Toymods » Tech & Conversions » does it matter which way a throttle plate opens??
ed_ma61
Lost in the K hole
icon5.gif  does it matter which way a throttle plate opens?? Mon, 04 October 2004 13:08 Go to next message
as in title??
does it matter if the throttle plate opens one way or another?
ie, the top of plate rotates outwards opposite to the flow of incoming air, whilst the bottom of plate rotates inwards in the direction of the intake flow? (this is the *normal* direction of plate rotation i believe)
OR vice versa?? does it matter?
would the plate induce preferential flow to the bottom of the port (at part throttle) in the normally rotating plate? would i flip this preferential flow to the roof of the port of the throttle opened the opposite way??
does it matter? perhaps its would if the throtle is very close to the head and intake valve?
also - does it really matter if the heads of the fasteners attaching the throttle plate to the shaft sit outwards or inwards? normally the face out, i guess as a consequence of access in the even that they may loosen?? otherwise??
any issues i havent addressed?
ed
Re: does it matter which way a throttle plate opens?? Mon, 04 October 2004 13:54 Go to previous messageGo to next message
Well, my stock one the bottom half goes in, and the top half goes out, (as do all toyota RWD's I think), but my 2nd TB will have it going the opposite way, so it better not make a difference.
EDIT: Ala this photo.
I will be picking it up this week hopefully
http://wesside.0wnsj00.net/pics/MAN02.jpg
Quick hijack for me, reckon I have one opening after the other? or both at the same time?
[Updated on: Mon, 04 October 2004 14:03]
Re: does it matter which way a throttle plate opens?? Mon, 04 October 2004 14:03 Go to previous messageGo to next message
if you are thinking ITB's, i'd be looking at high end bikes for guidance.. they seem to do their homework a little better than most car manufacturers..
edit http://www.mcnews.com.au/NewBikeCatalogue/2001/Suzuki/GSXRimages/GSXR1000_injector_600p.jpg
this is the pic i was thinking of, but it doesn't really help much.. sorry..
[Updated on: Mon, 04 October 2004 14:16]
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: does it matter which way a throttle plate opens?? Mon, 04 October 2004 14:32 Go to previous messageGo to next message
One thing I noticed looking at the recent pics of the BMW V10, the port shaping is very much influenced by the direction the throttle opens.
http://www.bmwm5.com/articles/m5e60/motor/23-800.jpg
How good is that, nice steep angle straight into the cylinder, & it couldn't be more than 150mm from the throttle to the back of the valve. Cool
Darren
Re: does it matter which way a throttle plate opens?? Mon, 04 October 2004 23:54 Go to previous messageGo to next message
I was told you want the blade opening inwards on whatever side has the shortest path to the valve. Apparently the air starts moving on that side of the port first and a higher percentage of the total air ends up flowing along that side.
The pic of the V10 seems to agree with the theory....
Darren.
ed_ma61
Lost in the K hole
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 03:49 Go to previous messageGo to next message
i hate questions that end up with an answer requiring reading lots of fat books and too much time on google Confused
stewy - what was that intake pic from?
and yeah - i love that bmw v10 Shocked
very interesting the changes in intake dia's that it has...
edit - doofy spelling of cahnages
[Updated on: Tue, 05 October 2004 04:09]
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 04:04 Go to previous messageGo to next message
from a GSXR1000 (google search'images' for GSXR throttle)
i would so love that V10 intake on my 4K Wink sigh.. i can dream can't i? Laughing
takai
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 04:08 Go to previous messageGo to next message
That BMW engine will have some lovely air speed.
As for throttle actuation, the 20v ITBs normally actuate top in bottom out. I have flipped the throttles upside down as per what Darren has suggested. Im guessing it woudl be about 100-110mm from butterfly to the valve seat. Ill have to do some better measurements when i pull the head off.
Most FWD Toyotas open top in bottom out, wheras RWD have bottom in top out.
ed_ma61
Lost in the K hole
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 04:09 Go to previous messageGo to next message
bizzare
RWDboy
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 07:23 Go to previous messageGo to next message
Basically that's correct Smile Although I think the air speed on the outwards moving side would be greater, the volume flux would still be lower (lower pressure).
