Toymods » Tech & Conversions » Re-Use Gaskets
-==L=a=N=c=E==-
Brisbane, Queensland
Re-Use Gaskets Tue, 05 October 2004 10:58 Go to next message
Okay, i have just dropped the fuel tank in my GT4, and i needed all the parts removed so i could drop it off to get repaired.
Now i dropped into Toyota to get new gaskets, and this is what i got back
filler pipe : 77169-14010 $7.20
evap pipe : 77179-16010 $45!!!?!?!!
sender hole : Can't find it in the EPC They don't know
pump hole : 77169-14010 $7.20
Now natually, i got the 2 cheaper gaskets, i can't justify using the $45 gasket at all, and was a bit dissapointed that they didn't know what gasket was used on the sender hole.
So what are my options, can i reuse the gaskets i have here, with a bit of gasket glue, and plenty of torque? or should i make up my own gaskets? or should i ring around and find some aftermarket or something....?
sprinter_turbo
North Brisbane
Re: Re-Use Gaskets Tue, 05 October 2004 11:11 Go to previous messageGo to next message
if the gasket is not broken or ripped then it should be ok to re-use with just a smear of grease on both sides.
-==L=a=N=c=E==-
Re: Re-Use Gaskets Tue, 05 October 2004 22:21 Go to previous messageGo to next message
sprinter_turbo wrote on Tue, 05 October 2004 21:11
Thanks for that, ill do that if i am out of options.
Ive been given word that the $45 gasket might actually be a set. I ordered it anyways just in case.
When you say greese, you just mean the normal gasket greese you get from autocheap etc...?
pheonix83
Devonport Tasmania
Re: Re-Use Gaskets Wed, 06 October 2004 04:44 Go to previous message
casket paper and a stanley knife.
i made all my water related gaskets out of repco gasket paper.
cost me under 10 bucks, and a little time watchin tv
Previous Topic:Upgrading diff in KE35 Corolla - spring plates?
Next Topic:exhaust or cams? hmmm
Current Time: Sat Nov 21 06:56:05 UTC 2026
Total time taken to generate the page: 0.003964900970459 seconds
