Classifieds » Wheels, Tyres, Suspension and Brakes » KE25/KE70 Coilovers
macstac
KE25/KE70 Coilovers Mon, 27 September 2004 01:32 Go to next message
I have the following parts avilable for a KE20/25
- FRONT HEIGHT ADJUSTABLE COILOVERS. These are on celica/KE70 (not sure) struts converted to suit a KE20/25. They include the larger brakes and calipers from the celica. The springs are 175 lbs. King springs. I will also include a FRONT SWAY BAR (18mm)
$370 ONO
- 4 SPEED GEARBOX QUICKSHIFT. Excellent condition. $90 ONO
http://forums.toymods.org.au/index.php?t=getfile&id=6871http://forums.toymods.org.au/index.php?t=getfile&id=6872
Attachment: Strut.jpg
(Size: 79.02KB, Downloaded 702 time(s))
Attachment: spring.jpg
(Size: 89.30KB, Downloaded 685 time(s))
[Updated on: Thu, 30 September 2004 12:58]
TerryOBeirne
Redbank Plains,near Ipswi...
Re: KE25 Coilovers Mon, 27 September 2004 02:51 Go to previous messageGo to next message
what celica are they out of??. I guess all you have changed is the strut top to suit the corolla???
macstac
Re: KE25 Coilovers Mon, 27 September 2004 03:15 Go to previous messageGo to next message
I think they are out of a TA22 celica, but I am not sure. I got hold of them as they are..
Super Jamie
On Probation
North East NSW
Re: KE25 Coilovers Mon, 27 September 2004 06:27 Go to previous messageGo to next message
haha just when i get my car going with custom front springs and ke70 brakes Razz however i do have some cash to spare
what inserts do the struts have?
have the struts been shortened any?
can you measure the two mounting holes at the base of the strut (center to center)?
what is the diameter of the disc brake?
what is the part number on the brake pads?
is the quickshift just a shifter or the whole gearbox? if it's for a "four speed", how is this different to a five speed if at all? as i've swapped shifters between K40 and K50 gearboxes before? got a photo of it? even if i don't get the struts, i'll definately get this if it fits my stuff
GZE-STYLE
Camden
Re: KE25 Coilovers Tue, 28 September 2004 02:37 Go to previous messageGo to next message
My mate would be very interested in the box if its still available. He needs it ASAP. PM me your phone number if its still available
macstac
Re: KE25 Coilovers Tue, 28 September 2004 03:16 Go to previous messageGo to next message
Super Jamie
I don't know what inserts are in the struts, but i think they are bilsteins.
I don't know if the struts have been shortened, but they are about 44cm from the base of the strut to where the insert goes in.
the two mounting holes at the base are 80mm from centre to centre.
the disc brake is about 21-22cm in diamter and they aren't vented.
I don't know the part number of the brake pads.
the quickshift came of the original 4 speed that was in my KE25, so I don't know if it fits a 5 speed,, but if you have swapped shifters between the 4 and 5, i guess that it would work.
http://forums.toymods.org.au/index.php?t=getfile&id=6894http://forums.toymods.org.au/index.php?t=getfile&id=6895
Attachment: QS1.jpg
(Size: 62.11KB, Downloaded 523 time(s))
Attachment: QS2.jpg
(Size: 22.76KB, Downloaded 517 time(s))
macstac
Re: KE25 Coilovers Tue, 28 September 2004 03:17 Go to previous messageGo to next message
GZE-STYLE wrote on Tue, 28 September 2004 12:37
it is just the shifter, i don't have the box anymore
Re: KE25 Coilovers Tue, 28 September 2004 04:38 Go to previous messageGo to next message
macstac wrote on Tue, 28 September 2004 13:16
just a a note, original KE20 discs ae 200mm diameter, KE30 discs are 218mm diameter and 10mm thick, KE70 discs are 218mm adn 12.5mm thick.
the calipers kinda look like ke70 calipers to me?
what is quick shift about the shifter? shorter top or longer bottom?
the rounded flange is KE20 K40 style. is a different flange to the KE30 and KE10 type. is the rod support at the rear of the base of the shifter still there?
macstac
Re: KE25 Coilovers Tue, 28 September 2004 04:51 Go to previous messageGo to next message
Stewart
The discs would be 218mm diameter... The discs are around 11mm thick, so i guess they could be KE70 items that have been machined. So the braking setup is probably from a KE70
I just had a look at the shifter and the rod support is still there, but it is cracked and probably needs to be welded.
Super Jamie
On Probation
North East NSW
Re: KE25 Coilovers Tue, 28 September 2004 11:04 Go to previous messageGo to next message
i thought the brakes looked like ke70 items as well, if you pull the caliper off and the pads are DB1086s or 1087s then this is true. so no advantage there
might pass it up, i can get a coilover kit and springs for the same price, and i can't be bothered changing to ae86 power steer arms and ball joints at the moment, i'll just modify the ae86 struts i have under mum's house and use those brakes
not real keen on cracked parts either
thanks anyway
Super Jamie
On Probation
North East NSW
Re: KE25 Coilovers Tue, 28 September 2004 11:14 Go to previous messageGo to next message
i might go as far as to say these are ke70 struts with ke20 tops
macstac
Re: KE25 Coilovers Tue, 28 September 2004 23:45 Go to previous messageGo to next message
they could be!
Re: KE25 Coilovers Wed, 29 September 2004 02:06 Go to previous messageGo to next message
but they are still coilovers Very Happy mm shiny
macstac
Re: KE25 Coilovers Thu, 30 September 2004 00:26 Go to previous messageGo to next message
i will drop the price to $320 ONO for the coilovers and swaybar
macstac
Re: KE25 Coilovers Thu, 30 September 2004 12:59 Go to previous messageGo to next message
how about offers around $300??
mlaser
Re: KE25/KE70 Coilovers Sat, 02 October 2004 06:28 Go to previous messageGo to next message
any idea on how much to the send coilover to bris?
[Updated on: Sat, 02 October 2004 06:30]
macstac
Re: KE25/KE70 Coilovers Sun, 03 October 2004 07:50 Go to previous messageGo to next message
around $50 approx.
twincam_ke20
Castlemaine Vic
Re: KE25 Coilovers Mon, 04 October 2004 07:51 Go to previous messageGo to next message
so are these a direct bolt in for a ke20/25? and will the std wheels still fit?
macstac
Re: KE25 Coilovers Mon, 04 October 2004 10:31 Go to previous messageGo to next message
yes, they are a direct bolt in for KE20/25
and yes, the standard wheels will still fit!
shashora
Re: KE25 Coilovers Wed, 10 November 2004 03:09 Go to previous message
have u sold the coilovers yet ?! and u in sydney??
Previous Topic:Supra Rims fits sprinter ( Price reduced)
Next Topic:FS mags and suspension suit 74 celica
Current Time: Tue Oct 20 22:36:06 UTC 2026
Total time taken to generate the page: 0.011443853378296 seconds
