Toymods » Tech & Conversions » Re-using gaskets..a little advice needed plz
BLK1GGTE
South Eastern Subs
icon5.gif  Re-using gaskets..a little advice needed plz Mon, 04 October 2004 04:24 Go to next message
Just wanted to know has anyone reused their gaskets. I pulled the intake manifold of and the turbo manifold along with the TPS and plan on re-using the gasket with some gasket silent. I would get new gaskets but I have to wait 8 weeks from Japan. Just want to know has anyone done this before and experience any trouble with doing so. The gaskets are not damaged when i pulled them off. Or has anyone got better idea. Can't use gasket paper on the manifold cause of the design but i will use it on the TPS and turbos..
Unless someone has some for sale on the forum???
EVOSTi
cambo
      no
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 08:25 Go to previous messageGo to next message
what part of the design prevents you from making one out of gasket paper?
you can reuse gaskets, just put a thin film of silastic on it. preferably some better quality stuff like permatex blue or whatever it is.
feral4mr2
Bundaberg, Qld.
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 10:28 Go to previous messageGo to next message
Hylomar spray dude for your paper gaskets, best stuff out there. i have even re-used a headgasket on a 4agte with the stuff. Smile
for your exhaust/turbo gaskets use Copper Maxx (Ultra Copper), i dont even have a gasket between my manifold-turbo-dump pipe-exhaust flanges, just the Copper Maxx.
YelloRolla
On your mum!
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 11:36 Go to previous messageGo to next message
There are new gaskets out there I am sure (try Stewart Wilkins Rally in Sydney).
Re-using gaskets is fine - as per above comments.
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 12:07 Go to previous messageGo to next message
feral4mr2 wrote on Mon, 04 October 2004 20:28
that copper stuff is pretty sturdy stuff - despite getting the entire exhaust manifold red hot on the 18R, the coppermaxx was still there when i pulled the turbo off the manifold ... it was mostly a fine reddish poweredy crap but at least it hung around unlike the manifold-to-head gasket.
allencr
tallahassee FL usOFa
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 13:05 Go to previous messageGo to next message
there isn't much chance of re-use if any kind of cement/sealant has been used on them previously, so if you want or might need a third "use" out of them, i wouldn't use the goop.
indigoid
Canberra, ACT
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 15:55 Go to previous messageGo to next message
I've reused gaskets in Aisan carbs without troubles. It sure would suck buying a new gasket every time you changed a jet
Re: Re-using gaskets..a little advice needed plz Mon, 04 October 2004 15:58 Go to previous message
allencr wrote on Mon, 04 October 2004 23:05
i find using silicon sealants (red, grey, etc) on manifold-to-head gaskets makes them come off much easier and in one piece. not sure i'd reuse them, but i could if i needed to..
it does make it much easier to clean the mating surfaces too.
Previous Topic:What lift pump?
Next Topic:Water pump cracked !
Current Time: Sat Oct 31 11:42:32 UTC 2026
Total time taken to generate the page: 0.071329116821289 seconds
