Toymods » Tech & Conversions » R154 Heavy Duty Bearing Coverplate
Skip
R154 Heavy Duty Bearing Coverplate Sat, 02 October 2004 13:35 Go to next message
Found this on marlincrawler 4x4 website, i would assume this is a problem area with R154 if it is a problem with R151 and R150 4WD trannys. I would also assume it will fit the R154, could be wrong though, wouldnt be the first time Smile
Heavy Duty Bearing Cover Plate
Fits R series transmission only (R150F, R151). CNC machined from top quality tool steel and will long out live the factory original. As the factory unit wears out it fails to properly position the main shaft. This heavy duty unit does a much better Job of holding the shaft in the proper position. Includes set of 4 bolts.
Heavy Duty Bearing Cover $35
http://www.marlincrawler.com/images/bearing_cover_500.jpg
Re: R154 Heavy Duty Bearing Coverplate Sat, 02 October 2004 13:46 Go to previous message
I've got a 154 in the backyard, if I remember I'll look at it tomorrow and compare it to this pic
Previous Topic:3s-ge reving too high
Next Topic:22R - Bottom End (ConRod) Power & RPM Tolerance ???
Current Time: Tue Oct 20 22:54:28 UTC 2026
Total time taken to generate the page: 0.0041370391845703 seconds
