Toymods » Tech & Conversions » AFM and Accurate Boost control
acreese
AFM and Accurate Boost control Mon, 04 October 2004 11:21 Go to next message
Is it possible to maintain accurate boost control, using factory SW20GT ECU and a ct26 or Pulsar GTi-R turbo charger?
If the factory ECU alone cannot do this reliably, please suggest what i can use in conjunction with it to achieve this goal.
I want to eliminate severe boost spiking, and without purchase of an aftermarket ECU, my target boost is 7-8psi, if this helps.
-Adam
shinybluesteel
melbourne
Re: AFM and Accurate Boost control Mon, 04 October 2004 11:29 Go to previous messageGo to next message
boost control on a gtir turbo (a T28 by the way) will be comtrolled by itself, as it has its own wastegate and wastegate actualtor, set at aroun 8-9 PSI from memory.
very rarely is boost pressure controlled by the ECU.
acreese
Re: AFM and Accurate Boost control Mon, 04 October 2004 11:35 Go to previous message
Thanks for the info mate.
That will help me a fair bit i think.
Will be on the lookout for a t28 then over the next few weeks.
-Cheers,
Adam
Previous Topic:electronic ignition
Next Topic:EFI using local AE86 fuel lines details
Current Time: Fri Nov 20 20:35:05 UTC 2026
Total time taken to generate the page: 0.0046429634094238 seconds
