Toymods » Tech & Conversions » vented single piston OR twin piston solid
Flogbag
Sydney (Campbelltown...!)
vented single piston OR twin piston solid Mon, 27 September 2004 12:20 Go to next message
hey ppl
had a look at some brakes today for my sprinter at the wreckers as i am wanting to do an upgrade very soon!
i seen:-
Cressida mx62 early 80's with vented disks single piston caliper but massive pads compared to the stock ones on the sprinter at the moment also had much larger disks
RT132? i think? it was a 2 door liftback with 2 round lights each side at the front. anyway this had solid disks which looked as big as the cressida ones but had twin piston calipers (piston on each side)
and i noticed that both set of brakes had the calipers on the back (above steering arm) but on the sprinter the calipers are on the front of the disk
QUESTIONS:
Has anyone had any experiance with both these sets of brakes?
i wanna know comparison in stopping power? which would be better?
how wheel alignment is affected with the celica twin piston setup if i use those struts?
will i definally need another master cylinder if i wanna use twin piston calipers or will the stock sprinter one give good enough pedal feel?
how ppl have routed the brake line as the caliper is on the other side of the disk?
ppl's recomendations and trouble ppl have had doing this conversion
and b4 anyone says use search i have and have been hunting thru these posts for about 2 weeks now trying to find everything i need to know but some things arent discussed in detail and these questions i havnt yet been about to answer
thanks for any help
[Updated on: Mon, 27 September 2004 12:26]
Flogbag
Re: vented single piston OR twin piston solid Mon, 27 September 2004 12:48 Go to previous messageGo to next message
to start things off
found this in a post
"You have more travel in the pedal as you now have more fluid to move thru the RT132 twin pot calipers. IIRC the T18 master cylinder is an a direct bolt on upgrade for the TA22 unit, and you go from 11/16 to 13/16 in size. (Corrections anyone?)."
read that the sprinter is a 13/16 master cylinder so would that make the pedal firm enough?
wilbo666
Re: vented single piston OR twin piston solid Tue, 28 September 2004 00:31 Go to previous messageGo to next message
Umm not really sure that I can be of that much help, but if you are thinking about MX62 cressida struts, another thing so investigate is RA60, RA65, SA63 struts (I actually swapped SA63 struts into my MX62 cressida, mainly for the better off the shelf spring options, and slightly bigger brakes). The camber between MX62 -> R/S6X celicas seemed to be then seemed to be very close to the same. The celica struts I'm talking about are 258?/22mm vented single piston things.
I had to reverse the struts to fit them in my car, was just a matter of putting the left on the right, and the right on the left Smile With the flexible hoses brake hoses I just zip tied them to the original mounting points with no dramas (couldn't use the original ones as per stock exactly as they had the wrong angle or something, so I bent them down and then zip tied to them if I recall)
Also another thing to think about is braking bias, when I put the SA63 struts in mine, the bias was shocking! I wasn't thinking that there would be that much difference, but OMG I was wrong :S Fixed the problem by installing the SA63 bias valve tho!
Also is it possible to use a MX62/ R/SA6X master cyl? MX62 is 7/8th and R/SA6X is 15/16th, might be good options?
Haven't had any dealing with the RT struts, so I don't really have much to add, although I think they are good in the fact that there is good upgrades available? (hilux 4 spot calipers and pug disks? or I might be confused and thinking about different struts Confused)
Re: vented single piston OR twin piston solid Tue, 28 September 2004 01:16 Go to previous messageGo to next message
you can actually use the 405 vented pugeot disc with the twin piston RT132 calipers if you space the calipers apart by about 3-4mm.
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Tue, 28 September 2004 06:27 Go to previous messageGo to next message
i think original sprinter m/c is 7/8th cant remember. the important thing with chosing the correct master cylinder bore diameter is to go with the same diameter as the calipers the car original came with. eg if the calipers the car came off used a 15/16th m/c, thats the size you want to use. also with changing m/c's check the depth at the back, the part the rod acts upon. very important.
ra23celica
Re: vented single piston OR twin piston solid Tue, 28 September 2004 06:47 Go to previous messageGo to next message
EVOSTi wrote on Tue, 28 September 2004 16:27
I can't agree more having learned this the hard way, with my RA23 with RT132 struts, Hilux calipers, Pug rotor's, SA63 m/cyl and original ('23) vaccum booster. Make sure the rod in the booster pushes the piston in the m/cyl its full travel. Word.
