Toymods » Tech & Conversions » Rear discs vs. better fronts
matt_84
Ipswich
Rear discs vs. better fronts Fri, 01 October 2004 04:14 Go to next message
After calling an engineer regarding a 1g-gte --> ra28 conversion, I was told brake wise, he would want to see rear dics.
I asked if I could do a front brake upgrade instead, but he said no, to pass it, he would want to see rear discs, instead of a front brake upgrade.
My question is why? Don't the front brakes do 90% of the braking?
rob_RA40
c'town, NSW
Re: Rear discs vs. better fronts Fri, 01 October 2004 04:16 Go to previous messageGo to next message
im not sure i follow 100%, to clarify here...
so the engineer said he'd be happy with stock front brakes as long as u put rear disks on?
....find another engineer....
ke382TG
Re: Rear discs vs. better fronts Fri, 01 October 2004 04:18 Go to previous messageGo to next message
I agree with the above, it does sound like a strange request (if the fronts are being left standard).
matt_84
Ipswich
Re: Rear discs vs. better fronts Fri, 01 October 2004 04:35 Go to previous messageGo to next message
Thats what I thought. I would much rather put money into front brakes, than doing a rear disc conversion.
And yeah, he said that as long as it had rear discs, he'd pass it. On stock fronts. Confused
[Updated on: Fri, 01 October 2004 04:36]
Re: Rear discs vs. better fronts Fri, 01 October 2004 04:43 Go to previous messageGo to next message
that is odd, but i'd want rear discs as well Wink
i hate drums, and to have a rear drum lock up kinda negates having any front brakes (when the car starts spinning)
find an engineer who wants both front and back upgraded Very Happy
hemi twofifteen turbo
Re: Rear discs vs. better fronts Fri, 01 October 2004 07:47 Go to previous messageGo to next message
maybe kill 2 birds with one stone since the stock diff is
going to go anyway, maybe shorten a VN diff? (cheap, stong, and comes stock with discs).
Re: Rear discs vs. better fronts Fri, 01 October 2004 08:51 Go to previous messageGo to next message
There are still some people out there that believe the old idea that '4 wheel discs' = good brakes. Oh dear..
IRA11Y
Club Member
Re: Rear discs vs. better fronts Fri, 01 October 2004 22:50 Go to previous messageGo to next message
Well .... any 4 disc combination will in most cases out peform a standard front disc and rear drum setup... but thats assuming you spend the time and money to set up the brake biasing correctly as well, its not a cheap and easy way to increase your braking power unless its a simple factory upgrade option somewhere along the line.
However.. If I were planning the conversion you are I would probhably opt for rear discs as well as upgrading the front, I suspect the engineer is trying to make sure you have plenty of stopping power so that you wont get yourself into a difficult situation... remeber that he doesent know what your driving abilities are so hes probhably trying to make sure both you are going to be safe and hes going to be covered from a lawsuit point of view.
Re: Rear discs vs. better fronts Sat, 02 October 2004 12:09 Go to previous messageGo to next message
It's obvious why he wants a brake upgrade (I think we'd all agree it's wise), but the weird thing is he won't allow a front brake upgrade while leaving the rears stock, which would clearly be far more beneficial than just upgrading the rears!
I agree though, upgrading both is the best way to go... if you can afford it.
Re: Rear discs vs. better fronts Sat, 02 October 2004 12:55 Go to previous messageGo to next message
matt,
<Kirk> from these forums dropped an 1G-GTE into his Ra28:
<http://www.eviltrip.com/77/>
i've not seen many posts from him on the forum lately, but he might respond to an email.
i9 think he did his conversion legit so he might know of a suitable engineer.
cheers,
Charles.
matt_84
Ipswich
Re: Rear discs vs. better fronts Sat, 02 October 2004 15:03 Go to previous messageGo to next message
IRA11Y, what I was confused about was why rear discs would be preferable to a front brake upgrade. I know its not ideal to have a one or the other situation, but currently, it is. I thought due to the nature of braking systems, an equivalent amount of dosh in front/rear brakes would show a marked benefit in investing in the fronts?
