Toymods » Tech & Conversions » scary noises
troyboy
Colyton, NSW
scary noises Thu, 26 September 2002 13:39 Go to next message
this started as a rattle this morning when i noticed it in a car park.. had to listen for it..
wheni got home tonight...
well let the sound file sbe the judge...
btw .. its a sc12
anyone got one for sale??
Broken S/C 1
Broken S/C 2
ps the sound files are at idel.. but camera near the sc.. that his is mean to be there... its the scraping noise that u can hear
[Updated on: Thu, 26 September 2002 13:44]
Gased
Re: scary noises Fri, 27 September 2002 14:01 Go to previous messageGo to next message
Don't know your engine.
Could be a collapsed water pump or alternator bearing.
Depending on how it is belted take off all belts except alternator and startup. Don't leave running for too long or else overheat.
Sounds front engine.
David
Gased
Re: scary noises Fri, 27 September 2002 14:08 Go to previous messageGo to next message
Oh, saw your other post.
Yeh collapsed supercharger bearings - add that to the list.
Would the engine run/idle without s/c belt? Try it.
D
Blown86
Re: scary noises Fri, 27 September 2002 15:44 Go to previous messageGo to next message
Doubtful it's the blower, unless the s/c clutch is hard wired it shouldn't be spinning that fast at idle!!
Sounds like you got stuffed water pump.
Check if you can see a slight wobble in the water pump pulley, that may indicate stuffed bearings.
ae102_3sgte
Canada
Re: scary noises Sat, 28 September 2002 02:49 Go to previous messageGo to next message
If the S/C fails:
S/C locks or binds at higher rpm's.
S/C clutch is overloaded and overheats.
Overheated (damaged) bearing in S/C clutch will now make noise at idle even with S/C switched off.
Sometimes the fuse (efi?) will blow if the clutch is shorted to ground.
Please note the IF that started this post.
troyboy
Colyton, NSW
Re: scary noises Sat, 28 September 2002 03:48 Go to previous message
Thanks heaps for all the responses guys...
my mechanic will check it out on Monday and give me the good err bad news...
a quick question...
does a 4age have the same water pump as a 4agze?
Previous Topic:Was the JZA70 SUPRA ever sold in Australia?
Next Topic:Catalytic converters a restriction or not?
Current Time: Sat Oct 24 17:23:57 UTC 2026
Total time taken to generate the page: 0.10834002494812 seconds
