Toymods » Tech & Conversions » 1g alternator wiring + wiring testing
willwal98
Toowoomba
1g alternator wiring + wiring testing Sun, 03 October 2004 10:18 Go to next message
Can anyone tell me where the three wires go from the back of the alternator on a 1g? There is a yellow one, a black one and a fat white one. There is also a really fat white one on the top white goes to the bat. It is internally regulated so i'm lost as to what the three could be for.
Also I've just finished sorting out the wiring (what a fricken huge job) and was wondering if anyone can give me some tips on testing everything to make sure it works (sensors and the diagnosis plugs) and some trouble shooting tips if they don't?
Gleno28
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 10:23 Go to previous messageGo to next message
try www.sixworks.com.au for diagrams etc
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 10:31 Go to previous messageGo to next message
at a guess, the biggest wire is for charging battery and goes to the battery post.
one wire is definitely for the charge light (grounds when low voltage)
the last wire is most likely for a 'voltage sense" wire.. maybe goes to bat or ignition.. can out a small resistor in it to fool alt into charging with higher voltage Wink.. not sure if this is recommended tho..
willwal98
Toowoomba
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 11:14 Go to previous messageGo to next message
wow thanks. Still didn't tell me what the three wires are but the daignostic stuff is really great. Also one thing I just noticed, on the second page of the 1g-gte wiring diagram there is a connection (near the top) that says 'ECT' and idea that that one is?
EDIT
Must have got in while I was typing oldcorollas. There are three coming out of the back and the big fat one on top (fourth wire) is the charing wire. So out of the other two I would have a charge light and possibly a coltage sense wire. Any idea what the third could be? Also the the black and yellow ones are still quite thick, 4mm ish, the white one is about 6mm (charging wire of course is bigger than that again).
[Updated on: Sun, 03 October 2004 11:19]
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 11:20 Go to previous messageGo to next message
where is this diagram you speak of? doesn;t it have wire colours there??
willwal98
Toowoomba
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 11:45 Go to previous messageGo to next message
http://www.sixworks.com.au/1GGTE_Gen_3.pdf
page two
6th wire down (pin 7)
colour is LG
sideshow
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 14:42 Go to previous messageGo to next message
fat white to battery
yellow to charge light
black with yellow trace to ignition
willwal98
Toowoomba
Re: 1g alternator wiring + wiring testing Sun, 03 October 2004 22:10 Go to previous messageGo to next message
thanks sideshow. Exactly what I was after.
One more quick Q. Also in that PDF on page one. Top left hand corner there is the ignition switch (I assume it's just the ignition key connection). This bit confused me a little bit. In the diagram there is a black-white wire from the ECU that goes to the 7.5a starter fuse then back to the black wire (Starter STA) on the ECU, Now all I should have to do is join those two wires and run a wire from the start position on the key through a fuse to those two wires correct?
And I also would have to run a wire from the igntion positing on the key through a fuse to that black-red wire right?
The diag is a a little confusing in that area.
Crossy
Re: 1g alternator wiring + wiring testing Fri, 29 October 2004 14:02 Go to previous messageGo to next message
sideshow wrote on Mon, 04 October 2004 00:42
hey you reckon someone could help me out with which wire goes to which pin on the back on the alternator... cause i got no loom at all for the alternator so dun have the plug and don't know which pin to run the above wires from
and also... the 'ignition' wire is that just 12V supply to the alternator when ignition is on
or does that give power to the ignition?
thanx
MaT
[Updated on: Fri, 29 October 2004 14:06]
flynn21atwork
Re: 1g alternator wiring + wiring testing Sat, 30 October 2004 05:32 Go to previous messageGo to next message
I just recently did all this, all the wire colours in the diagram were totally different colours to the loom I had. It was definatley the right loom. I ended up running alot of wires myself and pissing certain sections of the loom off, as I kept getting magical wires that went in and did not reappear anywhere else.... I used the pin numbers instead, and it all seems to be ok. But it's not a fun job, and I would happily pay someone the cash to sort it for me, if I were to do it all again.
Crossy
Re: 1g alternator wiring + wiring testing Mon, 01 November 2004 07:34 Go to previous message
Crossy wrote on Sat, 30 October 2004 00:02
thanx
MaT
come on does any one know... cause i can't get it to charge no matter what i try
Previous Topic:MX73 Cressida mods
Next Topic:Timing Belt - 4AGE Smallport
Current Time: Wed Oct 14 18:49:43 UTC 2026
Total time taken to generate the page: 0.14744710922241 seconds
