Toymods » Tech & Conversions » 3tgte in need of help
GOT_M.I.L.F.
adelaide
icon9.gif  3tgte in need of help Tue, 05 October 2004 11:11 Go to next message
ive discovered exceeding amounts of oil blow by. after a hard run i find the engine bay covered in oil. the rocket cover breather has not been plumbed into the air intake yet. even on cold start up it blows way to much smoke. ive been pickin my brain to find other reasons hoping its not not the rings.
Any input is appriciated.
scrote
Re: 3tgte in need of help Tue, 05 October 2004 14:30 Go to previous messageGo to next message
give your car a compression test,good way to tell if something internal gone wrong.
TE72_Turbo
Re: 3tgte in need of help Wed, 06 October 2004 02:48 Go to previous messageGo to next message
Does the engine still run fine? Its not uncommon to break ring lands on the pistons with these engines (from detonation), but it should be relatively obvious when it runs like its on 3 cylinders Crying or Very Sad At idle it may sound like you've installed some really fat cams Razz
How long have you had the engine running in the car?
GOT_M.I.L.F.
adelaide
Re: 3tgte in need of help Wed, 06 October 2004 09:38 Go to previous messageGo to next message
runs fine, does sound ever so slightly like its missing at idle but not as though its on 3 cyl. hasnt been running in the car long.
3T-GTE
Re: 3tgte in need of help Wed, 06 October 2004 23:18 Go to previous message
I know that you probably don't want to hear this, but I agree with TE72_Turbo here... sounds like you may have lost a piston "3T-GTE style".
Thankfully, when the piston breaks between the ring lands, it doens't do major damage to your cylinder bore.
Do a compression test, it will soon tell you if this is the problem or if it is something else.
If it is a piston, time to rebuild - throw in a set of forgies straight away, you'll be glad you did!
Previous Topic:18RG carbie inlet gasket
Next Topic:RT142 IRS - T or F series diff
Current Time: Fri Oct 30 11:32:14 UTC 2026
Total time taken to generate the page: 0.011376857757568 seconds
