Toymods » Tech & Conversions » What was the standard gearbox for....
checks202
icon5.gif  What was the standard gearbox for.... Mon, 04 October 2004 13:10 Go to next message
Ok just a quick question before i throw it out. Last of the RWD Tarago's , what gearbox did they normally have bolted up on the 3y and 4y engine? I know it's a 5 speed but after a bit more than that. Thanks guys.
ChuckLandwehr
icon3.gif  Re: What was the standard gearbox for.... Mon, 04 October 2004 14:06 Go to previous messageGo to next message
Not sure of the specific number for these boxes, however they are the same front pattern as a W55/57/58. ie a W55, will bolt up to the "Y" bellhousing. The ratios would be a commercial vehicle setup. I hope this has shed a little light on the subject for you.
regards Chuck
checks202
Re: What was the standard gearbox for.... Mon, 04 October 2004 23:42 Go to previous messageGo to next message
Thanks for that. Does it say anywhere on the gearbox whether its a W55/57/58. Would the gear ratios work on a standard car? Owell just seeing if their worth something. $10 and someone here can have it but i think the bearings are rooted and i used the angle grinder on the lay shaft so umm yea need another one of them. Razz
Purple_Beasty
New Zealand
Re: What was the standard gearbox for.... Tue, 05 October 2004 00:35 Go to previous messageGo to next message
Casing is quite different if they are like the rest of the Toyota van boxes I have looked at. Rear mount is bolted to the top of box, with no provision for the car type of mount and usually column or remote linkage change. Might be worth something as scrap metal maybe???? To see the box number look on the chassis plate, have vague recollections of them being a C box.
Callum
Re: What was the standard gearbox for.... Tue, 05 October 2004 02:27 Go to previous message
It's probably a G5x box, like the Hilux.
Previous Topic:no muffler?
Next Topic:G Series Rear End
Current Time: Sun Nov 1 04:30:50 UTC 2026
Total time taken to generate the page: 0.015940189361572 seconds
