Toymods » Tech & Conversions » 4AGE camshafts-HELP!!!!
Michael P
icon5.gif  4AGE camshafts-HELP!!!! Sun, 03 October 2004 22:24 Go to next message
How do I tell the difference between a bigport camshaft and a smallport camshaft if they are not installed in the head. Is there any distinguishing marks to tell the two apart. Can the cam lobe height be measured as I believe that the bigport has more lift so the cam lobe should be bigger (could measure its height with verniers). Does anybody know the cam lobe heights of these cams and would this be the correct way to identify them.
gtr_gaga
Sunshine coast, QLD
Re: 4AGE camshafts-HELP!!!! Sun, 03 October 2004 22:46 Go to previous messageGo to next message
As far as I know, cam duration ont he bigport motors have 240 inlet and 240 exhaust, when the smallport motors have 232 inlet and 232 exhaust... so measure the cam lobe height and see which is bigger... that will be the bigport one.
thats pretty much an educated guess, can anyone back me up or correct me?
Scorpion
Menai area of Sydney
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 02:32 Go to previous messageGo to next message
Not the height so much as that controls the lift.
Duration is where the shape of the cam stops continuing in a circle around the shaft and starts to form the sides of the lobe. 8 degrees isn't a lot of difference so you'll need a keen eye.
I don't know if the lift is higher on one compared to the other though - someone may be able to help here but again I suspect you'd be only talking around 0.5-1.0 mm.
If you can pick which one has the wider base on the lobe that'll be the big port one.
If you can mount he cams in a head with valves you could draw a degree wheel and stick it on the cam wheels or just put a mark on the cam wheel. The turn the camshaft back and forth and see which one turns the least before it hits against the valve - giving a wider cam lobe - bigport.
[Updated on: Mon, 04 October 2004 02:35]
Michael P
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 03:15 Go to previous messageGo to next message
Scorpion, I am planning to use bigport cams in AE92 MAP GZE. Is it worth the effort?
ae86drift
sydney.au
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 07:26 Go to previous messageGo to next message
nope
Scorpion
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 09:29 Go to previous messageGo to next message
I don't have any personal experience with the GZEs but in the forums I've seen it's not uncommon to use bigport cams in small port engines, particularly for turbo conversions. Any improvement may be marginal but I guess any improvement helps.
I'd check the duration of the stock GZE cams first though.
If the bigport duration is longer than the stock GZE then if you have the opportunity, you may as well use them.
You could try posting some more questions in the technical forum and also try the technical forums in www.twincam.org - there are plenty of GZE owners in there.
feral4mr2
Bundaberg, Qld.
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 10:08 Go to previous messageGo to next message
make sure you are looking at the early bigport 4age cams and not just bigport 4agze cams, as the 4agze bigport cams are the same as the smallport 4agze ones.
the early 4age (blue writing on inlet cam cover) has the 7.56mm lift and 240 degree duration cams compared to 7.1mm lift and 232 degree duration the 4agze's have.
i have a set of both in my shed, but am still not sure how to measure the difference properly.
people put them in their 4agze's (mainly bigport AW11 guys that i know of) and report a butt dyno improvement.
i dont know if anyone has tried the difference on a actual dyno?
drift86levin
brisvegas
Re: 4AGE camshafts-HELP!!!! Mon, 04 October 2004 10:54 Go to previous message
i have spent ages on this doing the maths..and found that a bigport inlet cam and a smallport ex cam..both timed with 114 deg Lobe centres..(in relation to TDC) they work out to be perfect for the job with only 8 deg of overlap...i'll post up a dig that i drew up for it..detailing this issue
Previous Topic:EFI using local AE86 fuel lines details
Next Topic:fitting cam in 4k
Current Time: Fri Nov 20 19:43:00 UTC 2026
Total time taken to generate the page: 0.020082950592041 seconds
