Toymods » Tech & Conversions » Do i use a grinder to install ducktail wing for my ae86?
Satoshi
Do i use a grinder to install ducktail wing for my ae86? Fri, 01 October 2004 10:55 Go to next message
what is the best method to put on the ducktail wing? rivet, self tappered screw (i heard from a friend), sikaflex...what else??
do i need to drill a hole to put the rivet through my rear hatch?
[Updated on: Sat, 02 October 2004 16:45]
ae95
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:02 Go to previous messageGo to next message
double sided tape
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:03 Go to previous messageGo to next message
sillyputty
Steve-AE86
Ademelaide, SA
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:05 Go to previous messageGo to next message
liquid nails
Skaney
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:08 Go to previous messageGo to next message
zip ties
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:30 Go to previous messageGo to next message
Lackie Strap Laughing
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:31 Go to previous messageGo to next message
Hubba Bubba, but only original.
Rex_Kelway
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:44 Go to previous messageGo to next message
Mix some flour and water into glue.
WiLo
wollongong NSW
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:52 Go to previous messageGo to next message
someone give a proper answer please
Re: Installing Ducktail for AE86 Fri, 01 October 2004 11:55 Go to previous messageGo to next message
But.. I can't wait till the next episode of Cooking with Rex(tm)..
MFX_Neko_86
Liverpool, Sydney
Re: Installing Ducktail for AE86 Fri, 01 October 2004 12:00 Go to previous messageGo to next message
It depends how you want the finished product to look... whether you want the pop-riveted look or it all flush... to get a good result i believe it is best to have to drill thru the boot...
If you want the pop riveted look then make marks (evenly spaced) and drill thru the wing and the boot, then pop - rivet.. sikaflex is up to you...
Or the flush look ( which i will be going for) get your wing to fir properley then drill thru the wing and boot all the way around with self tappers( like a trial fit) then pull off and sikaflex, then redrill the self tappers in and leave overnight... pull out the tappers the next day and nicky smooth...
sounds easy enough right?
Black sikaflex is the best, its the toughest....
Satoshi
Re: Installing Ducktail for AE86 Fri, 01 October 2004 12:57 Go to previous messageGo to next message
MFX_Neko_86 wrote on Fri, 01 October 2004 21:30
thanks neko (sounds like japanese girl Smile )
i have no idea what's self tappered is..but i'll bust out Bunnings to cuff those salesman and question them when i got time..cheers
Simon-AE86
Banned user
Re: Installing Ducktail for AE86 Fri, 01 October 2004 14:22 Go to previous messageGo to next message
does this mean that tomorrow we'll see a thread from you titled
"which section do i find selftapping screws in bunnings?"
driftae86
perth
Re: Installing Ducktail for AE86 Fri, 01 October 2004 15:42 Go to previous messageGo to next message
MFX_Neko_86 wrote on Fri, 01 October 2004 22:00
so... in the end it is just the sikaflex that is holding it on?
[Updated on: Fri, 01 October 2004 15:43]
Satoshi
Re: Installing Ducktail for AE86 Fri, 01 October 2004 16:27 Go to previous messageGo to next message
Simon-AE86 wrote on Fri, 01 October 2004 23:52
u really got sense of humour... Freak
Satoshi
Re: Installing Ducktail for AE86 Sat, 02 October 2004 01:34 Go to previous messageGo to next message
Steve-AE86 wrote on Fri, 01 October 2004 20:35
liquid nails
i just found out what liquid nails was...initially i thought it was liquid fingernails... Laughing Laughing Laughing
silly me.. Rolling Eyes
MFX_Neko_86
Liverpool, Sydney
Re: Installing Ducktail for AE86 Sat, 02 October 2004 03:26 Go to previous messageGo to next message
If you choose to do it that way, yes, the sikaflex with be the only tihng holding it on, but it is dtrong, i mean, if you wanted more you could always countersink screws but that would be prone to cracking the bog eventually..... plus you'd have to find screws that were smalll enough to sit flush with the wing, and that you could still have space to smooth over...
Self tappers are good because you dont have to pre-drill a hole, you can just hold the wing on and start drilling, and it will drill itself thru the wing and the boot....
How'd you go Satoshi?
