Toymods » Tech & Conversions » backfire when letting off throttle
Moonbreaker
backfire when letting off throttle Sun, 26 September 2004 10:32 Go to next message
the engines a 13t with twin 40 sidedraft mikuni's, jetted at 140 main and 200 air. the backfiring occurs when i let off the gas and can't figure out what's wrong. leaning out the idle screws a little lessens the occurence but does not completely remove it? any ideas? timings at 15 deg btdc, and the vacuum advances are plugged up
AE86slut
Baulko Hillo
Re: backfire when letting off throttle Sun, 26 September 2004 10:40 Go to previous messageGo to next message
I'm just throwing up an idea here and perhaps someone can answer this, but could a large buildup of carbon on the valves cause something like this? I mean, it would get very hot and could ignite the fule couldn't it?
Feel free to completely shoot me down in flames if this is ridiculous..... Razz
river
Land of Oz
Re: backfire when letting off throttle Sun, 26 September 2004 10:48 Go to previous messageGo to next message
There was some discussion about this on another forum a few weeks ago. I think it the car was running very rich or something like that. Can't remeber now.
However, since my engine has been tuned and all fixed up, it gurgles when decellerating - moreso, if you're using the engine as a brake. I love it. It used to do that years ago, then faded away as the carbies leaked and were badly in need of overhaul - but the gurgle is back! Smile
AE86slut wrote on Sun, 26 September 2004 20:40
Hmmm.. I'd just like to shoot you down for the hell of it, but can't think of any devastingly witty repartee, so I guess I'll let you go this time. Laughing
seeyuzz
river (with the gurgling 18RG)
AE86slut
Baulko Hillo
Re: backfire when letting off throttle Sun, 26 September 2004 10:59 Go to previous messageGo to next message
Your mercy has been noted River.....
I guess I don't mean it as a reason for the above problem, but is it possible?
As for the actual problem, running very rich would prolly rate pretty highly on the list of causes.
river
Land of Oz
Re: backfire when letting off throttle Sun, 26 September 2004 11:06 Go to previous messageGo to next message
Well a full-on backfire is unburnt fuel being ignited in the exhasut system, isn't it? So the two things you need for this is unburnt fuel and some form of ignitor.
Running rich would give you the unburnt fuel. Bits of hot coke/carbon deposits and other shit from the engine could supply the ignition. But, if that's the case, wouldn't a nice damn hard drive clean out some of the deposits? Then a tune-up on the carbs help with unburnt fuel?
I'm not sure, but I wonder if poor timing could also be a factor?
seeyuzz
river
greenta22
Dandenong Ranges, VIC
Re: backfire when letting off throttle Sun, 26 September 2004 11:31 Go to previous messageGo to next message
cant you get fuel additives that clean all the shit off the back of your valves? like some of the Nulon or Wynns stuff? never tryed it myself but its gotta be worth a shot for like $5 a bottle...
Gazza53
Re: backfire when letting off throttle Sun, 26 September 2004 11:43 Go to previous message
The old STP additive is the way to go,
Idle the engine until warm, remove spark plugs, pour about 25ml stp into each cylinder and let sit for twenty minutes,
spark plugs back in, fire up, lots and lots and lots of white smoke, slowly trickle more stp down carb, very hard to keep enging running while u are doing this but persist.
When youve got half a bottle of stp left, pour it into fuel tank.
Keep idling until smoke clears, change oil and spark plugs.
Should be like new!!
They used to give this stuff away at the pump in the 60's
[Updated on: Sun, 26 September 2004 12:21]
Previous Topic:DLI KIT for 4age 20V
Next Topic:RA65 Brakes
Current Time: Thu Oct 22 07:57:34 UTC 2026
Total time taken to generate the page: 0.0040521621704102 seconds