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Tue, 28 September 2004 06:54 Go to previous messageGo to next message
i wouldnt have thought of it but i had just finished covering master cylinders at tafe Smile
best way to measure is measure the length of the rod protruding from the booster compared to the m/c mating surface, and the depth of the m/c compated to the booster mating surface, if that makes sense.
CLG
Perth, Western Australia
Re: vented single piston OR twin piston solid Tue, 28 September 2004 07:48 Go to previous messageGo to next message
Before you think too much about the brakes associated with those struts, think about the geometry they both will give - the Cressida stuff has a larger stub axle angle than both the RT132, and your current AE86 strut, which once installed, will increase positive camber.
For that reason, I'd use the RT132 struts as the basis for your brake upgrade, with the added advantage of getting bigger wheel bearings too. You'll need to address shock draft and height also, but they can be easily cut down to suit, and you can install a Pug 406 rotor also to get the vented disc rotor, along with the 2 spot callipers relatively easily also. You can also rotate the strut assemblies to have the calliper on the front to make plumbing alot easier.
Flogbag
Re: vented single piston OR twin piston solid Tue, 28 September 2004 10:53 Go to previous messageGo to next message
taking everything into account
i am thinking of just doing the cressida strut caliper and disk then another steering arm the same length as the stock sprinter one (RA60?), turning the strut around as you have pointed out and get some ra60 roll centre adjusters with 2 degree neg camber to straighten up the wheel angles
the cressida pads are much bigger then the RT ones so i guess they wouldnt be much of a difference with a 950kg sprinter plus i like the look of vented rotors better then solid ones!
do you think the cressida calipers would give me a soft pedal or uneven brake bias? anyone done this and know from experiance?
wilbo666
Re: vented single piston OR twin piston solid Wed, 29 September 2004 01:15 Go to previous messageGo to next message
Are you using the stock AE86 lower control arms? If so I don't think that RA6X arms fit to the ball joint do they? I thought there was a size difference (i may indeed be wrong on this tho!)
Also, seeing as I'm pretty sure that MX62 and SA63 kingpin angles (and hence camber) are pretty close to the same, why don't you want to go to RA6X struts, as they have bigger brakes again than the MX62's.
Re: vented single piston OR twin piston solid Wed, 29 September 2004 01:28 Go to previous messageGo to next message
the angle at which RA65 struts sit on the RA65 is greater than on the AE86/AE71/RA2* and hence would create positive camber.
I would go with the RT132 struts. Just go into a self serve wreckers and do some test fitting on an AE71/KE70 - they are the same.
wilbo666
Re: vented single piston OR twin piston solid Wed, 29 September 2004 01:58 Go to previous messageGo to next message
THE WITZL wrote on Wed, 29 September 2004 11:28
Yeah thats fair enough, but if he is keen on using MX62 struts (which he seems to be), I thought that he might like to know that I'm pretty sure that the camber will be close to the same between RA6X and MX62 struts (but RA6X struts have bigger brakes).
I also think he should go the RT132 struts!
Flogbag
Re: vented single piston OR twin piston solid Wed, 29 September 2004 07:08 Go to previous messageGo to next message
oh ok
u have a good point there wilbo666
bout the lower control arms i was going to use mx62 ones as i have heard they were longer and use ra60 steering arms so i can both fit roll centre adjusters and put them on the lower control arm with the bigger ball joint
i am trying to stick away from using the RT twin piston setup for the reason i dont wanna change my master cylinder...
im going to wreckers this weekend and going to do some measurements they have a RT132, mx62, and a ke70 wagon (think)
i'll take a angle guage, tape measuring tape and report back...
wilbo666
Re: vented single piston OR twin piston solid Wed, 29 September 2004 08:49 Go to previous messageGo to next message
Flogbag wrote on Wed, 29 September 2004 17:08
oh ok
Whoa, the MX62 arms are longer...MUCH MUCH longer! lol
I think that MX73 arms are a little more realistic, not 100% sure? I wounder how RA6X arms fit into the picture....
