Toymods » Tech & Conversions » cressy swaybar upgrade
biggav
cressy swaybar upgrade Wed, 25 September 2002 10:44 Go to next message
when i had the mx83 beast on the hoist the other day i noticed toyota had bent a coathanger the shape of a swaybar and mounted it to the rear of my car Very Happy what a joke Rolling Eyes main question is, if anyone has upgraded theirs, did you use the standard plastic swaybar link or have you upgraded to a custom metal one?
thanks Smile
stevevp
Brisbane Qld
Re: cressy swaybar upgrade Wed, 25 September 2002 13:05 Go to previous messageGo to next message
This is one case where size doesn't really matter.
The bent coathanger works very well, I have never heard of it needing replacement.
If you want to stiffen things up just replace the rubber bush with neoprene. Remember it's IRS and doesn't need much in the way of roll stiffness from a sway bar.
frebbles
Re: cressy swaybar upgrade Thu, 26 September 2002 10:08 Go to previous messageGo to next message
Hey stevep...I noticed you have done the wheels up, did you stiffen suspension??? How is your baby cornering now? Is the handling a lot better?
rob_RA40
c'town, NSW
Re: cressy swaybar upgrade Thu, 26 September 2002 10:12 Go to previous messageGo to next message
read the thread on swaybars, be careful not to go overboard with the thickness of rear one..
http://www.toymods.org.au/msgboard/index.php?t=msg &th=4600&start=0&rid=19&S=4d9de6c1 353ddaa2245e238db9aac92c
stevevp
Brisbane Qld
Re: cressy swaybar upgrade Thu, 26 September 2002 11:24 Go to previous messageGo to next message
Frebbles,
Pedders lowered springs and bilsteins, made it handle flatter although handled pretty good as standard.
The main thing I was after was highway stability, the front still feels a little loose, I need to play with the alignment settings a bit more.
biggav
Re: cressy swaybar upgrade Thu, 26 September 2002 11:29 Go to previous messageGo to next message
yeah, i know about the risks of gong too big, but it just looks soooo small Smile i suppose i'm used to my old car (and it's handling)
how much for the bilsteins steve? (if you don't mind me asking)
apparently if you want a cheap alternative for short strut rears you can use ae92 inserts and space the bottoms...
stevevp
Brisbane Qld
Re: cressy swaybar upgrade Thu, 26 September 2002 11:33 Go to previous message
from memory about $300 per shocky, although it was a while back.
Previous Topic:1JZ to W5x gearbox? can it be done?
Next Topic:AE92 Conversion page I found...
Current Time: Fri Oct 30 07:52:45 UTC 2026
Total time taken to generate the page: 0.0057568550109863 seconds
