Toymods » Tech & Conversions » Weak points of an ae86 chassis
no_tofu_speed
Jab what?!!?!
Weak points of an ae86 chassis Tue, 05 October 2004 04:08 Go to next message
I been trying to find this answer for a while.
The main weak points of an ae86 chassis.
As in first places to give or most prone to it. People always talk about overpoweering an ae86 chassis, and stitch/seam welding it.
For surely someone has to know the maint weak point or the places that will give under stress first....
ae86trueno
Re: Weak points of an ae86 chassis Tue, 05 October 2004 04:46 Go to previous messageGo to next message
ahh lets see front Chassis rails will defineatly bend if hit sideways, ive had a top front strut mount go through the chassis, the panard rod ripped the mount from the floor, and the chassis is creased a little behind the front seats,
i could be here all day !!
Ben.
ae95
Re: Weak points of an ae86 chassis Tue, 05 October 2004 04:57 Go to previous messageGo to next message
As stated above the front chassis rails are inherently weak. they have notches in them which is designed to help them buckle in a head on collision.
[Updated on: Tue, 05 October 2004 04:58]
optionUP
Perth, WA
Re: Weak points of an ae86 chassis Tue, 05 October 2004 06:01 Go to previous messageGo to next message
I think someone on these forums also said something about the point where the chassis rails meet the firewall... can anyone confirm this?
..I remember someone else here saying with powerful cars (200~250 HP) that the roof can buckle just back from the A pillar, especially if the car has a sunroof.
Where the B pillar joins the body is also where AE86's commonly rust, I believe, and weaken the body as a result.
On a similar theme, I have heard that you can buy (or make) brackets you can bolt onto parts of the car to improve strength/rigidity (not strut braces, but under the body) - any one know where these are generally fitted on the car?
[Updated on: Tue, 05 October 2004 06:08]
ae95
Re: Weak points of an ae86 chassis Tue, 05 October 2004 06:08 Go to previous messageGo to next message
yes, where the chassis rails meet the firewall the welds seem to come undone quite a bit.
You can buy front and rear strut braces, an A-Spec brace(from steve-ae86), a full cage, under guard bracing and cusco make some braces that go under the front to help stiffen up the chassis
ae86drift
sydney.au
Re: Weak points of an ae86 chassis Tue, 05 October 2004 06:55 Go to previous messageGo to next message
remember, in small offs on the track and road, if you have strengthened certain parts of the chassis and not others, you can tear and pry the other parts of the car apart without knowly doing so.
so if your going to brace, from front to back:
under tension rod bar (cusco)
front strut brace (any)
4/6/8/12 pt roll cage (any, cams approved is better)
b pillar bar (hard to find, ssworks make one)
b pillar floorpan brace (do luck makes the best)
c pillar bar (ie aspec brace, useful for harness')
rear strut top brace (techno pro spirit, revolver, ssworks, ect)
tower brace (cusco type)
rear torsion/stabilzer bar (silk road)
then go the seam weld/spot weld/chassis riviting to make sure your internal bracing isnt killing th 20yr old orignal welding.
EVOSTi
cambo
      no
Re: Weak points of an ae86 chassis Tue, 05 October 2004 07:36 Go to previous messageGo to next message
bah! drive the car, when something breaks, fix it Cool
mr2drift
Re: Weak points of an ae86 chassis Tue, 05 October 2004 08:50 Go to previous messageGo to next message
EVOSTi wrote on Tue, 05 October 2004 17:36
Very Happy Very Happy Very Happy Very Happy thats the way haha so saying my car is now seam welded throughout plus cage welded in at 9 points to 6mm thick 100 x 175 mm steel plates at all contact points... heheh can you say stiff?
ae86drift
sydney.au
Re: Weak points of an ae86 chassis Tue, 05 October 2004 09:02 Go to previous messageGo to next message
mr2drift wrote on Tue, 05 October 2004 18:50
thats the way! Very Happy
optionUP
Perth, WA
Re: Weak points of an ae86 chassis Tue, 05 October 2004 14:33 Go to previous messageGo to next message
Hmmmm, so let me see if I got this right. You gots your:
Battle Version Front Tension Rods:
http://www.battleversion.com/img/DSC01362.JPG
...your Cusco Under Tension Rod Bar:
http://www.maz-sport.com/cusco/lower_arm_images/e_tenrod2.jpg
...your Autopower Race Roll cage:
http://www.ioportracing.com/images/product/rb-raceasb.gif
...your ssworks B-pillar bar:
http://www.on.rim.or.jp/~ssworks/bar+5.JPG
...your Do Luck Front Ladder Bar:
http://www.do-luck-usa.com/images/gallery/assistbars_03.jpg
..and your Do Luck Rear Cross Bar:
http://www.do-luck-usa.com/images/gallery/assistbars_05.jpg
...and then ya has ya A-Spec C Pillar bar:
http://www.users.bigpond.com/steveg101/rearbraces.jpg
..and finally your T3 Rear Strut Brace with tri-member.
http://www.technotoytuning.com/media/t3/products/tribar_rear.jpg
And then I read about some under-fender brackets, but couldn't find a decent picture of one.
How's that? Surprised
...oh, and Silk Road make a panhard rod mounting point bracket, but they don't have a pic of it.
[Updated on: Tue, 05 October 2004 14:35]
optionUP
Perth, WA
Re: Weak points of an ae86 chassis Tue, 05 October 2004 14:37 Go to previous message
Do the Do Luck bits go inside the car, or underneath it?
Looks like they hoop over the transmission tunnel.
Previous Topic:sa 63 engine conversion
Next Topic:3sge g/box - motor bolt sizes
Current Time: Sat Nov 21 05:18:51 UTC 2026
Total time taken to generate the page: 0.0081489086151123 seconds
