Toymods » Tech & Conversions » ae86 air conditioning.
shcao
ae86 air conditioning. Tue, 28 September 2004 09:09 Go to next message
I've just finished with my 4age engine conversion.
I was told that the 4ac air con unit doesnt work with a 4age is this true?
if so, can I adapt an ae82 twinky one? I am gonna try get my air con and heating issues solved.
thanks.
Cyber-punk
Brisbane, QLD
Re: ae86 air conditioning. Tue, 28 September 2004 09:12 Go to previous messageGo to next message
you should be able to adapt the twinky one is you cant use your pre-existing system
just swap as many of the componants as possible and get some custom lines made up
if the condensor and evaporator are of similar size you should be able to get away with using your sprinter ones
DanielJ
Re: ae86 air conditioning. Tue, 28 September 2004 09:31 Go to previous messageGo to next message
I am running my 4AC A/C compressor on my 20V in my AE86. Its been running for years without any problems.
ae95
Re: ae86 air conditioning. Tue, 28 September 2004 15:20 Go to previous messageGo to next message
4AC runs a different belt so u'd have to sort that out too
DanielJ
Re: ae86 air conditioning. Tue, 28 September 2004 21:10 Go to previous message
Yes, you have to use 4AC crank pulleys etc.
Previous Topic:AE86 Diff centre comparisson/conversion
Next Topic:What ECU to run Quad throttle 16v
Current Time: Mon Oct 26 14:21:14 UTC 2026
Total time taken to generate the page: 0.018764972686768 seconds