Norbie, yeah, thats what I thought. I know i'd much rather put money into front brakes over rears. Although with a bit or searching, the volvo diff option so often proclaimed by a single pundit on these forums may be worth investigating. Both front and back may then be (financially) feasible.
Charles, i'll give him a go. Its either that or try explaining to an engineer why I think he's wrong. Ha. I think i'm gonna have to find another engineer.
Chris Davey
sunny coast, qld
Re: Rear discs vs. better fronts Sat, 02 October 2004 22:45 Go to previous messageGo to next message
When I did my conversion I was told that I needed to have the same size brakes as the donor car from which the engine came. So in my case, I needed to have the same size brakes as a jzx90 chaser. Of course the engineer didn't know what size they were so jza70 supra then. This was only for the front brakes as far as I am aware. However, I already had a rear disk conversion with a Pajero diff and brakes which are large solid rotors and big single pistons.
I would be asking another engineer.
allencr
tallahassee FL usOFa
Re: Rear discs vs. better fronts Sun, 03 October 2004 00:25 Go to previous messageGo to next message
engineer?????
did he win a contest/drawing, or get a certificate from a cereal box?
Re: Rear discs vs. better fronts Sun, 03 October 2004 01:55 Go to previous messageGo to next message
The engineer I spoke to about my 2JZ conversion told me that provided the car is post-77 (when some brake-related ADR came into effect), and provided the engine fits within the 2.5x/3x rule, a brake upgrade is not required for engineering in Qld!
I'm still doing a brake upgrade of course, and it would be a top priority if I was turbocharging an old Celica. Wait a minute, I am turbocharging an old Celica. Laughing Luckily I already have a brake upgrade (MA61 fronts) since the stockers were barely adequate for a stock 18R-G.
gold28
Madrid - Spain
Re: Rear discs vs. better fronts Tue, 05 October 2004 11:41 Go to previous messageGo to next message
While it is important that Engineers advise whats best for safety, they do have to work within certain guidelines. He probably has a good reason for making the request he has and it may be to satisfy a legal requirement in your state. Ask him to explain the regulations to you if you doubt him.
If all he wants is rear discs, the setup from a RT141 corona will pretty much bolt on. do a search and all the tricks will be revealed. I would definitly look into a front upgrade to go with it though. The standard ones have been the undoing of many a nice celica. And if your paying for an engineers certificate for a brake upgrade it may as well be a good one.
Oh and just with the engineering, what made you think that we would know better than a paid professional??? If you doubt him ask for his reasons. In the end, it doesn't matter what we think cos we can't give you a certificate to say it's legal.
Re: Rear discs vs. better fronts Tue, 05 October 2004 11:54 Go to previous messageGo to next message
mrshin wrote on Fri, 01 October 2004 18:51
as far as i'm concerned, 4 wheel discs = better than 1 warped drum Wink
a warped drum will probably lock easier than a warped disc..
there is also the other problem of the leading shoes in the drums enhancing the braking effect, such that the braking force is not proportional to the applied force.
whilst drums may be more efficient for braking in terms of input force, a disc will be far more linear in it's braking effect..
sure the fronts may do around 70-80% of braking, but if your rears lock first, you are rooted Wink
river
Land of Oz
Re: Rear discs vs. better fronts Tue, 05 October 2004 12:44 Go to previous message
Drums are better at braking due to the more contact area the shoes have with the drum. Problem is the drum is not good at disapating the heat and with hard and continual application they get too hot and warp the drum, boil the fluid. Not good.
So, for normal driving, rear drums are fine. But, I agree with the others, the front brake upgrade would be better. Also get rear discs if you're gonna be doing a lot of hard braking. Also, if the engineer wants it, and he won't pass it without it, then I suppose you just gotta get rear discs.
seeyuzz
river
Previous Topic:Head Reco, gaskets help 4K
Next Topic:4age Starting problem
Current Time: Sat Nov 21 03:51:39 UTC 2026
Total time taken to generate the page: 0.0078539848327637 seconds
