Toymods » Tech & Conversions » difference between horizontal and vertical Webers
mark-ke30
Eindhoven
difference between horizontal and vertical Webers Fri, 01 October 2004 10:59 Go to next message
who knows the difference between horizontal and vertical Webers.
right know i have the standard carburetor of the 3k-h motor. i can buy the SR intake manifold and twin Weber's (vertical).
what is the advantage of these conversion???
thnx Mark
Re: difference between horizontal and vertical Webers Fri, 01 October 2004 12:07 Go to previous messageGo to next message
The terms you're looking for are sidedraught (horizontal) and downdraught (vertical).
Sidedraughts are great for top-end power because they offer the shortest and most direct path from the throttle plates to the inlet valves, with no major changes of direction in between. This has some disadvantages in terms of bottom-end driveability and fuel economy, not to mention the extra manufacturing cost and space issues (they make the engine very wide), which is why downdraught carbs are much more common on production cars.
indigoid
Canberra, ACT
Re: difference between horizontal and vertical Webers Fri, 01 October 2004 16:02 Go to previous messageGo to next message
eh? I shouldn't think that it's the sidedraftness that kills bottom end... more that they are being used for racing and therefore setup as such, with big chokes for big top end power! just pick the correct choke size for your application.
edit: sidedraft also tends to mean expensive Sad sure, you can pick up a cheap pair of Dellortos on ebay, maybe even with rebuild kits included, but then you're going to want to change jet and probably choke sizes at least once or twice. the bits aren't nearly as commonplace, == more expensive than for downdrafts
[Updated on: Fri, 01 October 2004 16:06]
mark-ke30
Eindhoven
Re: difference between horizontal and vertical Webers Mon, 04 October 2004 15:06 Go to previous messageGo to next message
thnx,
i'm getting downdraught webers. I don't know the size of the webers yet. I get it by mail this week. But does anybody know how much increase in hp ther will be???? And which k&n air filters i should use??
thnx
Mark
indigoid
Canberra, ACT
Re: difference between horizontal and vertical Webers Mon, 04 October 2004 15:36 Go to previous messageGo to next message
you're buying them and you don't know what they are?!
IDA? IDF? DGV? DFV? ADM? ADFA?
determined by entirely tuning, which in your case will mean changing jets and possibly emulsion tubes and venturis until you get it running properly.
the appropriate part for the carbs you are getting. at this stage, though, filters are the last thing you need to worry about. rather, you should be contemplating sourcing of appropriate jets, throttle linkages, fuel hose + fittings, and possibly fuel pressure regulator, possibly fuel pump. Some Weber carbs are notoriously picky about fuel pressure.
I also highly recommend purchasing Haynes Techbook #10240. It covers a great variety of Weber carbs, sidedraught and downdraught, in excellent detail, including rebuild and tuning instructions. You'll be needing it. Really.
mark-ke30
Eindhoven
Re: difference between horizontal and vertical Webers Mon, 04 October 2004 15:42 Go to previous messageGo to next message
I not only buy the webers, i buy the complete set, wich I can directly bolt on my 3k.
But now i think it isn't easy to make these carbs run.
I think i call some one who has (any)knowledge about this.
and i thaught it was so easy Shocked Shocked
thnx
Mark
mark-ke30
Eindhoven
Re: difference between horizontal and vertical Webers Tue, 05 October 2004 19:04 Go to previous messageGo to next message
the webers are 36mm...
does this help??
Mark
indigoid
Canberra, ACT
Re: difference between horizontal and vertical Webers Wed, 06 October 2004 00:00 Go to previous messageGo to next message
not really. what model are they?
c2888
Re: difference between horizontal and vertical Webers Wed, 06 October 2004 01:58 Go to previous messageGo to next message
The main difference between the two are mainly for packaging purposes. You want the straightest path as well, but sometimes that gives way to fitment issues.
In some cars it's possible to fit sidedrafts, some cars it's not.
Then you get downdrafts, they are the same carb, but the float chambers are designed to work when the carb is mounted vertically.
Your local library should have a few books about weber carbs.
dodgydan
mark-ke30
Eindhoven
Re: difference between horizontal and vertical Webers Thu, 07 October 2004 18:08 Go to previous messageGo to next message
36 DCNF is the type of the webers. does thes increase much power???
Mark
allencr
tallahassee FL usOFa
Re: difference between horizontal and vertical Webers Fri, 08 October 2004 03:53 Go to previous messageGo to next message
you are really writing about a single carb. with 2 barrels/chokes/venturies/throats aren't you, not multiple Webers, right???
are both 36mm or is the secondary different?
is the secondary mechanical or vacuum operated?
what size carb is it replacing?
spirokeet
London
Re: difference between horizontal and vertical Webers Fri, 08 October 2004 04:44 Go to previous messageGo to next message
I used to run a golf (1.6) on a 40 DCN Webber carb and it made a big difference in power, response and noise over the standard Solex.
I presume that the 36 DCNF would be a very similar design- twin barrels of equal size. If you are upgrading from a smaller carb you'll get similar benefits, plus Webbers are pretty reliable.
The 40 DCN wasn't particularily good with fuel as both barrels opened at the same time, my girlfriend's '76 2002 is running a 32/36 DGV Webber that is fairly economical (only opens the 36mm barrel on the second half of throttle travel- mechanical link) if that's a concern. Cheaper than a DCN for rebuilds too- the parts are getting hard to find.
As for filter- you'll be best going to somewhere like autobarn/repco,etc and ordering a kit to sit on top for about $30. K&N stuff is complex and v. expensive.
indigoid
Canberra, ACT
Re: difference between horizontal and vertical Webers Fri, 08 October 2004 05:10 Go to previous message
From my Haynes Weber carbs book:
Quote:
The carburettors covered by this chapter are of vertical downdraught typeand each barrel of the carburettor is of identical diameter.
The throttle valves are of the synchronised simultaneous operation type and are located on a single shaft.
The identication mark is located on the main body on the outer face of the float chamber wall.
I'd guess that you'd be wanting very small chokes if you are going to keep the stock camshaft and you are in fact going to use two of these carbs (so four throats). My totally-wild-stab-in-the-dark guess is 24mm, or perhaps even smaller.
edit: if, down the track, you get frustrated with these things and want to get rid of them and their manifold, email me... I may make you an offer. Can't afford it right now though
[Updated on: Fri, 08 October 2004 05:13]
Previous Topic:MR2 Intercooler Query
Next Topic:ISCV Workings - ANSWERS
Current Time: Sat Oct 24 01:38:08 UTC 2026
Total time taken to generate the page: 0.0064420700073242 seconds
