Toymods » Tech & Conversions » ign problems
Supralux
ign problems Mon, 04 October 2004 03:46 Go to next message
the other day i left the ignition in my car on for about an hour. previous to this the car would start first time but now it doesnt seem to be getting a spark. it turns over but just doesnt fire up. taken the plugs out and they are getting fuel so its not that. I have also checked all the fuses and they do not seem to be blown. could the relays be blown or even the ecu?
any ideas before that auto elec comes back????
dingaling
tas
Re: ign problems Mon, 04 October 2004 06:28 Go to previous messageGo to next message
I know that if you have a distributor with points in it, that they will complety burn them selves to buggery if you leave your ignition on. If you have electronic ignition i don't think leaving the ignition on is a problem, except for a flat battery.
73ke25
adelaide
Re: ign problems Mon, 04 October 2004 09:12 Go to previous messageGo to next message
If its a points ignition its possible to cook the coil, just depends if the contacts are closed during the process. Is the engine still cranking over at a normal speed ? Or is it very slugish.... You can check its got spark by holding one of the plugs onto the block while cranking it , hold onto the lead not the plug.
Supralux
Re: ign problems Mon, 04 October 2004 10:52 Go to previous messageGo to next message
it does crank over at normal speed. i will check the points tomorrow. thanks for the ideas
YelloRolla
On your mum!
Re: ign problems Mon, 04 October 2004 11:38 Go to previous messageGo to next message
as above - if it is a points type ignition then you may have burnt the coil out.
Supralux
Re: ign problems Tue, 05 October 2004 08:03 Go to previous messageGo to next message
turns out it isnt points type ignition. i have taken the plugs out and tested them against the manifold and they are getting a spark. also after cranking for a little bit i take one of them out and it has fuel too.
what the hell is wrong if it wont even give me a backfire if it has fuel and a spark? i have used different battery aswell but doesnt seem to make any difference.
The cam oil seal was replaced before the ign was left on but may it have changed the timing slightly so i would need to adjust the dizzy somewhat?
Would it be that the ecu/resistor pack for the injectors is now not working?
YelloRolla
On your mum!
Re: ign problems Tue, 05 October 2004 23:43 Go to previous messageGo to next message
sounds like it may to be too far retarded or advanced. Did you try the timing light? (don't forget to paint the mark with some liquid paper so that it can be easily seen)
Supralux
Re: ign problems Wed, 06 October 2004 01:49 Go to previous messageGo to next message
thats what i will be doing today. trying for spark on all plugs then adjusting the ignition timing. I dont see how it could have changed frokm previous setting tho.
brett_celicacoupe
townsville NQLD
Re: ign problems Wed, 06 October 2004 01:53 Go to previous message
have it at the specified degrees b4 TDC and check the dizzy rotor is lined up at no. 1 cyl.
Previous Topic:2S-C LRP
Next Topic:TA22: Pitman and Idler arms.
Current Time: Sat Nov 21 06:01:32 UTC 2026
Total time taken to generate the page: 0.0055508613586426 seconds
