Toymods » Tech & Conversions » AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 hatch?
jkvsnn
icon5.gif  AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 hatch? Tue, 28 September 2004 10:26 Go to next message
I have an AE92 hatch with 20V ST that I just bought and the CV's are on the way out, it also jumps out of 5th gear when cruising and still has (I think) standard CSi Ltd front brakes.
I also have an AE101 Trueno (20V ST) frontcut that I am only using the engine and loom from for a clubman I am building. Will the gbox/cv's/shafts/struts/brakes etc go straight into the AE92? What does and doesn't fit?
Thanks all,
Julian.
Rod83
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Tue, 28 September 2004 13:21 Go to previous messageGo to next message
The gearbox and shafts will, unsure of struts.
The brakes will need modification. Check this link out for details http://www.twincam.org/forums/index.php?showtopic= 1063
EvilJack
Sutho/Hills NSW
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Tue, 28 September 2004 22:25 Go to previous messageGo to next message
struts wont fit if it has the superstrut setup
jkvsnn
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Wed, 29 September 2004 02:41 Go to previous messageGo to next message
Thanks,
The front cut is not fitted with the superstrut option.
So do the 101 CV's match the 92 hubs if I don't change struts and hubs?
Julian
jasonp1977
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Wed, 29 September 2004 04:01 Go to previous messageGo to next message
the AE101 shafts fit the AE92 hubs. The ae101 non superstrut disc has a 55mm center hole instead of the 54mm like the AE101 superstrut and AE92.
You can either bolt the AE101 hub in place of the AE92 hub, but you will run into problems finding replacement discs when you need them, or you can use DBA discs for a series II SX seca or Gti with the AE101 non superstrut calipers.
To fit the box you will have to change the mechanical speedo drive from your original box into the AE101 box.
Use the Original AE92 gearbox mounts.
EvilJack
Sutho/Hills NSW
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Wed, 29 September 2004 05:58 Go to previous messageGo to next message
they will match
i had the superstruts on mine and used the 20v gearbox and driveshafts to the original ae92 hubs.
if you havent got superstruts then the struts will bolt up to your ae92
jkvsnn
Re: AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 ha Wed, 29 September 2004 09:55 Go to previous message
Thanks again guys,
Is there a noticable/significant improvement in braking with the 101 callipers on SX/GTi discs? I am not planning on seriously tracking the car but may do a couple with the westfield club to tide me over till I finish building the clubbie.
cheers,
Julian
Previous Topic:Lowering leaf springs?
Next Topic:Towing a boat
Current Time: Sun Oct 18 22:59:22 UTC 2026
Total time taken to generate the page: 0.0057649612426758 seconds
