Toymods » Tech & Conversions » 22R - Bottom End (ConRod) Power & RPM Tolerance ???
ed_ma61
Lost in the K hole
icon5.gif  22R - Bottom End (ConRod) Power & RPM Tolerance ??? Thu, 30 September 2004 13:28 Go to next message
Anyone have any thoughts or statements on the following??
- strength of 22r rods
- design flaws and or failure points of 22r rods
- pics of a 22r rod
- achievable/sustainable RPM of stock 22r rods
- achievable HP on a stock 22r bottom end
anyone have a dead 22r sitting around i can yank the rods out of for a look ??
ed
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Thu, 30 September 2004 13:52 Go to previous messageGo to next message
Does 22R have the same bottom end than 20R?
At least 20R has bad rod to stroke ratio (1.55). By eyeballing my Haynes manual I'd say that the 20R and 18R has the same rods. How about 22R, I dont know.
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 02:08 Go to previous messageGo to next message
ive got no idea Confused
i do know that the 22r has the correct size rod for what im looking for.
does anyone else know if the 22r rod is interchangeable with other r series engines? questions above still stnad also Smile
ed
Stefan
Hobart, Tas
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 02:14 Go to previous messageGo to next message
Ed, go to www.celicas.org, sign up to the OCC list and ask away, They're the 2xR experts; as a lot of OCCers have been there, done that, they should be able to tell you everything you need.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 02:19 Go to previous messageGo to next message
I'd have to go home and measure up my fucked 21R rod...
The 21R and 22R rods are the same deal.
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 02:28 Go to previous messageGo to next message
viper - if you get around to it, if you could measure the centre to centre length of a 21r rod and post it up, it would be appreciated.
a pic wouldnt go astray either Smile
me go sign up to that other list now (OCC forum currently down)
ed
[Updated on: Fri, 01 October 2004 02:31]
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 03:49 Go to previous messageGo to next message
no worries
also OCC = old celica club
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Fri, 01 October 2004 16:35 Go to previous messageGo to next message
How long is 22R rod? how about big end bore? Ed do you have any measurements for 7M rod?
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 02:51 Go to previous messageGo to next message
bugger! i misread the dimensions No No No
different catalogues seem to vary between dimensions based on crank PIN diameters, and others on rod TUNNEL diameters Sad
22r is no longer what im after... but here are the specs anyway. feel free to add your own rod spec data to build up a small database Very Happy
22r rod specs:
CC length: 5.819"
BE Pin Dia: 2.0857"
BE Tunnel Dia: 2.2047"
BE Rod Width:
BE Bearing Width: 0.866"
SE Pin Dia: 0.8656"
SE Tunnel Dia: 0.9449"
SE Bearing Width: 1.130"
SE Rod Width:
7m rod specs:
CC length: 5.984"
BE Pin Dia: 2.0466"
BE Tunnel Dia: 2.1659"
BE Rod Width: 0.975"
BE Bearing width: 0.783"
SE Pin Dia: 0.8661"
SE Bearing Width: 0.994
SE Rod Width:
2jz rod specs:
CC length: 5.590"
BE Pin Dia: 2.0465"
BE Tunnel Dia: 2.1663"
BE Rod Width: 1.020"
BE Bearing width: 0.760"
SE Pin Dia: 0.866"
SE Tunnel Dia:
SE Rod Width: 1.020"
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 03:05 Go to previous messageGo to next message
clipboard of bits of info ive found:
Chevy L4/L6 153/194/230/250
CC length 5.700"
BE Tunnel Dia 2.125"
BE Pin Dia 2.000"
BE rod width 1.029"
SE Pin dia 0.927"
Chevrolet 250 straight 6 cyl
CC Length: 5.700"
BE pin 2.000"
BE width 1.029"
SE pin 0.927"
[Updated on: Sat, 02 October 2004 03:10]
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 11:16 Go to previous messageGo to next message
Ovlov connecting rods.
Engine type: B17, 19, 21, 23 (OHC)
75-85
240, 300 and 700
CC length: 145 mm
BE Pin Dia: 54 mm
SE Pin dia: 24 mm
B200, B230
85-88
200, 300, 700
CC length: 152 mm
BE Pin Dia: 49 mm
SE Pin dia: 23 mm
B200, B230 "K-block"
89-98
200, 300, 700, 900
CC length: 152 mm
BE Pin Dia.: 49 mm
SE Pin dia: 23 mm
All above are inclined engines (opposed to perpendicular engines). Connecting rod material changed from -80-> to more robust. Connecting rod are the same in NA and turbo engines. Vulva connecting rods are noted as a strong connecting rods.
BlackSupra
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:02 Go to previous messageGo to next message
go on ed, flaw a good factory design Razz
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:15 Go to previous messageGo to next message
"good" factory design being the very point...
ahhh glen, if only you could appreciate the beauty of what it is to build a 'proper' NA motor Twisted Evil
BlackSupra
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:23 Go to previous messageGo to next message
I decieded to leave the N/A's for the little girls.
Im 'building' a real motor. Cool
Good luck with your rod search, but 2jz rods will be fine for me Smile
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:37 Go to previous messageGo to next message
and why are the 2jz rods 'fine for you' ?
what is it about the 2jz rod that suits your 'build' so 'nicely'
Cool
BlackSupra
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:39 Go to previous messageGo to next message
ability to take the power im going to dish to them.
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:42 Go to previous messageGo to next message
Ed, I assume that you're improving your rod to stroke ratio. May I ask what is the ratio that you're targeting?
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:43 Go to previous messageGo to next message
and thats all there is to rod selection?
kool Cool
BlackSupra
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:48 Go to previous messageGo to next message
7000rpm is fine for me
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:49 Go to previous messageGo to next message
Jayem wrote on Sat, 02 October 2004 22:42
now here's a man who knows what hes talking about Nod
aiming for 1:1.73 (stock 2jz is 1:1.64)
thats the tallest i can get with stock deck height and 'reasonable' pistons - ie compression height around 29mm.
the intake will be a high velocity type, and obviously some well calculated cam timing to suit - which im yet to fully get my head around. ill be talking to a few cam people about that - theres simply no way i can figure it out myself Confused
looking at redline around 8500
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 12:54 Go to previous messageGo to next message
glen - common dude - theres a shitload more to rod choice than just that Smile
sure stock rods 'will do', no debating it, but its another ballpark to start looking at how you want the engine to behave, what intake youre going to run, how you want the cyls to fill, and what kind of power you want, where in the rpm band.
dont diss a guy for optimising an assembly - its hardly goping to fault the design Twisted Evil Twisted Evil
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 13:24 Go to previous messageGo to next message
So you need 157.5mm long conrods...
Im considering 1:1.81 which means 16deg rod angle. Pretty ideal I say. I havent yet sort out the skirt clearance. Compression height is no problem for me.
ed_ma61
Lost in the K hole
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 13:37 Go to previous messageGo to next message
jayem - this is for a 2jz, not a 7m, so the rods dont need to be quite THAT long Shocked
more around the 148/149mm mark
id like to reach 16deg, but im going to have to settle for 16.5deg - simply not physically possible
whats the rest of the engine designed like around that 1.8??
ed
Jayem
Finland
Re: 22R - Bottom End (ConRod) Power & RPM Tolerance ??? Sat, 02 October 2004 13:40 Go to previous message
Ok! Laughing
I was thinking that where the hell is he going to find that long rods...
Laughing
Previous Topic:R154 Heavy Duty Bearing Coverplate
Next Topic:4AGZE Igniter
Current Time: Mon Oct 19 10:58:23 UTC 2026
Total time taken to generate the page: 0.064910173416138 seconds
