Toymods » Tech & Conversions » TPS, microtech, 18r-geu problem
beterthenu
Dubbo NSW
TPS, microtech, 18r-geu problem Sun, 26 September 2004 13:43 Go to next message
hey,
i have a problem. i have an RA23 celica with an 18r-geu engine. i am using a Microtech MT4 ecu, with no throtle position sensor. my mechanic tells me that he can not find a tps which will both fit the intake and correctly interface with the ecu. he says that te car will just stall when hooked up to a tps. he then rang microtech and they suggested a ford tps, which he could not get to fit.
this is the point in which my mechanic gave up, but not without charging me mind you.
any ideas on how i can fix my problem?
thanks.
Re: TPS, microtech, 18r-geu problem Sun, 26 September 2004 13:45 Go to previous messageGo to next message
late model 22r-e.
Re: TPS, microtech, 18r-geu problem Sun, 26 September 2004 14:09 Go to previous messageGo to next message
22RE is definitely variable voltage type. and 60mm TB too Smile
Re: TPS, microtech, 18r-geu problem Sun, 26 September 2004 14:10 Go to previous messageGo to next message
only the later ones though. The earlier ones are the switch type like the 18rge
10sec_rx7
Syndey
Re: TPS, microtech, 18r-geu problem Sun, 26 September 2004 23:54 Go to previous messageGo to next message
switch type TPS will work with the MT4, you just have to wire them differently,
people100
Rocklea qld
Re: TPS, microtech, 18r-geu problem Mon, 27 September 2004 11:16 Go to previous message
vl tps works...just need about 4mm spacers under the 2 screws to raise it to the right height or else the tps jams up becuase vl's have a different length shaft going into it.
Previous Topic:any recommended parts source in SYDNEY...?
Next Topic:Bluewire News
Current Time: Wed Oct 21 02:57:19 UTC 2026
Total time taken to generate the page: 0.0057101249694824 seconds