Arch
Re: Installing Ducktail for AE86 Sat, 02 October 2004 04:08 Go to previous messageGo to next message
Satoshi wrote on Sat, 02 October 2004 01:57
Actually his sense of humour is spot on! Wink
Satoshi
Re: Installing Ducktail for AE86 Sat, 02 October 2004 09:41 Go to previous messageGo to next message
as i never used self tapper screws before..i use a driller to drill a few holes unto my hatched and after a few push...i broke the drill pin..the reason why i did this way was because at first i tried using the screw tapper but it wouldnt stay..what a biatchhhh
since now i know i dont need to pre-drill a hole...i'll go borrow the drill back from my mate...
Skein
Re: Installing Ducktail for AE86 Sat, 02 October 2004 10:22 Go to previous messageGo to next message
I admire your ability to jump into a task like this that involves drilling holes into your car with very little knowledge on the subject.
ed_ma61
Lost in the K hole
Re: Installing Ducktail for AE86 Sat, 02 October 2004 11:05 Go to previous messageGo to next message
aside from the usual useless dribble, i love that specific reference to the 'black sikaflex'
oh yeah baby!
MFX_Neko_86
Liverpool, Sydney
Re: Installing Ducktail for AE86 Sat, 02 October 2004 16:01 Go to previous messageGo to next message
Yeah drilling holes sucks.... one time when we were using pop riverts we were trying to pre-drill the holes and we ended up snapping about 4 or 5 drill bits.... they werent tuff enuff!!
Laughing Laughing Laughing Hey why not? Taking an angle grinder to it would be worse..... Laughing
Satoshi
Re: Installing Ducktail for AE86 Sat, 02 October 2004 16:41 Go to previous messageGo to next message
Skein wrote on Sat, 02 October 2004 19:52
hmm....are you being sarcastic...or u really admire me like a HERO, RAMBO, SUPERMAN,POKEMON, that kinda admire? Razz
well...i take everyday as a learning experience + i have little to non DIY friends to seek help from other than this forum..hence u guys are here to help me out..
angle grinder in replacement of self tapper screws? Laughing Laughing u are a cool funny chiq.. Smile
MFX_Neko_86
Liverpool, Sydney
Re: Do i use a grinder to install ducktail wing for my ae86? Sat, 02 October 2004 17:03 Go to previous messageGo to next message
No, i didnt mean in replacement of the self tappers, i meant take the grinder, cut off the end of your boot and use the wing as a replacment end... just graft it on with metal tabs..... or gaffa tape.. or something.... Very Happy
Satoshi
Re: Do i use a grinder to install ducktail wing for my ae86? Sat, 02 October 2004 17:25 Go to previous messageGo to next message
i think i'll just use duct tape and tape my ducktail instead of self tappers...just incase i see defect station around..i can always just pull it off...and put them back in in less than 5 mins...
DUCT TAPE BODYKIT Pty Ltd Very Happy
Cyber-punk
Brisbane, QLD
Re: Installing Ducktail for AE86 Sun, 03 October 2004 10:36 Go to previous messageGo to next message
ed_ma61 wrote on Sat, 02 October 2004 21:05
oh yeah baby!
everytime i hear the word sikaflex i get the giggles
sounds so ricey Very Happy
Satoshi
Re: Installing Ducktail for AE86 Sun, 03 October 2004 11:16 Go to previous messageGo to next message
Cyber-punk wrote on Sun, 03 October 2004 20:06
oh yeah baby!
giggle? maybe u are ghey wif teh aids.. Laughing Laughing
clubagreenie
1st street on the right
Re: Do i use a grinder to install ducktail wing for my ae86? Sun, 03 October 2004 21:13 Go to previous messageGo to next message
Just make sure you get the sikaflex adhesive, not the sealant. Perhaps they could market it specifically for ricers "fullysikaflex". Each pack is only half full, therby reducing weight giving you the powah and handling you deserve.
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: Do i use a grinder to install ducktail wing for my ae86? Mon, 04 October 2004 07:16 Go to previous message
clubagreenie wrote on Mon, 04 October 2004 07:13
Hands together for clubgreenie
Previous Topic:2t/2tg questions
Next Topic:1MZFE/ 3VZFE celica
Current Time: Fri Nov 20 22:31:25 UTC 2026
Total time taken to generate the page: 0.0088629722595215 seconds
