Toymods » Tech & Conversions » Q's Bout Turbo For GZE-20V??
MRKE20
wollongong
Q's Bout Turbo For GZE-20V?? Tue, 28 September 2004 11:08 Go to next message
I am running a 4agze block with 20 valve head and turbo in my AE82 hatch. I am looking to upgrade my current turbo (ulp cordia) to a larger ballbearing model.
I am currently looking at a modified T28 with a TO4 front wheel.
I am looking for a turbo, that when tuned well will get me a 12 sec pass. I know traction will be limited, i am running a LSD mr2 box so that should help as long as the clutch is up to the job.
Do you guys think this is a good choice, i have been told by many that just the straight T28 would be a deadly turbo for the street, but i am really after quick times aswell,and would not want to buy it if i will just want to upgrade soon after.thats why im not going with somthing like a t25 etc...
so if any one else is running the same or similar setup to me, maby you could gimmie some feed back, even in a RWD car would help in the pwr figures area.
any help appreciated. Very Happy
ke382TG
Re: Q's Bout Turbo For GZE-20V?? Tue, 28 September 2004 23:47 Go to previous messageGo to next message
I have the "small" T28 with 0.48 exhaust housing, it has been high flowed and runs a larger compressor wheel. It's hanging off a 4AGZE (16V head) engine that is untouched, it's RWD and runs 12's on street tyres no probs.
170rwkw is enough for my car to do 12's at WSID. It is difficult to get it cleanly off the line though, probably even harder in a FWD car like the AE82. Get some good rubber on there!
The BBT28 you are thinking of should be plenty for 12's, it will make more power and flow better than my bushing type T28 with smaller housings. A freind of mine is currently fitting a brand spanker BBT28 to his 4AGTE, I will be interested to see how it goes.
[Updated on: Tue, 28 September 2004 23:50]
Flogbag
Sydney (Campbelltown...!)
Re: Q's Bout Turbo For GZE-20V?? Wed, 29 September 2004 07:41 Go to previous messageGo to next message
wat model bottom end are u using?
is it all standard bottom end with just head bolted straight on and a turbo added
details would be greatly appreciated
MRKE20
wollongong
Re: Q's Bout Turbo For GZE-20V?? Wed, 29 September 2004 09:45 Go to previous messageGo to next message
As far as i know the bottom end is standard, not sure what model engine. does any1 know a way to check, eg. eng number??
would like to find out cos some as far as i know had forged pistons n rods some didnt, am i right? they all had oil squirters yes? some even had ceramic coated pistons aswell yes?
how much boost were you running for the 170rwkw???
the only prob i can see me having is actually fitting the turbo between the block and radiator. the dam mount and rad hose make it a bitch, but, it will fit Evil or Very Mad
so thats 12's on street rubber, sound great for a steeter, yeah, traction is really the key to good times,rwd or fwd.
any1 got any pics of a similar setup as mine with a t28? i was even thinking af trying a high mount?
MRKE20
wollongong
Re: Q's Bout Turbo For GZE-20V?? Fri, 01 October 2004 09:02 Go to previous messageGo to next message
bump Razz
org86t
taree nsw
Re: Q's Bout Turbo For GZE-20V?? Fri, 01 October 2004 13:03 Go to previous messageGo to next message
how much power u got because in a fwd car traction is hard to get with a lot of power unless your turbo has a lot of lag
come on boost ya bitch ahhhhhh Laughing Laughing Laughing
cramet
warrnambool
Re: Q's Bout Turbo For GZE-20V?? Sat, 02 October 2004 04:11 Go to previous messageGo to next message
use a ext waste gate on the t 28
thats what mrd in melb had on there palsar et to do high 11's
on there 1.5lt motor
MRKE20
wollongong
Re: Q's Bout Turbo For GZE-20V?? Sat, 02 October 2004 10:14 Go to previous messageGo to next message
yeah, was thinking bout using a external too, i know that this will give better boost control allowing more flow out at high boost, but i am still tryin to keep on a low budget
ie, the boss (missus) wont let me spend too much Laughing
from what ive been told by most of the turbo guru's i know is to get big numbers from a 4ag is to go for a huge comp wheel and a tight exhaust wheel and housing. and ball bearing of course.
how much boost do you think a gze block can handle in standard form?
monkeymajik
Re: Q's Bout Turbo For GZE-20V?? Sat, 02 October 2004 15:24 Go to previous messageGo to next message
There are a few around NZ and here that run 18psi on the standard internals, probably some that run higher too!
tanman
Re: Q's Bout Turbo For GZE-20V?? Sat, 02 October 2004 21:36 Go to previous messageGo to next message
If you currently have a ULP Cordia turbo (TC05) then a TD05-16G (evo lancer) turbo will bolt to you manifold. You will have to check on clearance to you block/radiator though
MRKE20
wollongong
Re: Q's Bout Turbo For GZE-20V?? Sun, 03 October 2004 08:35 Go to previous messageGo to next message
are these evo turbo's any comparisen to the t28? what do they go for do you know? What size comparison are they toother turbo's, just to give me an idea, eg similar as t25 ????
are they ball bearing?
sounds interesting. but yeah, thats what its got on it at the moment, just always had TD in my head, not TC. Rolling Eyes
quest
u.s.a. south
Re: Q's Bout Turbo For GZE-20V?? Sun, 03 October 2004 19:31 Go to previous message
this exact same question was asked on the staion 2.0 forum.
evoIII 16g bolted to a 2.0L 3350 pound awd mitsubishi pig and has powered it to 11sec quarters.
Best 't28' I've seen is the one used on this car; Gone 11s also
http://www.wincom.net/trog/car.html 348hp/376wtq at the wheels!
Look at the torque figure. This $600usd turbo has took a full wt. s13 stock motored sr20 hatch to 12.2s quarters, with -severe- tracton problems... spinning drag radials! Doesn't make hp like the expensive overated GT stuff, but the torque is substantially higher and has the ETs to back it up.. better than the small frame GT turbos.
Previous Topic:what causes fuel in oil
Next Topic:KE55 Help
Current Time: Sun Oct 25 02:36:27 UTC 2026
Total time taken to generate the page: 0.029067993164062 seconds
