Toymods » Tech & Conversions » turn oil drain in sump...what size
people100
Rocklea qld
turn oil drain in sump...what size Thu, 30 September 2004 09:41 Go to next message
as the subject says. Whats a good size pipe to put in my sump as a drain for the oil off the turbo??
ChuckLandwehr
Re: turn oil drain in sump...what size Thu, 30 September 2004 11:20 Go to previous messageGo to next message
Ideally, the same size as your turbocharger oil drain pipe.
Chuck.
YelloRolla
On your mum!
Re: turn oil drain in sump...what size Thu, 30 September 2004 12:23 Go to previous message
Chuck is quite correct - oil cooled and plain bearing turbos require the shifting of a lot of oil and have large drain pipes (as the oil is delivered at high pressure and only uses gravity to get it back to the sump). I have used 3/4" (19mm) for plain bearing turbos and I use 1/2" for the roller bearing - seems to work fine.
Previous Topic:MX73 Electrical Wiring diagrams available for both 5M-E and 5M-GE
Next Topic:original phillips tape deck
Current Time: Fri Nov 20 06:59:51 UTC 2026
Total time taken to generate the page: 0.0047550201416016 seconds
