Toymods » Tech & Conversions » original phillips tape deck
Bradelz
Tamworth
original phillips tape deck Sun, 26 September 2004 09:35 Go to next message
hey all,
my phillips tape deck is playing up, you put a tape in it and it just keeps changing sides without actually playing. when you hold the "tone" button it stops but tape still doesnt play. the little round things dont even spin. is it a rubber band?
brad
brett_celicacoupe
townsville NQLD
Re: original phillips tape deck Sun, 26 September 2004 10:05 Go to previous messageGo to next message
i think they have a load sensor ie. when the tape gets to the end, the load is high so it changes sides.
maybe a rubber band. maybe the button. one of the buttons allows u change side its called 'program' maybe its stuck on
good luck, although ude be better off to get a deecent cd headdeck
brett
river
Land of Oz
Re: original phillips tape deck Sun, 26 September 2004 10:18 Go to previous messageGo to next message
Clean your capstans (the thin metal spindles) and the rubber drive wheel. Use metho and, if you haven't cleaned it before, you'll need a few cotton buds to get all the shit off.
Also, clean the heads while you're at it - but use clean cotton buds for that - also with metho on them. Wait a few mins after you clean before you put a tape in, to let the metho evapourate.
I'm assuming that you've tried a few different cassettes and it does the same to all of them?
The tension sensor can be one of a few types, depending upon the deck. It could be detected by load - that is, the motor amps (milliamps) rises to signify the tape is at the end and the motor is stalling - or, it can be a sensor that detects the rollers have stopped - or, it can be a little tab thing that pushes in the tape and when the tape is under tension it pushes the tab out.
I'd hazard a guess it's the last one - especially if it's an older deck. Check to see if there's a small tab in there and see if it's bent, which can happen if the tape is pushed into the deck hard and fast.
Naturally, this ain't easy to do with the deck in-situ and a tape being put in 'cos your view gets severely blocked. Worse case, pull it out, remove the lid and have a gander. Better still, invest in a new deck. It's a good excuse to get a CD unit. Smile
seeyuzz
river
Bradelz
Tamworth
Re: original phillips tape deck Thu, 30 September 2004 10:59 Go to previous message
hey river thanks for that ill print it out and show my dad he might be able to help me, also heres a pic.
http://img.photobucket.com/albums/v293/Trentelz/radio.jpg
brad
Previous Topic:turn oil drain in sump...what size
Next Topic:Cluth Pedal Rubber
Current Time: Fri Oct 30 17:32:00 UTC 2026
Total time taken to generate the page: 0.0050270557403564 seconds