I don't think changing the master cylinder should steer you away from the RT132 struts....as I suspect either way you are going to have dramas with the brake bias anyway! Is there any reason that you don't want to consider using the RT132 master and bias valve?
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Wed, 29 September 2004 11:13 Go to previous messageGo to next message
bah all this hastle when you can go the hilux/pug way, its all pretty much nuts and bolts stuff, and ive written the instructions Shocked
http://toymods.org.au/Repository/TechDocs/ae86brak es.pdf
Flogbag
Re: vented single piston OR twin piston solid Wed, 29 September 2004 11:56 Go to previous messageGo to next message
ill have a look at what size master cylinder RT132's have and what size wheel cylinders they have in the back
as for hilux and pug dont have the money...
i guess its all up to wat i find when i go get some measurements
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:01 Go to previous messageGo to next message
not all that expensive, but yeah more so than what your contemplating. if you do it all yourself you can have it for between 500-800 depending on where you get your parts from.
Flogbag
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:06 Go to previous messageGo to next message
what do u mean by rose jointed for camber adjustment on the lower control arms???
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:09 Go to previous messageGo to next message
http://img11.exs.cx/img11/7195/Pic21.jpg
http://img11.exs.cx/img11/6589/Pic22.jpg
http://img11.exs.cx/img11/8641/Pic23.jpg
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:10 Go to previous messageGo to next message
yeah i shoulda resized those
Flogbag
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:18 Go to previous messageGo to next message
nice...
where did u get them from and how much?
was the control arm just cut then they were bolted on?
different bushes?
ae86drift
sydney.au
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:22 Go to previous messageGo to next message
i would always go with vented over solid
reguardless of size/pistons
because of fade reduction and mu temp on the pads
and the ae86/4age is a lightweight combo
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:29 Go to previous messageGo to next message
they are custom jobbies i was lucky enough to obtain Smile
they are just cut, with blocks bolted to the ends and the threaded rose-joint going through the middle with a nut for camber adjustment. as you can see there is still enough thread to throw a few more degrees of neg camber in Smile
there are no bushes. you can probably obtain the rose joints yourself and get an engineer or someone to make them up. i have to mention tho that they are HIGHLY illegal for street use.
Flogbag
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:32 Go to previous messageGo to next message
it looked that way...
oh well, ill have a look at the wreckers and get back to u if i have any other questions
thanks for the info it was greatly appreciated
ae86drift
sydney.au
Re: vented single piston OR twin piston solid Wed, 29 September 2004 12:36 Go to previous messageGo to next message
ps. average rose joints dont last long on road cars because of the vibration of the crap roads
(half as long if your in sydney)
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Thu, 30 September 2004 07:05 Go to previous messageGo to next message
how longs not long? been in current car 2 years, previous car 5.
no obvious signs of wear. but if they do fail, IM FUCKED!
Flogbag
Re: vented single piston OR twin piston solid Thu, 30 September 2004 08:25 Go to previous messageGo to next message
lol thats reasuring
Flogbag
Re: vented single piston OR twin piston solid Thu, 30 September 2004 08:31 Go to previous messageGo to next message
think im going to put off this for a while now
got a letter in the mail from the epa bout excessive smoke from my exhaust (valve stem seals) and have to fix that now...
EVOSTi
cambo
      no
Re: vented single piston OR twin piston solid Thu, 30 September 2004 08:54 Go to previous message
Really? EPA sent you a letter? thats a little unusual isnt it?
Previous Topic:1G-GTE starting issues... and running issues!
Next Topic:rough GVM on RN41 hilux with alloy tray
Current Time: Fri Nov 20 14:36:43 UTC 2026
Total time taken to generate the page: 0.015100955963135 seconds
