Toymods » Tech & Conversions » 4ag 100kw
Flem
cambo
4ag 100kw Mon, 04 October 2004 05:42 Go to next message
hey im doing a 100kw conversion in my 4afc corolla my questions is do i have to connect ELS1 ELS2 A/C OR SPD for the 12 pin ecu connecter im not running air or steer , does that also go for the body connector (f2 grey) so i dont have to connect up a/c wires ,also does the 4afc cluster have a input for the check engine light or can i hook a small light up or am i going to have to change the cluster sorry for another 4ag question i did a search i got pages of crap but i got a pin out diagram
koen
Re: 4ag 100kw Mon, 04 October 2004 06:31 Go to previous messageGo to next message
Check out Phil Bradshaw site:
http://home.clear.net.nz/pages/phil.bradshaw/EFI%2 0Operation.htm
I was reading it this morning and i'm fairly certain it will answer your question. SOmewhere on there he has a table containing the ECU pinouts and what is strictly necessary to get it running.
ae86drift
sydney.au
Re: 4ag 100kw Mon, 04 October 2004 06:42 Go to previous messageGo to next message
http://www.club4ag.com/technical_main.htm#4A-GE/GZ E%20Specifications%20and%20Data
4A-GE 16V / 4A-GZE / 4A-GE 20V Specifications and Data
4A-GE (Japan) 16V / 20V Specifications
4A-GE 16V (Japan) AE86 ECU Pin Identification
4A-GE 16V (Japan) AE92 (Non-TVIS) ECU Pin Identification
4A-GE 16V (Japan) AE92 (TVIS) ECU Pin Identification
4A-GE 16V (USA) AE82 FX/Sedan ECU PINS
4A-GE 16V (USA) AE86 Corolla GTS ECU PINS
4A-GE 16V (USA) AE92 Coupe GTS ECU PIN
4A-GE 16V (USA) MR2 AW11 ECU PINS
4A-GE 20V (Japan) "Black Top" AE111 ECU Pin Identification
4A-GE 20V (Japan) "Silver Top" AE101 ECU Pin Identification
4A-GE Connecting Rods
4A-GE Engine Block Specifications and Variations
4A-GZE (Japan) AE92/101 ECU Pin Identification (Now including wire diagrams)
4A-GZE (Japan) Specifications
4A-GZE (USA) AW11 ECU Pin Identifications
4A-GZE DLI Systems and Substitution
AE86 Driver /Passenger Part Number Information - Repairs
AE86 Final Drive (Differential) Gears and part numbers
AE86 Model Name Comparison
AE86 TRD N2 Spec. Racing Components
Camshaft Comparison Chart 4A-GE 16 Valve
Camshaft Comparison Chart 4A-GE 20 Valve
Toyota ECU Diagnostic Codes
Toyota Transmission Specifications
Frequently Asked Questions
[Updated on: Mon, 04 October 2004 06:42]
Flem
cambo
Re: 4ag 100kw Mon, 04 October 2004 09:55 Go to previous messageGo to next message
AE86DRIFT cant you read ive got the wiring diagrams but i want to know do i have to use the pin outs as stated above what have you done to your 4ag or you wouldnt have a clue???
koen ive got the 20v version but not the 16v hes site is part down so i spose ill have to wait or hopefully someone thats done this will lend as few pointers
[Updated on: Mon, 04 October 2004 10:03]
koen
Re: 4ag 100kw Mon, 04 October 2004 11:12 Go to previous messageGo to next message
This is what i was talking about:
http://home.clear.net.nz/pages/phil.bradshaw/16v%2 0Pins.htm
or
http://www.club4ag.com/faq%20and%20tech_pages/ECU% 20Japan%20AE86%204A-GE.htm
By the look of that you def don't need A/C or SPD but i'm fucked if i know what the other two wires you're talking about are. There's not much on that plug you do need though, according to that info.
shinybluesteel
melbourne
Re: 4ag 100kw Mon, 04 October 2004 11:33 Go to previous messageGo to next message
the pinouts on phils site are for a bigport, not a smallport, there arent enough pins...
edit: the ones on club 4AGE are for a bigport too.
im finding this very useful, i want to hook up as few wires as possible on mine.
[Updated on: Mon, 04 October 2004 11:34]
koen
Re: 4ag 100kw Mon, 04 October 2004 11:47 Go to previous messageGo to next message
Ah, right. My bad.
There're a couple of things on that list that they say aren't necessary but you'd really want to have connected imo, like the circuit open relay.
ae86drift
sydney.au
Re: 4ag 100kw Mon, 04 October 2004 12:16 Go to previous messageGo to next message
Flem wrote on Mon, 04 October 2004 19:55
AE86DRIFT cant you read? ive got the wiring diagrams, but i want to know do i have to use the pin outs as stated above. what have you done to your 4ag? or you wouldnt have a clue???
just trying to help you out. there may be somethign there you may be able to use.
on my 4age we used the ae86 computer from my previous engine
we did nt worry about this pinout problem as we didnt encounter it.
jeez. forget it.
Scorpion
Menai area of Sydney
Re: 4ag 100kw Mon, 04 October 2004 13:34 Go to previous messageGo to next message
ELS1 is Stop Lamp Switch
ELS2 is Idle Up Diode
A/C is Air Conditioner Clutch
SPD is Speed Sensor (in SX cluster only)
IMHO the first three would be optional in your case.
The SPD sensor, or lack of, from what I've read in forums, affects the rev limit of your engine. Again optional but I think my engine runs more smoothly with it connected - not sure why or whether it is psychological.
Don't understand what you mean by "F2 Grey" as I can't see any A/C connections on either of the two grey ECU connectors.
The 4AFC doesn't have an engine check light but yes you could hook up a light if you wished.
Have you looked at the ECU Pin Out Identification on www.club4ag.com ?
If you got a CSi cluster it should have a tacho, speed sensor (I think) and an engine check light. hmmm .. maybe not a speed sensor.
I think you'll find that A/C connections are to trigger the idle up process whichyou shouldn't need.
Flem
cambo
Re: 4ag 100kw Tue, 05 October 2004 07:49 Go to previous message
the grey f2 (22 pin)connector is connected to the c/open wires its connects to the body loom it also connects all the cluster up to the respectable? sensors Smile
i was hopeing the 4af cluster would have a check engine circuit of some sort, ill pull the cluster out and check it out, i might be able to mod the cluster to have a check engine light thanks for the input guys (side show does a speed sensor )
Previous Topic:ae86 Oil pressure gauge q's
Next Topic:steering wheel legal
Current Time: Fri Nov 20 22:55:10 UTC 2026
Total time taken to generate the page: 0.0056188106536865 seconds
