Toymods » Tech & Conversions » mx62 crossmember in celica for 1g-gte conversion
brett_celicacoupe
townsville NQLD
mx62 crossmember in celica for 1g-gte conversion Tue, 28 September 2004 11:36 Go to next message
i was measuring up a cressida crossmember and it looks very close to fitting into my ra40. the cressida xmember is designed for a front sump engine ie. xmember curves backwards opposed to ra40 xmember goin fowards.
using this xmember, it would leave more option when selecting a 1g front cut.
also, the cressida seems to have lower engine mounts than the ra40. apparently the ra40 mounts have to be cut down for the 1g conversion.
does a 1g bolt straight into a cressida (disregarding the g/box)??
this might make it easyer to put the 1g in my celica later on Smile
thanx
brett
[Updated on: Tue, 28 September 2004 11:37]
Stefan
Hobart, Tas
Re: mx62 crossmember in celica for 1g-gte conversion Tue, 28 September 2004 12:52 Go to previous messageGo to next message
No idea, but it would be great if it would (for the same reasons).
I thought that in an ra40 or below, the engine pretty much bolts right up if you use the rigt mounts.
Re: mx62 crossmember in celica for 1g-gte conversion Tue, 28 September 2004 12:55 Go to previous messageGo to next message
i would have thought it easier to simply modify the engine mounts (using only a grinder and an arc welder) rather than attach an alien cross member and wonder how to get the steering and suspension back to something that's drivable.
but hey... that's just me Wink
seriously now: i'd be wondering what that does to the inboard mounts for lower swing arms - plus (and i'm only guessing here) being concerned about the width (between mounting bolts the same?).
brett_celicacoupe
townsville NQLD
Re: mx62 crossmember in celica for 1g-gte conversion Thu, 30 September 2004 00:11 Go to previous message
i think it has the same width between bolt holes. these are the cressida measurements, (730 or 740mm across and 105mm apart ie. front and back bolt) but it is hard to measure with a big dirty 5me still sittin in it and with a tape measure too. the ra40 xmember widthe between bolt centres is 745mm across and 115mm between front and back bolts. those measurements are correct for my ra40, but not so accurate for the cresdia. also i dont kno if the back of the xmember would fowl the steering drag link.
also i wouldnt kno if the suspension arm would be the same, i woul think it would be i dunno. i might sit lower or higher too.
anothere thing, maybe i could just use the mounts of the cressida, coz they seem lower, ands on a less steeper angle.
Previous Topic:using a sc12 on a non standard application
Next Topic:4AGZE ECU dependence on o2 sensor
Current Time: Fri Nov 20 17:54:25 UTC 2026
Total time taken to generate the page: 0.0050938129425049 seconds
