Toymods » Tech & Conversions » engine delima?need suggestions
FKN16V
NSW, East Coast
engine delima?need suggestions Mon, 04 October 2004 08:27 Go to next message
motor rb20det in a s13, i know its not toyota but i thought id start here,
When we remove the coil plug from n#6 coil nothing happens, do it to the others and the motor runs a little rough (no surprise there) but this n#6 cyl has got us stumped.
there is fuel and there is spark, there are no rattly unusual noises, what could be the problem witht he number 6 cyl,
I will also post on skyline forums.
Please help?
Steve
BradW
Bottom of the hill, Sydney
Re: engine delima?need suggestions Mon, 04 October 2004 08:31 Go to previous messageGo to next message
FKN16V wrote on Mon, 04 October 2004 18:27
The only other thing it needs is compression.
Brad
FKN16V
NSW, East Coast
Re: engine delima?need suggestions Mon, 04 October 2004 09:29 Go to previous messageGo to next message
BradW wrote on Mon, 04 October 2004 18:31
Brad
Although we havent tested it with a gauge, there was enough pressure in the cyl to blow my mates hat of when the spark plug was out.
He also said that something hit him in side of the head, couldve been been part of the valve (suspect broken maybe) but the oil pressure hasnt changed at all, might've been compression ring, who knows.
Steve
Re: engine delima?need suggestions Mon, 04 October 2004 09:58 Go to previous messageGo to next message
dodgy valve seals/faces?
... not evident when the plug is out, but once in- probably obvious effective at lowering compression once plug reinserted.
do a wet/dry comp test on that cyl followed by a leak down - and if you have the time/money get a boroscope (spelling?) to look at the bores for scoring (dud rings).
no noises would probably indicate that at least the crank is alright.
btw - is there excessive crankcase pressure (measure with hand over oil filler hole - pressure should fluctuate from mild vacuum to slight pressure at idle)?
oil pressure would remain good even if a valve broke off - droap in pressure would indicate problems with bearings etc...
73ke25
adelaide
Re: engine delima?need suggestions Tue, 05 October 2004 09:56 Go to previous messageGo to next message
Is the lead to that plug in looking pretty shity ? Might be tracking somewhere before the plug.... you can normally see that though if its really obvious. Fouled plug even ? Are you sure that #6 injector is triggering ? Other then that there isnt really anything else electrical... Like the others said check compression i suppose.
jesseT18
Castle Hill, Sydney
Re: engine delima?need suggestions Tue, 05 October 2004 10:21 Go to previous messageGo to next message
i think us toymodders must be considered the guys to come to when ure car has problems!
ppl are always popping in from other forums to ask toymods whats going on
FKN16V
NSW, East Coast
Re: engine delima?need suggestions Tue, 05 October 2004 10:37 Go to previous message
jessetamsett wrote on Tue, 05 October 2004 20:21
I live here so its only normal to ask here first, besides doent matter who makes the motor, i was only lookin for ideas as the what the problem maybe, toyotas have multicoils as well .Thanks guys all suggestions will be tried,
Steve
Previous Topic:*fixed*- AE92 front end CLUNK
Next Topic:1G ECU Question
Current Time: Sat Nov 21 02:41:39 UTC 2026
Total time taken to generate the page: 0.0065641403198242 seconds
