Toymods » Tech & Conversions » playing with my bush..
Celica_John
playing with my bush.. Thu, 30 September 2004 03:43 Go to next message
I've got my exhaust too close to the idler arm (i think thats what its called) on my ra23. there's a little bit of movement on the arm. the beaurepairs bloke said that i needed a new idler arm to fix my steering alignment. It just seems like it needs a wheel alignment but i've tried that and it was good for 2 days then out again. would it be worth putting in a nolthane, urethane etc bush? or is the only solution to move the exhaust and try some heat shelding?
whats the difference between nolthane and urethane??
is it expensive??
Re: playing with my bush.. Thu, 30 September 2004 05:06 Go to previous messageGo to next message
Nolathane = brand name. Urethane = petrochemical substance they're made out of.
And yes, it's always worthwhile replacing worn rubber bushes with shiny new urethane equivalents. It should make your steering a little more precise.
indigoid
Canberra, ACT
Re: playing with my bush.. Thu, 30 September 2004 07:10 Go to previous messageGo to next message
100% agreed. urethane highly recommended. noltec are another company that does such bushes
http://www.noltec.com.au/
edit: complete set of noltec bushes for the KE26 cost me about $300 from Auto-One 12 months ago. Includes swaybar links, front control arms, tie rod ends, leaf spring eyes, and a few others I have forgotten. The tie rod ends are the most expensive by far. Leave those out and it'll probably be less than $150. Most of them you can install yourself in a single afternoon with regular hand tools. Some you'll need a press for.
[Updated on: Thu, 30 September 2004 07:14]
Celica_John
Re: playing with my bush.. Fri, 01 October 2004 02:55 Go to previous messageGo to next message
cool. I thought they could be more expensive (like everything else with cars)
but do urethane bushes withstand more heat??
Re: playing with my bush.. Fri, 01 October 2004 13:57 Go to previous messageGo to next message
Yeah, urethane bushes are more tolerant, but if they're getting that hot, move the exhaust/do some shielding anyway. I put some Noltec front lower arm bushes in my KE70 today, cost an astronomical $22 for the pair.. And sure can feel the difference.
sideshow
Re: playing with my bush.. Fri, 01 October 2004 14:17 Go to previous messageGo to next message
just watch out when fittin nolethane bushes on steering arms
i used to run them on my 1600 but went back to std rubber ones
the rubber ones are all glued together so when u turn the steering it twists the rubber then when u let go the rubber stretches back to straight position
with urathane bushes it doesnt do this
its not much but when working on rally cars we tried to run rubber bushes for better feel
Siktoy ra23
Plumpton/sydney
Re: playing with my bush.. Fri, 01 October 2004 14:20 Go to previous message
I agree with sideshow
Get a new set from toyota they are much better
Previous Topic:What would cause paint to go like this?
Next Topic:1G ct26 twins, your thoughts
Current Time: Fri Oct 16 12:03:09 UTC 2026
Total time taken to generate the page: 0.0055339336395264 seconds
