Toymods » Tech & Conversions » Ford AU Twin Thermo's
Ford AU Twin Thermo's Thu, 30 September 2004 06:06 Go to next message
Anybody know how much current AU fans draw?
Here is the result of mine.
http://oz-enet.com.au/~peewee/fuse_1.jpg
http://oz-enet.com.au/~peewee/fuse_2.jpg
Fans were running for about 2 mins MAX.
I currently have one 40A relay, and a 25A fuse powering these.
Should I convert to separate relays and fuses for each?
bmak
Re: Ford AU Twin Thermo's Thu, 30 September 2004 06:38 Go to previous messageGo to next message
yeah they draw a fair bit of current.
Last time i set some up i used 2 relays & 40 amp fuses i think
Re: Ford AU Twin Thermo's Thu, 30 September 2004 06:39 Go to previous messageGo to next message
Ok then
2 relays it is.
Re: Ford AU Twin Thermo's Thu, 30 September 2004 07:01 Go to previous messageGo to next message
PWNED
Laughing Laughing
Re: Ford AU Twin Thermo's Thu, 30 September 2004 07:15 Go to previous messageGo to next message
oops!!
DC fans pull
12" = 9amps
14" = 11amps
16" = 19amps Shocked
they say these are maximum current, but not if it's continuous maximum.. the peak current on starting might be a lot higher..
do you have a multimeter that can take 20amps? connect inline and see?
Chris Davey
sunny coast, qld
Re: Ford AU Twin Thermo's Thu, 30 September 2004 08:03 Go to previous messageGo to next message
That is unreal!!!
I have a 25amp on one 14" Davies Craig thermo fan, is this alright? it hasn't blown yet but I hope it isn't too big?
Cyber-punk
Brisbane, QLD
Re: Ford AU Twin Thermo's Thu, 30 September 2004 08:29 Go to previous messageGo to next message
Chris Davey wrote on Thu, 30 September 2004 18:03
That is unreal!!!
going by oldcorollas recomendation, i'd say its too big
if what old doc says is true...then downsize to a 15A fuse
Re: Ford AU Twin Thermo's Thu, 30 September 2004 08:40 Go to previous messageGo to next message
oldcorollas wrote on Thu, 30 September 2004 15:15
oops!!
DC fans pull
12" = 9amps
14" = 11amps
Well, they are 12.5-13" fans.
And no, I don't have a 20A DMM only a 10A.
I have now converted to 8guage power wire (bout to go buy the fuse holder), a twin input/output relay, and wired both power and earth for each fan independantly.
So it should be all good.
Previous was a 12" Davies Craig fan with a 10A fuse, and that was what came in the pack.
Cyber-punk
Brisbane, QLD
Re: Ford AU Twin Thermo's Thu, 30 September 2004 08:42 Go to previous messageGo to next message
CrUZsida wrote on Thu, 30 September 2004 18:40
oops!!
DC fans pull
12" = 9amps
14" = 11amps
well if the amps he listed are for startup then a 10A fuse should be more than enough. 9A seems like alot of current draw for a pissy little 12" fan to continuously draw
sideshow
Re: Ford AU Twin Thermo's Thu, 30 September 2004 08:44 Go to previous messageGo to next message
another thing to look out for is
when u buy thermo fans
no matter how big the thermo they supply the same fuse holder
when u start running twin fans or similar i hVE COME ACROSS THE FUSE HOLDERS MELTING TOO
thats y i always use 30 amp fuse holders
Re: Ford AU Twin Thermo's Thu, 30 September 2004 09:25 Go to previous messageGo to next message
Cyber-punk wrote on Thu, 30 September 2004 16:42
The amps he listed is for running.
Its about 6 times FLC on startup.
But its only for a fraction of a second.
But I now have a 60A fuse holder, and a 40A fuse.
So it *should* all be good
Cyber-punk
Brisbane, QLD
Re: Ford AU Twin Thermo's Thu, 30 September 2004 09:42 Go to previous messageGo to next message
CrUZsida wrote on Thu, 30 September 2004 19:25
go overkill Very Happy
still think my fuse and fuse holder ownz0r
Re: Ford AU Twin Thermo's Thu, 30 September 2004 10:03 Go to previous messageGo to next message
Ok, these thermo's ROCK
Let the car warm up to half way between normal and hot (3/4ish on the guage).
Laptop read out was 100degC.
Turned the thermo's on, the guage dropped back to normal in about 10 secs, and the laptop temp went down to 88 over about 2 mins.
Highly recommended
Re: Ford AU Twin Thermo's Thu, 30 September 2004 11:15 Go to previous messageGo to next message
yeah, the au thermos move a shitload of air Smile
the fact that they're almost a direct bolt up to an ma61 rad is also a good thing Smile
Re: Ford AU Twin Thermo's Thu, 30 September 2004 11:26 Go to previous messageGo to next message
wow... i did the melted fuse thing with a 16" Davies Craig ... happened on bloody hot brisbane summer's day so i had to drive home in 5 minute hops.
it was 20 amp fuse in the socket that came with the fan... i'll have to photo it now Wink
Re: Ford AU Twin Thermo's Thu, 30 September 2004 13:51 Go to previous message
I did the same thing with the fuse to my fuel pump in the Corolla - damned cheap flimsy Dick Smith fuseholder and fuse = bad news.. And that was only a smallish fuel pump..
Previous Topic:Beginner's Dummys Guide to Repairing Celicas. Please point and laugh.
Next Topic:ae86 clutch question
Current Time: Fri Nov 20 10:39:27 UTC 2026
Total time taken to generate the page: 0.0092110633850098 seconds
