Toymods » Tech & Conversions » what causes fuel in oil
Simon-AE86
Banned user
ADELAIDE - The Drift City
what causes fuel in oil Sun, 03 October 2004 14:49 Go to next message
noticed my car has been HELL SMOKEY, talking cloudes of smoke on accel, decel, idle etc etc, initially thought it was the turbo but i checked the oil and it looked and smelt like fuel. drained it and yep, the sump was mostly fuel, the oil didnt even FEEL like oil anymore so i hate to think of the engine wear that was inccured.
replaced the oil, went for a short drive and all is fine, no smoke, checked it when i got back and it was still clean., but im guessing it will happen again.
what causes it?
Re: what causes fuel in oil Sun, 03 October 2004 14:57 Go to previous messageGo to next message
in cars with a mechanical fuel pump, if the pump diaphragm ruptures, fuel will piss into the sump.. not good.
in an EFI car, the only sources for fuel into oil are the valve stem seals (being turbo, fuel could be blown thru the seal, into the oil system), or piston ring blowby where mixture gets past rings.
how's your compression?
Simon-AE86
Banned user
Re: what causes fuel in oil Sun, 03 October 2004 15:01 Go to previous messageGo to next message
hmmm i have no idea,
btw its CA18det, stock ecu.
i put a thick 25W60 oil in there, worked a treat...
Re: what causes fuel in oil Sun, 03 October 2004 15:18 Go to previous messageGo to next message
I presume it's not running disgustingly rich... and that the injectors/pressure reg aren't leaking? Does it tend to seem flooded on one/all cylinders when you start it?
Simon-AE86
Banned user
Re: what causes fuel in oil Sun, 03 October 2004 23:23 Go to previous message
nope, starts first crank every time. no smoke on start up.
also, doesnt seem to run super rich, blows the usual amount of black smoke out the exhaust as per all nissan engines..
Previous Topic:cheap boost spike fix
Next Topic:Q's Bout Turbo For GZE-20V??
Current Time: Mon Oct 26 03:17:48 UTC 2026
Total time taken to generate the page: 0.063854217529297 seconds
