Toymods » Tech & Conversions » turbo & superchareger
bunny
North Sydney
icon5.gif  turbo & superchareger Fri, 24 May 2002 00:45 Go to next message
hehehe
i had a idea.......i think it might be good....
the 1G series is available with supercharger and turbo/twin
what if you used the supercharger to take care of low down boost+ increase torque then coupled it to a big turbo to take care of the upper end of things.
ie run the output of the supercharger to the inlet of the turbo
and then the turbo to intercool;er then the intercooler to the inlet man.
perhaps even twin intercoolers?
what do you guys think of this idea.
rob_RA40
c'town, NSW
Re: turbo & superchareger Fri, 24 May 2002 00:52 Go to previous messageGo to next message
its called twin charging, and the 1G actually had a twin charged model, i dunno if it was factory or a HKS kit but there was one, and from what i hear, it is WAY too much stuffing around, u would be better off spending your money on a new turbo/s setup thats been tuned to meet your specifications...
in short, u will never get it working properly, and if u do you would have spent WAY too much on it...
inferno
Re: turbo & superchareger Fri, 24 May 2002 12:48 Go to previous messageGo to next message
No Message Body
bunny
North Sydney
icon5.gif  Re: turbo & superchareger Fri, 24 May 2002 14:12 Go to previous messageGo to next message
the mechanichs of it are not hard: fit the factory nsupercharger to the twin turbo model run the out pipe from the supercharger into the inlet for the turbos, which should get some good response low down and its only 400 bucks for the supercharger i could do it myself hehehe
MRTA22
Re: turbo & superchareger Sat, 25 May 2002 13:20 Go to previous messageGo to next message
Simple in theory but as Rob said not worth it!! Its simple to plumb the supercharger into the turbo plumbing but what happens when your supercharger is pumping only say 6psi and the turbo's pump 10psi? The extra 4psi blows down into the supercharger!! (and dont even think about having them both make the same boost, wont work either!) You need to install a valve which bypasses the blower when the turbo comes on boost.
A larger turbo and aftermarket computer would have heaps more capability and would cost the same in the end. There was a twin charging kit made for the 4AGZE but was very expensive and didnt give huge gains. Jamie
bunny
North Sydney
Re: turbo & superchareger Sat, 25 May 2002 13:31 Go to previous messageGo to next message
well, dont i feel like a sack.
thanks for the info TA, i hadnt thought of that, No No No
although it interests me mainly as an idea cause i like things that no one else has. but aparently ill have to find something else. Smile
MRTA22
Re: turbo & superchareger Sat, 25 May 2002 13:34 Go to previous message
Ha ha no worries. If you want something different why dont you convert a 1J to triple carbs and put a blow through turbo setup? I bet noone else will do that one Laughing Just kidding.
Previous Topic:The 2t-geu, what kind of potential?
Next Topic:1jz stnd injector impedance
Current Time: Mon Oct 19 19:06:15 UTC 2026
Total time taken to generate the page: 0.042593955993652 seconds
