Toymods » Tech & Conversions » Lowering leaf springs?
serge
western suburbs,sydney
Lowering leaf springs? Tue, 28 September 2004 11:42 Go to next message
How do you lower leaf springs ? I've heard something about adding blocks or something like that i'm not to sure Confused its for a ke70 panelvan.
gr8r-x
Vic, AU
Re: Lowering leaf springs? Tue, 28 September 2004 12:46 Go to previous messageGo to next message
Basically, you add a block of metal and longer U-bolts, between the axle and leaf spring.. Basically moves the springs closer to the ground and the axle closer to the bottom of the car.
Just look for lowering blocks or similar, that's what you are after. Or speak to any decent suspension place and they'll be able to point you in the right direction.
7M-Brisbane
Re: Lowering leaf springs? Tue, 28 September 2004 12:53 Go to previous messageGo to next message
I also believe that in a less dodgy fashion you can actually get lowered leaves.
gr8r-x
Vic, AU
Re: Lowering leaf springs? Tue, 28 September 2004 12:59 Go to previous messageGo to next message
7M-Brisbane wrote on Tue, 28 September 2004 22:53
All depends on the height of the springs to begin with, and the amount of lowering required.. Some leaf springs can be lowered, by reducing the ride height, but others are close to horizontal at full load normally, so lowering won't do that much.
TE72_Turbo
Re: Lowering leaf springs? Tue, 28 September 2004 13:07 Go to previous messageGo to next message
I recently had the leaf springs on my AE71 panelvan reset 2" lower. They had to remove the bottom helper spring (the straight one that isn't bolted to the other leaves) to avoid any adverse handling that they would cause by resting on the other leaves.
I'm not sure what process they use to reset the leaves, but they are a much flatter shape then before. Smile And no, they didn't turn one of the leaves upside down.
Re: Lowering leaf springs? Tue, 28 September 2004 15:05 Go to previous messageGo to next message
get leaves reset or get new springs made up.
lowering blocks are fine if you are just cruising around, but they increase the leverage the diff has on the springs, making 'spring wind-up' much worse....
serge
Re: Lowering leaf springs? Wed, 29 September 2004 10:05 Go to previous message
Thanks everyone that helps alot. Smile
Previous Topic:Removing the Inlet manifold on a 1G-GTE
Next Topic:AE101 front cut bits (gbox, CV's, driveshafts, struts, brakes etc) will they fit into my AE92 hatch?
Current Time: Mon Oct 19 17:51:17 UTC 2026
Total time taken to generate the page: 0.0042738914489746 seconds
