Toymods » Tech & Conversions » Starter motor problems, 1 WEEK LATER, YAY IT RUNS!!!
jkvsnn
icon5.gif  Starter motor problems, 1 WEEK LATER, YAY IT RUNS!!! Mon, 04 October 2004 02:51 Go to next message
My 20V/AE92 has suspected starter motor problems. Symptoms are as follows.
Everytime I start the car I can hear what sounds like metal on metal grinding as I release the key when the engine starts.
I few times when driving you can all of a sudden hear the same grinding noise (engine still runs/idles fine during this noisy period) a couple of times the noise has stopped after a few seconds but on a few occasions I have stopped, switched off the ignition and restarted the car.
This morning on my way to work I had the same noise while driving and so pulled over and turned off the car. I tried to restart again only to hear the sound again without the engine turning over. tried a few more times before abondoning the car. Came back after about half an hour, tried again at which point the engine started to kick over before the grinding noise returned and the engine stopped turning over. Luckily I was on a bit over a hill and was abe to roll start the car without drama . I have not tried to restart the car but suspect it won't start again.
Does this sound like it's the starter motor thats screwed?
Is it possible to replace the starter with the engine in or does the engine have to come out? (surely not)
Is the 20V starter different to standard 4AF/4AC starters?.
All guidance and assistance gratefully received.
Julian
Brisbane.
[Updated on: Tue, 12 October 2004 08:31]
1ndecent
Re: Starter motor problems...HELP! Mon, 04 October 2004 05:37 Go to previous messageGo to next message
The low current starting connection to the solenoind may be contacting a positive voltage source, most likely the postive terminal on the solenoid which is connected to the battery. If this occurs the solenoid activates, pushing the starter pinion into the flywheel ringgear and energising the starter motor.
This could be the cause of the symptoms you describe, but like any problem the answer is outside under the the bonnent of your car! Go and have a look...
73ke25
adelaide
Re: Starter motor problems...HELP! Mon, 04 October 2004 09:16 Go to previous messageGo to next message
The starter itself may have a broken shift fork (internal to the starter) which could cause the driver to slide forward and mesh... No doubt by the sound of it the pinion (teeth) are probably very worn also, possibly the ring gear on the flywheel too. Best bet to take it off yourself or take it to an auto elec.
jkvsnn
Re: Starter motor problems...HELP! Mon, 04 October 2004 13:03 Go to previous messageGo to next message
Thanks for the replies guys.
A trip to the auto elec seems to be the order of the day.
Julian.
jkvsnn
Re: Starter motor problems...HELP! Tue, 05 October 2004 02:34 Go to previous messageGo to next message
Holy crap!!!!
Auto elec says starter is well and truly shagged. Wants $380 for a replacement!!!
Just as well I have a 20V front cut at home!
Julian.
soaringmik
Re: Starter motor problems...HELP! Tue, 05 October 2004 03:53 Go to previous messageGo to next message
I had the exact same problem with my GF's AE92 Seca, I was sure it was the starter, and it was only the battery,
Maybe you should get a second opinion.
My 2c Smile
jkvsnn
Re: Starter motor problems...HELP! Tue, 05 October 2004 12:47 Go to previous messageGo to next message
Update,
Located a 4AF/4AC starter at a wrecker near the autoelec, picked it up took it down (a bosch unit that was clearly much bigger, but I was still hopeful it would fit.) Worst luck, didn't fit Sad
The wrecker was able to locate a 4AG starter ($65) from another location which will be delivered and fitted tomorrow.
When I was delivering the wrong starter they showed me the starter they had removed from my car. Absolutely shagged! Armatures burned away/melted cases, broken fork, non existant brushes, teeth half gone from pinion.
Hopefully it will be all fixed tomorrow.
Julian.
jkvsnn
Re: Starter motor problems...HELP! Wed, 06 October 2004 09:26 Go to previous messageGo to next message
Faaarrrrk....ongoing saga continues...
Called em at lunchtime to make sure they had gotten the starter, yes comes the reply....we are just putting it all back together now.
Cool I'll be there just after 5 to pick it up then.
Walk in the front door to see the rolla still on chassis stands, bonnet up and doors open Confused
Whats wrong I says to the boss......no reply/looks pissed
Ask again..."everything is back in, starter works, but car doesn't start. No spark, can't work it out" Sad
More checking around whilst I'm there reveals that ECU seems to be sending the signal but its just not coming out the other end....
I am taking a copy of the blacktop manual, spare ecu, and ecu pinouts to them tomorrow morning.
hopefully this turns out alright.....hate to think what the bill is going to be like...... Crying or Very Sad
Julian.
73ke25
adelaide
Re: Starter motor problems...HELP! Wed, 06 October 2004 12:03 Go to previous messageGo to next message
Well the bill shouldnt be to bad considering it wont start after theyve done work to it. You cant run a business by charging people for things that have gone wrong due to some other work. But anyway , the broken shift fork probably cause the whole lot to go on the starter....
Let us know what the problem was with it not starting.
jkvsnn
Re: Starter motor problems...HELP! Thu, 07 October 2004 08:13 Go to previous messageGo to next message
still won't start Sad
they are now looking into pin L1 which is apparently not feeding what it should or something.
They have tried getting the fault codes from the computer and it just comes up blank......
FARK Mad
Hope I have my car for the weekend!!!!!!
jkvsnn
Starter motor problems, day four has passed at the auto elec.. Fri, 08 October 2004 10:28 Go to previous messageGo to next message
day four is gone now.....stil wont start, swapped the igniter, still no spark.
no wheels for the weekend... Crying or Very Sad
WHAT IS IT!!!!!!!!
jkvsnn
Re: Starter motor problems, 1 WEEK LATER, YAY IT RUNS!!! Tue, 12 October 2004 08:39 Go to previous message
Well, after dropping it off tuesday last week, I finally got the Rolla back tonight!! Turns out the original igniter had died (I drove it there however?) and the igniter plug itself was faulty in that if it was just plugged in as normal the car wouldn't start, if you applied pressure to the plug and REALLY pusshed and held it on the car would start and run, let go and it stops. Once that was fixed everything was fine, boy were they happy to see me go!!
Top marks to the guys at Brisbane Auto Electrics though, they were very good about it all, and the charge was very reasonable considering all of the time and effort they spent on it. Everything has been triple checked on the car now so I guess I don't have to worry about anything electrical being on the way out Smile
Just happy to have it back now.
Julian.
Previous Topic:3SGE Versions
Next Topic:what new clutch for my aw11
Current Time: Tue Oct 20 16:41:58 UTC 2026
Total time taken to generate the page: 0.13859415054321 seconds
