Toymods » Tech & Conversions » XT130 struts into KE55..
gr8r-x
Vic, AU
XT130 struts into KE55.. Tue, 28 September 2004 10:17 Go to next message
Howdy once again.
Was trying to be tricky, and not screw around with cutting/welding, by using the KE strut tops with the XT130 strut/spring/holder, but just realised that the KE strut top is flat whereas the XT130 bulges down.. Obviously it won't fit, damn it!!
Now, can I put a big, fat "washer" to go between the spring holder and strut top, or would that cause problems? I'd assume that as long as the "washer" is lubed properly it shouldn't case any problems. Anyone shed any light?
Already tried the KE spring holder on the XT spring, but it's to small, same with the KE spring in the XT strut.
gr8r-x
Vic, AU
Re: XT130 struts into KE55.. Tue, 28 September 2004 22:08 Go to previous messageGo to next message
Bumpity bump.. Anyone?
demuire
Ipswich
Re: XT130 struts into KE55.. Tue, 28 September 2004 22:42 Go to previous message
No you don't want to put a washer in, that will make your car sit even higher (not to mention the extra load on the shock shaft). Also I suspect the spring is too big for the strut tower anyway...
What you want to do is use the KE top spring platform and strut top. Like you discovered the XT spring won't fit because the KE top spring platform is too big. You've also noticed the KE spring doesn't fit the XT strut.
So, you'll want to get AE86 springs. Not sure if KE70 ones are the same, I think T18 ones are different (they looked different to me). If you get lowered AE86 springs (KTFL33 I think), it'll sit your KE55 at stock height.
Click here for some photos
Previous Topic:Just a quick question
Next Topic:AE86 Diff centre comparisson/conversion
Current Time: Sun Oct 25 02:21:59 UTC 2026
Total time taken to generate the page: 0.0042839050292969 seconds
