Toymods » Tech & Conversions » hookin up the turbo
lilcrash
ipswich queensland
hookin up the turbo Sun, 03 October 2004 23:18 Go to next message
if i bolt the 3tgte exhaust manifold to the 2tgeu can i just run the turbo through the cooler and into the inlet or am i wrong with how this works. ive neva see a turbo engine up close. sorry if i sound retarted.
acreese
Re: hookin up the turbo Mon, 04 October 2004 03:38 Go to previous messageGo to next message
There is a bit more to it than that mate.
I suggest you do some searches on google.com
for
How turbos work,
Turbo setups,
Turboing with high compression,
Turbo oil pickup,
and heaps and heaps more,
There is much to learn. I suggest you do before you cost yourself an engine.
I personally have been working towards turboing my engine, and i have been researching and asking questions for over a year now, only now am i ready to start buying the parts for the setup, as only now to i understand what i need to be doing, and how not to destroy my engine (hopefully Smile)
These forums are very helpful, have a read of some of the posts regarding turboing NA mr2's (with the 4AGE engine) the responses to those threads will give you a good basis from which to start.
If you have never seen a turbo engine up close then i think you better go look at a few before you try and turbo an engine.
There will be heaps of ppl on these forums with experience turboing T series engines, so ask around. There are some gurus here for sure.
Sorry if i sound like i am putting you down, i dont intend to,
Good luck,
-Adam
people100
Rocklea qld
Re: hookin up the turbo Mon, 04 October 2004 08:18 Go to previous message
Firstly u need to find a turbo and manifgold suited to the 2tg engine and the right size turbo for it. You will need to look at upgrading your injecters so u dont lean out. You want more fuel rather than not enough. If you plan on running the standard engine then dont go over 5psi or you will start causing damage to the engine. You could even look at just using a metal headgasket to save dollars. Considering you already have a haltech ecu you will need to get it setup for the turbo buy a professional. You need to put a drain in the sump for the oil and run lines from somewhere that has high pressure oil (posasible t piece out of you oil sendor). then you will also need high pressure water lines and somewhere for that to go back into( maybe around your thermostat housing somewhere.Then you need to look at a bigger exhaust something atleast 2 1/2 inch would be good. You dont need to have a intercooler but it would help. In the end i suggest just find the complete 3tgte engine and drop that in and get some of your money back buy selling the 2tgeu you have. I would not be doing it when you havnt even really seen how the engines work. Theres probably lots more you need to know about
Previous Topic:how to hook up NOS to twin carbs???
Next Topic:will this work if so wat do i need to do
Current Time: Fri Nov 20 22:00:37 UTC 2026
Total time taken to generate the page: 0.0096609592437744 seconds
