Toymods » Tech & Conversions » fitting cam in 4k
bassy
fitting cam in 4k Mon, 04 October 2004 09:18 Go to next message
Ive just picked up a free cam for my 4k. It has been modified and is suppose to sound rather lumpy. Can someone explain the easiest way of installing it?
thanx
Re: fitting cam in 4k Mon, 04 October 2004 10:34 Go to previous message
remove engine from engine bay
remove sump
remove crank pulley and timing cover
loosen rockers and remove pushrods and lifters (no8 may not come out, so gold it up with coathanger)
take off both timing sprockets and timing chain (catch the tensioner)
remove cam thrust bearing
use old headbolt in end of cam, and carefully pull old cam out.
installation is the reverse of pulling out Wink
how 'lumpy' is lumpy? is the base circle of the lobes now below the cast part of the shaft? (ie has the base circle area been cleaned up?
what is height of lobe (measure difference between base circle and base circle+lobe)
if it's too big, you should mod the rocker towers..
Previous Topic:4AGE camshafts-HELP!!!!
Next Topic:Camry Cigarette Lighter Problem
Current Time: Fri Nov 20 20:02:30 UTC 2026
Total time taken to generate the page: 0.0065529346466064 seconds
