Toymods » Tech & Conversions » will this work if so wat do i need to do
lilcrash
ipswich queensland
will this work if so wat do i need to do Sun, 03 October 2004 08:27 Go to next message
ive found a fully setup head/injection/turbo 3tgte syestem
will this fit onto a 2tgeu bottom end
any info muchly appreciated
thanx
Re: will this work if so wat do i need to do Sun, 03 October 2004 08:53 Go to previous messageGo to next message
Yes it will fit, but I'm not sure about valve-to-piston clearance. The T series gurus will probably be able to tell you.
It might be easier to keep your 2T-GEU head and adapt the 3T-GTE gear around it, since the 2T-GEU head apparently flows better and you don't have to deal with that silly 8-plug setup.
lilcrash
ipswich queensland
Re: will this work if so wat do i need to do Sun, 03 October 2004 10:51 Go to previous messageGo to next message
i have decided to try to bolt the 3tgte manifolds to the 2tgeu and go from there. i just wont be able to go very high with the boost as i dont want to blow up the engine.
any info on this choice please say sumthin
i need to know if i the 3t manifolds will fit.
if they dont fit i wont bother gettin it
thanx
river
Land of Oz
Re: will this work if so wat do i need to do Sun, 03 October 2004 11:15 Go to previous messageGo to next message
Norbie wrote on Sun, 03 October 2004 18:53
... you don't have to deal with that silly 8-plug setup.
Does that actually help, having twin-plugs per cylinder? It's not something you often see on car engines.
seeyuzz
river
SeptemberSquallIndustries
Re: will this work if so wat do i need to do Sun, 03 October 2004 11:22 Go to previous messageGo to next message
Doesn't the Nissan Z18 of the same era also feature twin plug?
Regarding the initial question, the exhaust manifold will fit but the intake manifold won't. You could re-engineer to use a 2T-GEU manifold perhaps.
T APLUS 22
Re: will this work if so wat do i need to do Sun, 03 October 2004 11:48 Go to previous messageGo to next message
sorry to hijack. But the Gazelle featured a 2Lt with twin spark. And more recently i think the Honda Jazz 1.3lt has twin spark.
thankyou. goodbye.
Re: will this work if so wat do i need to do Sun, 03 October 2004 12:48 Go to previous messageGo to next message
Many people who modify 3T-GTE's only use one set of plugs. Apparently the original idea behind the twin-spark setup was to help prevent detonation. An intercooler does a much better job of that though!
As above, the 3T-GTE inlet manifold will not bolt up to the 2T-G cylinder head, but you'll find the 2T-GEU manifold is much more convenient for intercooler piping since it has a front-facing throttle body.
Re: will this work if so wat do i need to do Sun, 03 October 2004 13:05 Go to previous messageGo to next message
I gather the 3TGTE twin plug business had the idea that one set of plugs fired slightly before the others, and under detonation the more advanced set was cut out? or something?
Also on multi plug engines, a couple I can think of are Nissan Z18, Nissan CA20 (bluebird, pintara), and of course not forgetting bloody Alfas! Evil or Very Mad
Re: will this work if so wat do i need to do Sun, 03 October 2004 13:07 Go to previous messageGo to next message
I thought 3T-GT fired the pairs together and presumed it had something to do with the efficiency benefits (ie. complete combustion) resulting from propogation of two flame fronts.
but I dunno really.
Re: will this work if so wat do i need to do Mon, 04 October 2004 07:52 Go to previous message
Yes, the plugs fire at the same time on the 3T-GTE. The idea (as I understand it) is the twin flame fronts have less distance to travel, which means you can run more ignition advance without having problems with detonation. Or something like that. Confused
Previous Topic:hookin up the turbo
Next Topic:2t/2tg questions
Current Time: Fri Nov 20 22:09:24 UTC 2026
Total time taken to generate the page: 0.0091679096221924 seconds
