Toymods » General Car Talk » Help my aw11 went CLUNG!
fractoid
icon5.gif  Help my aw11 went CLUNG! Tue, 28 September 2004 02:33 Go to next message
Anyone got any idea what might have caused it? It was shortly after fanging it round a corner, and then going over a small bump (the kerb, going into my work parking lot).
I was sitting in the car waiting a couple of secs before turning it off (turbo habit, although you don't have to idle down superchargers - do you? anyway I've always thought it was rude to turn a car off immediately after giving it some stick) and all of a sudden it makes a major 'clung' noise. Nothing seems to be hanging down from the car, no belts are broken that I can see, suspension etc. still seems to be working when I rock the car, steering still works... so what on earth could have made this scary noise?
Spanktown
Inside a giant turbo (syd...
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 02:55 Go to previous messageGo to next message
no idea on the noise, but yes you dont have to 'warm' down supercharged cars, but its still a good idea to idle a car for a little bit before you switch it off.
Benno
NSW Australia
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 03:18 Go to previous messageGo to next message
Maybe it was one of your springs re-seating. If you have lowered springs, sometimes the strut can expand enough so that the spring gets out of its groove at the top or bottom mounting cups. I had this happen with my lowered RX-4 many years ago. You're right its a scary sound!!! Shocked
fade-e
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 03:26 Go to previous messageGo to next message
when you say clung, wsa it a clung and car turned off or was the car still on and can you still start it?
fractoid
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 03:30 Go to previous messageGo to next message
It does make clunking noises going over bumps sometimes, which sound like the nuts holding the struts in aren't as tight as they could be and are moving up and down. I had the same noise on the Supra after getting new struts put in - so it could well be something like that (especially given the combined stimulus of a roundabout and a sweeping right hander, both taken at the limit of traction (nearly), and a bit of a bump).
OK, for now I'm going to pretend that that was it. Thanks! Smile
[edit: it still seems to go. I'm pretty sure it was running when I heard the clung, in fact my first thought was that putting the handbrake on had somehow caused it and I always put the handbrake on before turning the car off. Dunno why. ]
[Updated on: Tue, 28 September 2004 03:31]
Ben Wilson
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 04:41 Go to previous messageGo to next message
Check the nuts on the sway bar links, they make a horrible noise when they come loose (and when they start to rattle, they trash the droplinks).
old_mr2
Re: Help my aw11 went CLUNG! Tue, 28 September 2004 12:31 Go to previous message
It sounds like your handbrake cable has snapped. The same thing happened to me when I had it jacked up. I heard a big 'clung'. I already had one cable broken and the clung was the other one breaking.
Put your handbrake in the down position and look under the car. If its broken you will see the cable hanging down about 2/3's down the car.
Check that out. I think its about 150 to have both replaced or check out http://www.padandwheels.com and do it yourself. If thats the problem that is
Previous Topic:jambo pics {56k beware}{28.8k can go to hell}
Next Topic:name of mags need a replacment
Current Time: Fri Nov 20 10:39:32 UTC 2026
Total time taken to generate the page: 0.005836009979248 seconds