RWDboy
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 07:33 Go to previous messageGo to next message
Actually - when I think about it...it won't make much difference to the over-all power, or even the torque curve, it'll just change the throttle response...so err - what's the big deal? If you have the throttle move inwards on the side with the shortest intake path, then you might end up with slightly laggy throttle response but have a more linear relationship between power output and throttle opening...but if you have it the other way around, you will have snappier throttle response (good air speed), but less linear relationship (peakier) between throttle application and power output.
ed_ma61
Lost in the K hole
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 07:47 Go to previous messageGo to next message
i like stories Confused
Darren
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 10:32 Go to previous messageGo to next message
The throttle shafts on my 4AG are vertical and it makes great power albeit with some intake reversion at about 5000 rpm.
Hows that for a story?
Don't panic, we think the reversion is caused by the headers being too small not the orientation of the throttles Very Happy
Darren.
clubagreenie
1st street on the right
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 11:08 Go to previous messageGo to next message
Some carbs are top in, some are bottom in. Some have pistons that slide up, some slide down. Originaly was pretty much a flavour of the month thing coupled with how easy was it to make it work from the linkages. These days we can gather a lot more info about what happens to the air. It also depends on your plenum design, if it's like the Bm then you want it down. If it's like say a Range Rover, large plenum with trumpets inside then you'd want it flowing up.
EDIT: theres also slide butterflies and vertical shaft bflies
[Updated on: Tue, 05 October 2004 11:53]
RWDboy
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 13:06 Go to previous messageGo to next message
For what reasons, what are the 'advantages' over the other way around?
ed_ma61
Lost in the K hole
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 15:42 Go to previous messageGo to next message
first up - sorry for my pissy responses during the day... ive had a shocker No No No
i simply didnt have time to write anything meaningful.
ive yet to have any time to do any serious reading on the matter either.
darren - id be interested to talk to you about the reversion youre experiencing. its a killer, yet i know very little about how to design around it. there appears to be very little info avalable on it also (or perhaps im just reading the wrong books)
hell, i need to have a decent sit down talk with someone about intake velocities and harmonics in general...
Darren
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 22:34 Go to previous messageGo to next message
Ed,
The reversion happens just after it starts to come onto the cams, it's almost as though the headers can't handle the sudden increase in flow.
We tried smaller, straighter inlet trumpets which helped reduce it (and also made a heap more power as a little bonus). Now we are trying some things with stepping and collector design in the headers. Then we've got some new CNC'd trumpets (they are simply spank worthy!) with different shapes that may or may not work. Ultimately we might try a horizontal throttle shaft, provided I don't run out of money Confused
When we get the car back on the dyno, hopefully in the next couple of weeks, come out and have a look.
Steve_Reynolds
Gold Coast
Re: does it matter which way a throttle plate opens?? Tue, 05 October 2004 23:34 Go to previous messageGo to next message
Many of the high performance race engines I have seen also have slide throttles or throttle plates pivoting on the vertical axis. Personally, I feel this suggests it doesn't make a great deal of difference which way they open.
ed_ma61
Lost in the K hole
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 00:14 Go to previous messageGo to next message
Darren wrote on Wed, 06 October 2004 08:34
Ed,
darren, id be very interested to stick my head in on the dyno Nod
ill PM you my number...
RWDboy
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 04:02 Go to previous messageGo to next message
My guess is that any reversion will be related to harmonics in the design of the manifold/ports/valves, but then again I have no idea what kind of set-up you are using Razz
Darren
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 04:49 Go to previous messageGo to next message
FWDboy wrote on Wed, 06 October 2004 14:02
100kw 4AG, 320deg TRD cams, shim under buckets, big valve springs, port work, 45mm (i think) throttle bodies, fabricated manifold, yadda yadda yadda... nothing that hasn't been done before. But the headers are small diameter sand bent ones.
I guess only Dyno time will tell. It could well be the vertical throttle shafts!
RWDboy
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 05:03 Go to previous messageGo to next message
I'm hoping that later this year I will start work on a real-time flow simulation that will be able to compute these kind of problems numerically in real-time (and thus be able to respond to certain realistic conditions) based off of CAD designs.
allencr
tallahassee FL usOFa
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 15:32 Go to previous messageGo to next message
yes. on which ever side it is easiest to put the idle system & acc. pump jet.
i think its a manufacturing decision rather then performance or engineering.
Darren
Re: does it matter which way a throttle plate opens?? Wed, 06 October 2004 22:16 Go to previous message
allencr wrote on Thu, 07 October 2004 01:32
Which idle system and acc. pump jet would that be Allen?
Previous Topic:RT142 IRS - T or F series diff
Next Topic:GZE idle up motor
Current Time: Sat Oct 31 10:57:46 UTC 2026
Total time taken to generate the page: 0.073974132537842 seconds
