Toymods » Tech & Conversions » HELP!!! 2TGEU not firing
fallenangel
Wollongong NSW
HELP!!! 2TGEU not firing Tue, 28 September 2004 05:17 Go to next message
ok...i got 2tgeu engine with weber 45mm sidedraft carby
have been workin on gettg it running but when all timing marks are lined up it wont fire...however when the timing is telling me it is out by quite a bit it runs....
I know the principle is to set everything to start point or 'One'
and everything should be fine.
Could it be the wrong flywheel maybe.....unsure if engine has had conversions.
greenta22
Dandenong Ranges, VIC
Re: HELP!!! 2TGEU not firing Tue, 28 September 2004 08:30 Go to previous messageGo to next message
ive got the same issue with my 2T at the moment, nobody can figure out what is going on. it kicks over if the timing is retarded by 20 degrees plus. very wierd. if you find out please let me know & vice versa.
Snyper
Re: HELP!!! 2TGEU not firing Tue, 28 September 2004 09:28 Go to previous messageGo to next message
try taking the distributor out and rotating it one tooth and then putting it back in...
omegaman
SYDNEY
Re: HELP!!! 2TGEU not firing Tue, 28 September 2004 10:15 Go to previous messageGo to next message
To get the answer I believe we need to know what you did to the motor ie. did you take it apart, removing timing chains.
this would then guide us to whether you have assembled it correctly.as far as tdc no.1 cyl, dizzy set up it should attempt to fire. must be more to it?
pheonix83
Devonport Tasmania
Re: HELP!!! 2TGEU not firing Tue, 28 September 2004 11:26 Go to previous messageGo to next message
you need to turn the engine over manually till it is at top dead centre on cylinder 1.
then pull the dizzy cap off any note the rotor button position.
it needs to be lined up exactly where the lead to cylinder 1 would go.
if it doesnt, remove the dizzy and insert again so it lines up.
then all you need to do is tighten it, turn it over and adjust timing till correct.
LT1974
Adelaide Hills
Re: HELP!!! 2TGEU not firing Wed, 29 September 2004 06:39 Go to previous messageGo to next message
have a look at this...
is it set up like this?, i know the picture is for a pushrod 2t but it is the same for a 2tg / 2tgeu
http://www.cardomain.com/id/lt1974
have a look at page 4, i couldnt bring the picture up big enough on this site ???
while your there check out the rest of my car Very Happy Very Happy
[Updated on: Wed, 29 September 2004 06:55]
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Wed, 29 September 2004 13:53 Go to previous messageGo to next message
Number 1 cylynder TDC.
Dizzy set to Number 1
checked cams all lined up on TDC on first cylinder
Timing is set properly.
Have removed dizzy to line it up on one
points are good. New leads and sparkies.
still cant get it to fire on proper timing marks.
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Wed, 29 September 2004 13:54 Go to previous messageGo to next message
could it be condenser?
pheonix83
Devonport Tasmania
Re: HELP!!! 2TGEU not firing Wed, 29 September 2004 23:18 Go to previous messageGo to next message
pull out spark plug number one, keep the lead on and hold it against your engine/chassis.
turn the car over and see what your spark looks like.
if it looks weak, bypass your ballast resistor and check again.
did it seem better.
does it run with it bypassed ?
if it does its prolly rooted.
if not try a different coil and check spark strength.
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Sat, 02 October 2004 13:30 Go to previous messageGo to next message
Ok.....the problem has to be alot more obscure....
electricals are all good....
replaced condensor, new leads and plugs, everything lined up right.
Engine not running when timing marks are lined up though will run when marks are sayin its out....
fileing new timing marks on flywheel.
LT1974
Adelaide Hills
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 01:00 Go to previous messageGo to next message
timing marks should be on the front pulley, and on casing, not flywheel ??
pheonix83
Devonport Tasmania
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 10:19 Go to previous messageGo to next message
its called the harmonic balancer
jesseT18
Castle Hill, Sydney
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 10:32 Go to previous messageGo to next message
mechanical advance?
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 12:55 Go to previous messageGo to next message
er...woops...my bad....harmonic balancer i should have said
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 12:57 Go to previous messageGo to next message
well...short of stripping the engine down for a rebuild i am a lil stumped...but is running ok now though timing marks dont seem to think so...sounds sweet
jesseT18
Castle Hill, Sydney
Re: HELP!!! 2TGEU not firing Tue, 05 October 2004 13:09 Go to previous messageGo to next message
sounds a lot like your mechanical advance, have u rebuilt the dizzy?
sometimes the weights get bogged with crud
i definately wouldnt be stripping my engine...
[Updated on: Tue, 05 October 2004 13:11]
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Sat, 09 October 2004 11:19 Go to previous messageGo to next message
ok...got engine firing.
Thanks for suggestions Smile
Though now it seems i have inlet valve problems....the heads comin off.
Crying or Very Sad
fallenangel
Wollongong NSW
Re: HELP!!! 2TGEU not firing Sat, 09 October 2004 11:20 Go to previous message
oh yea...dizzy is nice. no probs there
Previous Topic:Timing Belt woes :(
Next Topic:Wheels for 91 MR2
Current Time: Sun Oct 18 02:53:09 UTC 2026
Total time taken to generate the page: 0.0279381275177 seconds
