92?
Oh, and where are the 20v video's?
cjeff
Re: Bang 4 Buck mods for '90 Seca SX Sat, 28 September 2002 08:18 Go to previous messageGo to next message
Well guys, I've decided against the engine conversion for my bang for bucks. This is what I've come with so far...
I'm going for the exhaust and the Cold air. But this what I have questions about...
My friend has a stuffed 20V lying around with the original extractors and the quad throttle body. Are the 20V extractors any better than the 16V's extractors? If I custom fit a quad throttle body to the 16V, what will need to be done to tune it properly? More importantly how much benefit, and how much to get it sorted?
If I fit my mate's extractors, I can get cold air and 2" exhaust for $700. Powerchip sell their chip for $890 - has anyone had one - did it make any difference?
vitor
Re: Bang 4 Buck mods for '90 Seca SX Thu, 19 February 2004 11:01 Go to previous messageGo to next message
hey guys, im getting a 100kw worked at the moment, nothing serious... a head job Shocked and 20 thou over pistons, balanced, and lightened flywheel, havent put it together yet, cant wait, its going into a ae82 seca but i tell you what, the old 86 kw sometimes surprises me.....its stock with hurricane 2" extractors 4/2/1, 2 1/4 stainless exhaust and uni filter, shes getting a little tired but still a little rocket, also ive been trying to find quad throttle bodies for the 100kw, no luck other than new at $1500..rightttttt
hotrolla
Re: Bang 4 Buck mods for '90 Seca SX Thu, 19 February 2004 11:36 Go to previous message
Just remember you will be paying a couple of thousands extra on insurance with a gze compared to a 20 valve.
Previous Topic:5-speed for KE-55 2-door 1980 corolla
Next Topic:poop
Current Time: Sun Oct 25 08:05:01 UTC 2026
Total time taken to generate the page: 0.12026000022888 seconds
