Toymods » Tech & Conversions » ra40 --> 83' cressida discs + struts, also xmember for 1g convertion......worth the effort?
brett_celicacoupe
townsville NQLD
ra40 --> 83' cressida discs + struts, also xmember for 1g convertion......worth the effort? Sat, 25 September 2004 07:23 Go to next message
i was wonderin if this would be a worthwhile conversion. how much would it improve my braking power??. i can get the whole strut legs for free with everything. have read the article in the tech notes thing. is this gunna mix up the handling?
tell me what u think . most of the stuff ive got of the cressida so far has fitted; power steering, power windows, power locking(some with minor mods)
will go and measure it up now
crossmembers look very compatible too, maybe this would be in some interest if i was to put a 1g in later on down the track. the cressida crossmember goes to the back ie. for a front sump. it looks like the back of the xmember would go very close to the steering linkages.
thanx
brett
[Updated on: Sun, 26 September 2004 10:29]
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 07:50 Go to previous messageGo to next message
the % increase in diameter (maybe measure from pad centres) will be your increase in braking power (leverage to the wheel). a change in caliper piston will alter the feel of the brakes. bigger discs/pads will delay heat problems a bit...
7M-Brisbane
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 08:22 Go to previous messageGo to next message
IIRC the brakes are actually smaller...
brett_celicacoupe
townsville NQLD
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 08:35 Go to previous messageGo to next message
i went out and measured the cressida strut and the disc diametre is about 250....hard to get an accurate measure ment with a tape measdure. i will measure the ra40 one tomorow and compare.
also, one would assume the cressieeda being heavier than the celica, it would need better brakes. thats only an assumption thou
brett
also, what the fark does IIRC mean???
[Updated on: Sat, 25 September 2004 08:37]
7M-Brisbane
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 08:57 Go to previous messageGo to next message
Definitely worth, it you should investigate if these brakes are bigger before you consider the upgrade Wink
Wilbo666 is the man to ask.
IIRC = If I ReCall
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 09:10 Go to previous messageGo to next message
Actually, its "If I Recall Correctly" Smile
Gazza53
Hey Brett, how much work to fit the cressida power steering unit to the RA40???
Any pics???
brett_celicacoupe
townsville NQLD
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 09:18 Go to previous messageGo to next message
Gazza53 wrote on Sat, 25 September 2004 19:10
Any pics???
yeah there was a topic a while ago. i drew a diagram on autCAD too. easy conversion, works graet too Very Happy
http://forums.toymods.org.au/index.php?t=msg&g oto=381106&rid=4696&S=d3a8f66b8ede1f584e08 0d233b66a8a1
if u have any ques. see me on messemger
gr8r-x
Vic, AU
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sat, 25 September 2004 12:54 Go to previous messageGo to next message
For all your brake measurements, see www.dba.com.au.
RA40 - solid 254mm diameter
MX62 - vented 248mm diameter
Would help with cooling, but your losing out in diameter... There are better option out there I'd imagine.
brett_celicacoupe
townsville NQLD
Re: ra40 --> 83' cressida discs + struts.....worth the effort? Sun, 26 September 2004 01:24 Go to previous messageGo to next message
smaller eh, thats a bit of a bummer. i could have got it all for free too but i guess i aint worth the effort.
does a 1g bolt into a mx62 cressida (disregarding the g/box)??
maybe something to think about... Rolling Eyes
thanx
brett
brett_celicacoupe
townsville NQLD
Re: ra40 --> 83' cressida discs + struts, also xmember for 1g convertion......worth the effort? Sun, 26 September 2004 10:32 Go to previous message
bump
Previous Topic:3SGTE and 5MGE knock sensors same?
Next Topic:sc12 rattle/clunking noises, 4agze
Current Time: Fri Oct 23 01:06:02 UTC 2026
Total time taken to generate the page: 0.0065929889678955 seconds
