Toymods » Tech & Conversions » Welding aluminium
chrishulbert
Castle Hill NSW
icon10.gif  Welding aluminium Mon, 27 September 2004 00:02 Go to next message
I have an opportunity to get my hands on heaps of aluminium tubing cheaply, so i can make a wakeboard tower for my boat, but i was wondering: is aluminium hard to weld? Anyone have any experience?
AE86slut
Baulko Hillo
Re: Welding aluminium Mon, 27 September 2004 00:32 Go to previous messageGo to next message
Aluminium is pretty hard to weld AFAIK. It has to be TIG welded.
What boat is it btw?
chrishulbert
Castle Hill NSW
Re: Welding aluminium Mon, 27 September 2004 00:44 Go to previous messageGo to next message
Here's the baby i'm going to be buying this thursday:
http://img40.exs.cx/img40/5793/kevs.jpg
AE86slut
Baulko Hillo
Re: Welding aluminium Mon, 27 September 2004 00:58 Go to previous messageGo to next message
Nice man..... But will she put out much of a wake? Looks just like a normal ski boat. Just pack her full of bladders!!! That's what we did with my mate's CruiseCraft and it was HUGE!
CLG
Perth, Western Australia
Re: Welding aluminium Mon, 27 September 2004 00:59 Go to previous messageGo to next message
I've also seen Aluminium MIG welded - the welder reqiured different wire and settings to weld it succesfully though!
[Updated on: Mon, 27 September 2004 01:00]
chrishulbert
Castle Hill NSW
Re: Welding aluminium Mon, 27 September 2004 01:01 Go to previous messageGo to next message
Just look at that deep-vee, man! It'll put out a FAT wake. Not to mention its a rear mount, big old cast-iron v8. niiice and heavy.
Yeah i might buy a couple of fat sacs. Or find some concrete blocks and leave them in a nice spot at the ramp. Bladders? haha ive never heard them called that.
gabe
Re: Welding aluminium Mon, 27 September 2004 01:12 Go to previous messageGo to next message
Everyone reckons ally is hard to weld but I disagree.
Due to the rate it dissipates heat, you need to weld with a lot more current than you would welding a similar size piece of stainless or mild steel.
If you TIG ally, an AC welder needs to be used but if you need to fill a gap, just MIG it!
Ally tends to 'fall' away when being welded, leaving big holes. You just need to be careful and set the current just right.
TIG as always leaves a much nicer finish, but as I said earlier, all your cuts need to be spot on as its hard to fill big gaps.
Also when TIG welding ally, you will chew through filler rod like its going out of fashon!!
AE86slut
Baulko Hillo
Re: Welding aluminium Mon, 27 September 2004 01:15 Go to previous messageGo to next message
Meh, the image looks heaps dark on my PC (all images seem to) so I can't see the bottom of the hull.... But yeah, with the engine right at the back it should be pretty nice! And yeah, we put about 250kg in the back of that ol' Cruiser! Lucky it had a 200 on the back otherwise it wouldn't have moved! What engine is in that beast?
As for the welding, I had a few bits custom made for my engine from aluminium pipe and that was done by Gary at Hornsby Performance Mufflers. Apparently there are only a couple of places around the area that will do it and Gary is one of them.
Hope this helps!
Jeremy.
chrishulbert
Castle Hill NSW
Re: Welding aluminium Mon, 27 September 2004 01:25 Go to previous messageGo to next message
I think its a 327 chevy AFAIK.
Toobs
Re: Welding aluminium Mon, 27 September 2004 04:50 Go to previous messageGo to next message
You can still oxy weld aluminium but it requires a bit of practice.
The main thing to consider when welding this stuff is you MUST clean the surface extremely well (steel wool + a bit of liquid soap works well) and dry it off with the air gun so there is no oil etc. left on it.
TIG welding is the best option but not many people have a TIG laying around and leadfoots like me tend to blow holes in things with the TIG.
djmickyg
Re: Welding aluminium Mon, 27 September 2004 06:25 Go to previous message
for tig..
if ur gonna clean it with some steel wool or a wire brush make sure it is stainless steel.. mild steel brushes deposit bad things into the aluminium and it makes it real shit to weld..
and once again like people have said make sure the 2 sides of what ur welding are joined together real well.. you sont wana be filling up holes..without lots of welding under ur belt..filling a hole in ally usally turns into a bigger hole with alot of shit around it..
also welding round tube can be dificult cus u gotta constantly change the angle of the gun.. so try and do it in short bursts.
getting tig welding done by someone else can be real expensive. alot of places charge $70+/hour.
[Updated on: Mon, 27 September 2004 06:26]
Previous Topic:Turboing n/a 99 corolla - info required
Next Topic:MA70 LH Rack End Question
Current Time: Fri Oct 23 04:53:29 UTC 2026
Total time taken to generate the page: 0.051426887512207 seconds
